Results 1 to 15 of 15
    Veteran Member Four Rings jerseybrian's Avatar
    Jul 15 2011
    2008 Audi A4 2.0T Quattro QG 6spd
    Boynton Beach, FL
    OEM HID Ballast model #?
    Hi folks, just wondering if someone could confirm which model OEM Ballast the Bi-xenon projectors have from factory.
    Are they the Valeo LAD5GL Ballasts?
    REVO 2+ | VAST Meth | RAI HFC and 3" DP | Milltek S4 Exhaust | Autotech HPFP | 145bar PRV | JHM STS | BFI knob | 034 SD MM | ECS RA4 LWFW | ACT RS4 HDSS | QTP Cutout | Forge DV | APR Snub | Deval RS Front | Votexx 3pc wing | OEM Euro Bi-Xenons | Bilstein HD Shocks & ECS sleeves | Eibachs | RS4 RSB | S4 F&R Brakes | ECS S4 Slotted | Hawk HPS | ECS SS lines | FK LED Tails | CF Dipped Diffuser | Innovate LC1 | IE Billet | THULE | PODI
    Jan 01 2011
    Selden
    Dipped headlight problem? Rapid flickering?
    Veteran Member Four Rings A-BlacK_MambA-4's Avatar
    Jan 22 2011
    '05.5 A4 2.0T Tip Revo Stage 2; Wifes 2013 Chevy Cruze
    Ohio
    I'm sure Phil will chime in shortly, but we need a little bit more info... OEM Adaptive and Non-adaptive take different ballasts and honestly we would need your headlight model number to be able to tell for certain...
    When I pieced together my Bi-xenons I found my adaptive ballasts on eBay for $220 shipped..
    Part # 8E0 941 329 A
    -JOEL
    The Real Black Mamba
    Jul 15 2011
    Boynton Beach, FL
    They are OEM Bi-xenons with the adaptive cornering function (but not using that function until I can afford the kit).
    I guess I'll chime back in when I get the headlights in the mail!
    However, can both ballasts be ordered from MOPAR instead of Audi? I've heard that buying from MOPAR is considerably cheaper.
    Jan 22 2011
    Ohio
    Unfortunately, even if you decide not to use the adaptive/cornering function you will have to use an OEM Adaptive ballast. The adaptive and non-adaptive OEM headlights require different ballasts. Now, as far as the Kufatec harness you can order the one that doesn't provide the wires for the adaptive function and you will be fine(it is what I did during my recent upgrade). See this picture from another thread where someone asked the same type question and Jens (lowestA4) answered it. As you can see the Adaptive ballast has more pins and if those are not utilized you will throw codes all over the place. Hope this helps...
    -JOEL
    Jul 15 2011
    Boynton Beach, FL
    Quote Originally Posted by A-BlacK_MambA-4 View Post
    Are the Ballasts for the adaptive/cornering headlights available through MOPAR as well?
    Jan 22 2011
    Ohio
    I believe the ballasts you are referring to were only a cheaper replacement for the B6's, I do not believe they will work with the B7 headlights..Regardless of adaptive or not.. I truly believe your only option is OEM, which is the best route to go anyways.. Just ensures you don't throw any codes or fitment issues.
    -JOEL
    Jul 15 2011
    Boynton Beach, FL
    Thanks for the info. $220 shipped is one hell of a deal! I'm seeing one of the ballasts sold for $175 on ebay right now! I'll see what I can get them for from Audi with my shop's wholesale price.
    Veteran Member Four Rings groundround's Avatar
    Jun 19 2009
    17 ram 1500
    Hartford CT
    well looks like we both bought the same lights from the same guy!!
    and we have been buying al the parts we need for the lights we are not going to get!
    Dont buy anything from tselod05!
    Oct 02 2006
    Wadsworth,OH
    We have both Genuine VW/Audi style ballasts available below!
    Click HERE to order or for more information.
    Jason
    Jun 19 2009
    17 ram 1500
    Hartford CT
    Jason
    Are they for the adaptive type?
    Oct 02 2006
    Wadsworth,OH
    Quote Originally Posted by groundround View Post
    I believe that's what Automatic Headlight Range Control is. We also have the option for cars that have Automatic Dynamic Headlight Range Control With Cornering Light Circuit (AFS).
    If there's something you need but isn't listed you can PM me your VIN and I can pull the exact part number which came on your car from the factory ensuring you get the correct one.
    Jason
    Jul 15 2011
    Boynton Beach, FL
    He had 2 sets :) So I'm still waiting to get them by the end of this week.
    $300 for each ballast!! damn... I know I can get them for cheap on ebay (new) but I'm gonna check with Audi and my shop's wholesale discount first.
    Brian
    Jun 19 2009
    17 ram 1500
    Hartford CT
    Quote Originally Posted by jerseybrian View Post
    Brian
    Yea just found it strange he has 2 sets laying around, but only did a swap with his stock headlights. Hope they are both in like new condition and working order.
    Jul 15 2011
    Boynton Beach, FL
    same here lol
