Results 1 to 20 of 20
    Sep 21 2005
    2010 B8 A4 Qt
    B8 A4 front Brake Pads - help needed!
    Hi AZ members,
    When I took my B8 A4 to the dealership today, they told me that the brake pads are worn out and need to be replaced.
    As they they quoted me $295 for parts and labor, I would like to replace the pads by myself as I have changed brakes and rotors numerous times.
    However, it seems like our B8 model has electric ebrake that I might need to use vag-com tool to release the caliper.
    While I did search throughout the forum, some says that you need to use vag-com tool to release the rear calipers but doesn't say anything about front brakes.
    Are the front brake pads as simple as working on regular cars that do not have electric ebrake? meaing can I simply use C-clamp to compress and open the calipers and swap out the brake pads?
    It seems like not many people on the forum have done brake pad job.
    Thank you in advance.
    current: 2010 Audi A4 2.0T - Blesk 5000K D3S bulbs, LED interiors, Blesk 3000K HID fogs, Blesk LED festoon on license plates, carbon fiber wrapped roof, + more upgrades may be on the way upon approval from the boss (wify)
    past: 99' Audi A4 2.8, 03' B6 A4, 2009 IS250, ACURA TL-S, 240SX, + 13 more...
    Veteran Member Three Rings ddun's Avatar
    Jun 06 2009
    Stanton, CA
    The fronts is nothing special, c-clamp is all you need
    Deactivated Two Rings
    Aug 19 2011
    1998 Audi A4, Quattro, 2.8/30v, Tip; 2001.5 VW Passat GLS, 2.8/30v, 5spd, w/Unitronic
    Groton, CT
    Here is all I was able to find after I did a little searching:
    Couldn't find much info on any of the Audi related forums on the B8 A4 brakes. What I would recommend to do would send a PM to the OP of the thread linked above. Good luck on your search, and let us know how you make out!
    Mar 02 2007
    Fresno, CA
    The parking brake is attached to the rear only, so yes... the fronts are more straight forward. That being said, both times I've had my rear pads and rotors replaced the tech confirmed that Vag Com was not necessary and he showed me a hand tool he used to manually release it.
    Mar 14 2007
    09 A4 2.0 6MT AWE Exhaust&FMIC
    New York, NY
    From RossTech regarding the rears...
    http://www.ross-tech.net/vag-com/adv...akeTechTip.pdf
    Mar 02 2007
    Fresno, CA
    Quote Originally Posted by JasonR View Post
    That works too, but not necessarily required, apparently.
    Sep 21 2005
    2010 B8 A4 Qt
    cool! Thanks for your help!
    Now, I am trying to decide to go either Hawk HPS or Centric posi-quiet pads.
    Which ones would you recommend?
    I usually used EBC green stuff on my other cars before but it seems like they only have red stuff for the B8.
    Mar 02 2007
    Fresno, CA
    Never used Hawk but love my PQ's.
    Established Member Two Rings uberwgn's Avatar
    Mar 29 2011
    '06 A6 Avant, 2015 Q5
    Boston suburbs
    Quote Originally Posted by akinaboy View Post
    I fitted the Centric Posi Quiets (part number begins with 104.xxxx, indicates semi-metallic) to my '11 A4 a couple weeks ago....was getting tired of the sub-standard braking capability of the OE ceramics. In fact, I had them fitted all around on our A6 a couple weeks before that. Very nice pad, much better initial bite. Some dust, but nothing like a traditional OE German pad. Seems to be a very good solution, recommended by someone over on AW forum.
    The front brake pad changeout is pretty straightforward on this car.
    '06 A6Q Avant | '11 A4Q | '15 Q5
    Senior Member Two Rings B8SlineNate's Avatar
    Mar 15 2010
    Northern California
    what is this hand tool you speak of? would a regular set of brake piston retractors work?
    2010 B8 S-Line Avant Prestige w/Driver Assist
    Active Member One Ring psych's Avatar
    Sep 05 2014
    2010 A4 Quattro
    Hannibal, Missouri
    I am getting ready to do this myself, does anyone know if you need 1 or 2 pad wear sensors when replacing the front pads? I am guessing 2, one for each side. Thanks.
    Veteran Member Four Rings booost's Avatar
    Jul 17 2008
    '12 VW Beetle Turbo DSG, a boat
    Quote Originally Posted by psych View Post
    There is only 1 on the driver's side.
    Click: B8 Quartz Grey Metallic A4 2.0T quattro | 18" Peelers et35| APR stage 1 | aFe | eurocode | H&R | 3.0 TDI FMIC | PowerStop | PODI
    Sold: B5 Silver A4 1.8T Quattro 5MT GIAC KO4 | B5 Santorin Blue A4 2.8 Quattro 5MT | B6 Caribic Blue A4 3.0 cabrio
    Sep 05 2014
    2010 A4 Quattro
    Hannibal, Missouri
    Beautiful, thank you.
    May 07 2014
    Where are you ordering the pad wear sensor?
    Jul 17 2008
    Quote Originally Posted by zokissima View Post
    Can't beat Rockauto
    Sent from my iPhone 6 using Tapatalk
    Sep 05 2014
    2010 A4 Quattro
    Hannibal, Missouri
    Well... my local part store carries them for $10, I have a feeling I "shouldn't do that", but its cheap, comes with a warranty and I'm poor until payday and need to get this done while the weather is dry here.
    -Do you ever feel like you bought someone else's problems?-
    2010 Audi A4 Quattro - 6 speed manual
    Veteran Member Three Rings gunsmoker's Avatar
    Oct 24 2011
    Mansfield,MA
    Yes, you should. It's just a wire loop, not really a sensor.
    2011 A4 2.0TFSI Quattro 6MT, Premium+, 18" Sport Package, Ice Silver, Light Grey, Dark Walnut, AWE Exhaust, STaSIS ECU Tune, Deval CF Splitter, aFe Pro Dry S Filter, ECode Turbo Inlet Hose, Alu Kreuz, Osir CF Valance, R8 Coil Packs, ECS Two-piece S4 Rotors, H&R Rear Sway Bar, 034 Trans Mount, RS5 Pedals, Ultra Racing Strut Bar
    May 07 2014
    I didn't even realize that we had to replace these when doing the front pads/rotors.
    Do you have a part number by any chance?
    Jul 17 2008
    You may not need to replace it but mine had completely disintegrated when I pulled it off so I'm glad I got a replacement - since it's cheap you might as well. OEM part # is 8K0615121.
    May 07 2014
    Thanks Boost!
