since vwvortex is dead or no one knows the answer, i figured i'd come here.
I have a 2002 gti 1.8t 108 k miles ( i know its a vw, but they share many parts with the TT) forge tip,3"dp to 2.5 magnaflow catback,forge splitter dv, unitronic stage 1+.
awp engine code. stock ko3s.
would an exhaust leak cause rough idle? possible lean condition?
i'm notorious for snapping my dogbone mount bolt. this is the fourth time it snapped. I think my new issue is related to it.
last night the bolt snapped while driving home. i was 1/4 mile (roughly, but probably less than that). from home so i drove it home. I was unable to get the bolt out before sunset today and i don't have a garage to work on it in, so i called it a day...tommorow i will do further work.
anyway..the car is idling very roughly. vacuum fluctuates between 5-10 hg but when held at a constant rpm (ex. 2200) the vacuum reads at 19-20 hg. i didnt step on it on the drive home so i don't know if boost is normal.
however, while under the car today, i noticed my flexpipe is well...very flexible (3" dp to 2.5" magnaflow catback) i think it may have become damaged as the exhaust makes a very loud crackling/popping sound upon reving, leading me to believe its a possible exhaust leak.
i checked the vacuum lines from the dv to the mani (how i have mine set up) and the one for the fpr and they look to be fine. where else should i look for vacuum leaks (common places of leakage)?
also, does this sound like a vaccuum leak, exhaust leak, or something else. obv the broken mount caused the engine to shift. so i think its very likely that its an exhaust leak, but how would that affect vacuum?
also turbo makes a whining noise under vacuum only while in gear..probably the turbo exhaust housing..also when the mount is bolted where it should be, it does not do this.
footnotes:
-dogbone mount bolt snapped
-rough idle
-flex pipe seems to be broken
thanks in advance for any insight on what could be the problem.
