Sorry, I don't think info@eurocode read your question. I'll make sure he takes his ADD med today.
The endlinks do not require special tools. All you will use are open end wrench and hex sockt. They are as easy as pie to replace, held in by two bolts. The install manual won't have pics, but you really shouldn't put these on if you need pics. Its easier than an oil change. Hope this helps.
in the background while hitting head against the desk..."damn you info@eurocode did you forget to bring your add med again"
