Results 1 to 7 of 7
    Senior Member Three Rings a3s-line's Avatar
    Nov 25 2008
    A4 B7 1.8T FWD
    Athens,Greece
    Suspension question
    Hi mates!
    I need some feedback on my question.I have a B7 1.8t stage 1+ with OEM s-line lowering springs and non sport shocks (I know it is a mistake).I like to replace the shocks because the car seems a bit floating after 95.000 kms.I don't like to change the springs since they are perfect for the Greek road condition (-20mm from the standard suspension).Any suggestions about the shocks? I don't like to have a bumpy drive, but I like to upgrade my suspension a bit.What do you suggest? Bilstein B8 shocks or something else? I need something to cooperate with the OEM lowering springs.
    TIA
    A4 B7 1.8T FWD, OEM Black out grill conversion,, red calipers, s-line springs, slottted and cross drilled front rotors (galfer), tuning brake pads (galfer), stainless steel brake lines, RS4 pedals and footrest,OEM TT MKII 8,5X17 wheels,235/45/17 tyres, VW touareg flashlight instead of lighter, cupra R lip, black mirror covers, ECU Flash custom stage 1+, TT/S3 injectors, Boost Brothers FMIC,turbo back exhaust,200 cpsi magnaflow HFC,Forge 006, HID 6000K & fogs 6000K
    Veteran Member Four Rings elwigglero's Avatar
    Sep 04 2008
    B7 S4 DTM, B7 A4 2.0T Ti
    Lansdale, PA
    Why not the oem s-line shocks then? Should be plenty of people that upgraded suspension who'd be willing to let their old set go.
    Justin
    DTM S4 Sprint Blue
    Oct 02 2006
    Wadsworth,OH
    Another alternative would be either Koni or Bilstein! We have both available below!
    Click HERE to order or for more information.
    Jason
    Nov 25 2008
    A4 B7 1.8T FWD
    Athens,Greece
    thanks for the quick replies! Some people say that FSD 's are superior because they change the ride according to the driving style.Is it true? others believe that Bilstein 's are the best.I am confused.I don't want a bumpy ride and I like to maintain the current ride height.
    Veteran Member Four Rings Stewy's Avatar
    Jan 24 2010
    2007 Audi A4 S-Line 6MT, 2012 F-150 Platinum 6.2L, 2003 Suzuki GSX-R750
    Vancouver, B.C., Canada
    +1 for Bilstein's if you're going aftermarket. If you're looking to save some money, OEM S-line shocks would work as well (noted above). Too bad you're in Greece, I have mine sitting in the garage. You should have no problem finding a used set.
    2007 Audi A4 S-Line 2.0T FSI - APR Stage III GT2871R, APR HPFP, Carbonio intake, AWE FMIC, BSH CC / PCV delete, OEM "D" DV, APR downpipe, Neuspeed exhaust, H&R coils, ECS Stage 4 BBK, JHM 4:1 center diff, Neuspeed short shift, RS4 rear sway bar, Neuspeed snub mount, Defi MeterBF gauges with Defi-Link, Vag'd, de-badged, black rear valence, Cupra R lip, Huper Optik tint, RS4 grille, EU amber tails, 19" Hartmann RS4 replicas with H&R Trak+ spacers
    Nov 25 2008
    A4 B7 1.8T FWD
    Athens,Greece
    do you ship them?how many miles on them?
    Senior Member Two Rings QuattroTi's Avatar
    Aug 21 2011
    Yamaha 50th Anniversary R6
    South Florida
    I have the koni sport (yellow) and love them. adjusted them to 1/4 turn stiff and they perform great and the ride is comfortable.
