Results 1 to 30 of 30
    Dec 03 2008
    2018 SQ5
    Castle Rock, Colorado
    Adjust windshield washer nozzle?
    My passenger nozzle isn't spraying high enough, so it hits the wiper arm head on and won't hit the windshield. I looked at the nozzle, and it just snaps into the hood, and doesn't look like it can be adjusted? Maybe there is a slight clog in the line somewhere? What can I do?
    JR
    2021 Audi S4, P34 Intake
    Established Member Two Rings S4SHOES's Avatar
    Jan 21 2011
    Calgary
    there is a special audi tool to do it but its not necessary
    i use a pin, stick it in the nozzle and adjust that way
    i believe this is common practice
    there is a spec they are supposed to be adjusted to but just keep in mind the stream hits your windshield lower at higher speeds
    Dec 03 2008
    2018 SQ5
    So you are saying just stick like a safety pin in the hole and aim it up that way?
    JR
    Senior Member Three Rings Heavy Fluid's Avatar
    Mar 23 2009
    2010 Specialized Stumpjumper FSR Comp
    Michigan
    Mine is the exact opposite. Driver's side pretty much clears the windshield, over the roof, and onto the back window. I need to get the pin in there and adjust.
    2013 Ford Mustang GT Premium - 6MT - Shelby GT500 exhaust
    Veteran Member Four Rings bman005's Avatar
    Sep 06 2011
    2015 Silverado, 2012 A4 Avant. Former; 90 Corrado, 97 Golf, 05.5 A4, 2010 Tiguan
    Harrisburg, Pa
    That's pretty much it. The special tool just looks like a pen with a needle sticking out of it. Here's a pic of where the spray should hit the window http://www.audizine.com/gallery/show...=64273&cat=500
    New Build, 2010 Tiguan. Details to com
    Senior Member Two Rings Jason84's Avatar
    Sep 18 2006
    Green Bay, WI
    That is weird my driver side hits the wiper at a lower point and only sprays up 1/4 way will have to make this adjustment !
    Dec 03 2008
    2018 SQ5
    Thanks everybody! That's just the info I was looking for!
    JR
    Senior Member Three Rings A4-Wookie's Avatar
    Mar 27 2011
    2015 Audi Q7
    209, Ca
    Quote Originally Posted by Heavy Fluid View Post
    Mine too! Rofl. Im pretty sure I've "made it rain" on the hwy a few times..
    2015 Audi Q7
    2013 Audi A6
    2006 Audi A4 Quattro - Stolen and totaled 7/9/2012
    Jun 27 2011
    Quote Originally Posted by A4-Wookie View Post
    My buddy had a really old (like 80s vintage) suburban in HS and he wrenched the passenger windshield sprayer so it sprayed out horizontally at the car next to him. It was awesome.
    Man we were pricks back then...
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Mar 27 2011
    2015 Audi Q7
    209, Ca
    I thought about doing that hundreds of times!! haha. Nothing like shutting up some ricer reving at a light!
    2015 Audi Q7
    2013 Audi A6
    Jun 27 2011
    It was especially good if their window was open...
    -CP
    2017 Q7 3.0t
    Veteran Member Four Rings vbrad26's Avatar
    Oct 17 2009
    MK7 VW GTI
    St. Pete, FL
    these thinks are a bitch to adjust just right
    or maybe i was just having bad luck lol
    Sep 06 2011
    Harrisburg, Pa
    It can be a little annoying to get it the way you want it
    Veteran Member Four Rings papadelogan's Avatar
    Jul 31 2011
    1999 F250 7.3 Powerstroke
    Gulf Coast of Florida
    Install a secondary pump & reservoir with a separate button, kinda like a methanol kit. Fill it with something non-toxic or staining and have some fun....
    2013 Phantom Black A5 P+ Cabriolet (2.0T quattro) mods4cars, mesh grill, gunmetal VMR 701, HFC "Boudica"
    2007 Ibis White B7 A4 Ti Avant 6MT quattro JHM Stage 2, HFC, Milltek CatBack, GFB DV+ "the YETI" sold
    2005.5 Black B7 A4 6MT quattro sold
    Jun 27 2011
    Quote Originally Posted by papadelogan View Post
    I bet you could tweak one of the headlight washers. Not sure if the spray can travel enough distance though...
    -CP
    2017 Q7 3.0t
    Sep 06 2011
    Harrisburg, Pa
    A friend of mine used to have a jet behind his VW emblem. He would always get people by askin them to lift his hood up when we were at shows. Pretty funny as long as you weren't the one walking around looking like you pissed yourself
    Established Member Two Rings mr larry's Avatar
    Feb 14 2011
    B7 A4 2.0T 6MT Quattro, BMW E82 128i Coupe
    South FL
    Quote Originally Posted by bman005 View Post
    Maybe this is too anal but anyone know what the a, b, c, d measurements are supposed to be?
    Sep 06 2011
    Harrisburg, Pa
    Quote Originally Posted by mr larry View Post
    The adjustment dimensions indicate the values for a moving vehicle, i.e. the spray from the nozzles is slightly offset when the vehicle is stationary.
    – Use water-soluble pen to mark the four points on windshield:
    l Dimension -a- = 250 ... 275 mm
    l Dimension -b- = 465 ... 490 mm
    l Dimension -c- = 270 … 415 mm
    l Dimension -d- = 140 ... 225 mm
    – Align individual washer nozzles with these points using adjusting tool.
    Copied and Pasted from ELSA Web
    Feb 25 2011
    Seacoast NH
    A friend of mine used to have his passenger one aimed way, way too high up, so it would easily hit whatever car that was tailgating him.
    Feb 14 2011
    South FL
    A+ post, would read again
    Dec 03 2008
    2018 SQ5
    That is some really great info bman. What is your job?
    JR
    Jul 25 2010
    Spare engines!
    Denver, Colorado
    Quote Originally Posted by wildcat333 View Post
    Genius! I'm doing it!
    Jul 12 2010
    848 Corse, SQ5
    washington dc area
    lol awesome! mine need to be spread out more i think. just to be clear that's where they should spray when you're stationary, right?
    Sep 02 2008
    Boonies VA
    You can also retrofit the Passat sprayer nozzles, which have a much better spray pattern to them. More of a mist that covers the windshield, instead of the jet of water. There is a thread about it on here somewhere.
    White Wagon
    Dec 03 2008
    2018 SQ5
    Quote Originally Posted by naiku View Post
    I remember that now that you mention it, from a long while ago.
    JR
    Senior Member Three Rings GAIC Husky's Avatar
    Nov 24 2009
    NW Chicago
    THIS is the thread about doing the conversion.
    Revo Stage II - 034 HFC - 034 IH - 034 SD mounts - AWE FMIC - B&B Exhaust - Q5 BBK - RS4 RSB - GFB DV+ - 42DD Catch Can - 35% tint - Podi Boost Gauage
    Sep 06 2011
    Harrisburg, Pa
    JR
    I'm a Tech (Mostly VW, but I spent 4 years in a dealer that also had audi and Porsche) I work at a VW dealer right now but we get plently of Audi work because we're $40 an hour cheaper on labor than the local Audi Dealer. Since I have ELSA access I get tons of info
    Dec 03 2008
    2018 SQ5
    Good good stuff. I knew you knew your shit, just didn't know why.
    JR
    Sep 06 2011
    Harrisburg, Pa
    JR
    Thanks, If you ever need any kind of repair info just let me know
    Dec 03 2008
    2018 SQ5
    Thank you sir!
    JR
