Originally Posted by
Joe Dirt
Thank you for the curt response.
His response is understandable, because it sounds like you are getting into a trade that your shop is not equipped for. You described your business as a "garage," which usually means a mechanic. Mechanics generally don't install aftermarket stereos, because a) that requires a bunch of specialized knowledge, which is why there are car stereo shops, and b) because of the jungle of proprietary manufacturer audio systems that are not simple to modify, which you are running into. I would not have a car stereo shop replace my power steering pump, because that is a job for a mechanic. Your description of the problem is totally lacking in detail, which leads me to believe that you don't know car stereos very well.
If I had to guess, I'd say you somehow put speaker level outputs into the amp's RCA level inputs, but that doesn't explain why the sub still works.
