Results 1 to 40 of 48
    Veteran Member Four Rings rs4 tony's Avatar
    Sep 13 2010
    Long Island, NY
    Anyone ever notice there speedometer is off?
    Anyone experience this?
    2007 Audi Rs4 Daytona Pearl/Carbon Fiber Trim/Navi/Lambo Verde Ithaca Pearl Painted Calipers/H&R Springs/JHM 93 Octane Tune/K&n Drop In/Apikol Red Rear Diff. Mount/StopTech S.S. Lines/Michelin Super Sports 275-30-19/H&R 8mm Front Spacers/MTM 10mm Rear Spacers/JHM Intake Manifold Spacers/SPEC Stage 3+ with LW Steel FW/JHMCatless Downpipes/JHM 2.75" Non-res Catback Exhaust/JHM Lightweight Front & Rear Rotors/034 Torque Mount/
    Instagram: @rs4_tony
    Veteran Member Four Rings dparm's Avatar
    Apr 24 2009
    Frisco, TX
    It becomes increasingly inaccurate as you go faster. From what I have seen on various GPS units, it's a few mph off above 120mph.
    now: 2021 Mercedes AMG C63 S, 2017 Chevrolet Corvette Grand Sport
    past: 2005 Audi S4, 2011 Audi S4
    Veteran Member Four Rings Turbwhistle's Avatar
    Jan 02 2011
    Slower or faster?
    Chris|1999.5 B5 A4 Avant 1.8TQM Brilliant black|Flickr
    PSS9 | StopTech | Fikse | Challenge Motorwerks | EPL
    Sep 13 2010
    Long Island, NY
    I know when I do 80mph on the speedo, my friends car next to me does 75. Both traveling at the same speed. Weird. Maybe because my rolling diameter of my tires throughs it off? 275/30/19's
    Sep 13 2010
    Long Island, NY
    Quote Originally Posted by Turbwhistle View Post
    Slower or faster?
    Well I am 5mph slower then the speedo when it's above 50mph. For me to do 40 mph on local roads I have to do 43 on the speedometer or people pass me for going to slow.
    Jan 30 2007
    2014 Lexus IS350, 1988 Porsche 944, 2008 Porsche Boxster, 2001 Audi TT Quattro
    Greenville, SC
    speedo says 60. actual is 58 for me.
    Tom
    2014 Lexus IS350 (present), 1988 Porsche 944 (present), 2008 Porsche Boxster (present), 2001 Audi TT Quattro (present), 2006 Audi S4 (past), 1998 Audi A4 (past), 1975 Audi Fox (past)
    Sep 13 2010
    Long Island, NY
    Any way to fix this issue? Recalibrate it?
    Sep 13 2008
    Western Chicago Burbs
    Yeah my speedo is a few mph optimistic.
    Active Member One Ring Audeeznuts's Avatar
    Feb 14 2011
    MASS
    Tires size should make a difference. Not sure if it would be noticable enough since its probably not a drastic increase/decrease in size.
    If It Doesn't Have Tits, Trigger, Or A Throttle I'm Basically Not Interested
    Big Trucks Fast Cars
    Sep 13 2010
    Long Island, NY
    Yea true it's a slight slight decrease in rolling diameter.
    Senior Member Two Rings Petes4's Avatar
    May 20 2008
    Boston Ma
    At about 75mph my speedo is about 6 mph optimistic.....the dealer said that "they had never seen this before and that they didnt know what was wrong".
    JHM 93, H&R Koni setup, Magnaflow exhaust, APR DPs, JHM LW Rotors, Porsche Calipers
    Sep 13 2010
    Long Island, NY
    I hate problems that come back unanswered. HATE
    Oct 12 2010
    Keswick, Virginia
    Tony take a look here. I remembered reading about this, and just found this... Some reading in all of the posts
    http://forums.quattroworld.com/rs4b7/msgs/36280.phtml
    Sep 13 2010
    Long Island, NY
    Good find. Seems like its a common problem in the rs4's.
    Established Member Two Rings ringsroc's Avatar
    May 11 2011
    2006 Audi S4, Tip, Brilliant Red.
    Germantown, MD
    It was a well known problem with the MKV VW Jetta I had. Several reasons givin.
    http://tech.bentleypublishers.com/th...rt=0&tstart=40
    Here is a thread from the Bentley Publishers site that discussed it fairly well.
    I am assuming that Audi and VW share the same philosophy.
    2007 VW Jetta 2.5- SOLD
    2006 Audi S4 Brilliant Red, Platinum interior.
    Veteran Member Four Rings seanj130's Avatar
    Sep 05 2008
    Pittsford, NY
    Keeep it, you think your doing 80mph on the highway with your buddies.. they think you are badass, but you are really doing 75mph... Only 10 over and won't be bothered by state troopers shooting Lidar..
    Best regards,
    Sean.
    Paying someone to install parts and bragging about it being fast, is like watching someone
    bang your wife and being proud to raise their kids.
    Sep 13 2010
    Long Island, NY
    Quote Originally Posted by seanj130 View Post
    Lmao. Bad ass. Look at me! =P
    Registered Member Two Rings
    Mar 02 2011
    F-14 Tomcat
    Philly/DC
    the speedometer's accuracy is determined by a pre-set fixed setting based on wheel diameter. It measures how many times the axle is rotating - or the revolutions per second (Hz).
    Ok - some math...
    We'll assume the car is set for a 17" diameter tire.
    60mph = 1,056 inches/second
    Circumference of 17" wheel = 53.38 inches
    Revolutions per Second = 1,056 inches/second * (1/53.38 inches) = 19.78 Hz - This is the setting on the computer. So if the axle is spinning at 19.78 times per second, it will register on the speedometer at 60mph.
    Now, if you put 18" tires on that vehicle, it is still checking for the Hz of the axle (19.78), however, since it's a bigger tire, it travels further each revolution which means you'll be going faster at the same constant 19.78 revolutions per second.
    Circumference of a 18" wheel = 56.52 inches
    Actual Speed at pre-set Rev/Sec = 56.52 inches * 19.78 rev/sec = 1117.9 inches/sec = 63.5mph
    For a 19" tire:
    C = 59.66 inches
    Actual speed = 67mph
    Long story short, the factory determines the pre-set constant and as you (the customer) change tire sizes, it makes the speedometer readings inaccurate. If the factory sets a smaller diameter than the actual tire size, you'll be going faster than what is shown on the speedometer. If the factory sets a larger diameter than the actual tire size, you'll be going slower than what is shown on the speedometer.
    Feb 15 2007
    A lot of vehicles have around a 10% speed inaccuracy. In the US, speedo's read 5-10% higher than they actually should. This is a US "safety" feature. I had an article on this, but i've lost it when my last comp crashed. Many of the radar readouts are also inaccurate by about 5-10% anyway. Also, This can be lessened or strengthened by changing tire/wheel size. GPS seems like the best way to monitor real speed, besides knowing actual mileage and dividing it by the time.
    2007 Audi RS4 - Daytona Grey - Original Owner
    1957 MG MGA 1800 - Austin Healey Spruce Green
    2020 Mercedes-Benz GLC 63 AMG - designo Cardinal Red
    2023 Mini Cooper SE - White Silver Metallic
    Sep 13 2010
    Long Island, NY
    I see. I see. I see it as a good thing tho. Says 80 I'm doing 75* ish. No biggie
    Dec 05 2006
    So. Cal.
    It's "Their" not "There". You guys are an embarrassment to the US education system.
    Sep 13 2008
    It's U.S.
    Veteran Member Four Rings mbgt72's Avatar
    May 18 2008
    2003 Jeep Wrangler
    Nashville TN
    Quote Originally Posted by 2012S4Guy View Post
    Ok - some math...
    For a 19" tire:
    C = 59.66 inches
    Yes, I remember seeing a lot of B7 RS4's from the factory with 17" TIRES back in the day. . . .
    Sounds like we have another AurtherPE up in here!
    Current: 996TT
    Sold but not forgotten: 2005.5 S4 MT6 l JHM Parts: Stg 1 S/C, LTH, IM, SS Trio, LW Front Rotors, LWFW, Stg IV clutch, 4:1 Diff, Stern Motor Mounts, Snub/Trans/Diff Mounts, F.I.Exhaust l H&R C.O. 24.75" G-F, 034 Adj UCA's, H-Sport RS4 Rear Sway l Hawk HPS Pads, SS lines & SuperBlue l Fly'sV4 LEDs l 15% Tint, 50% Front l VMR V710 GM 19" & Enkie RPF01's l JL 10W7, Focal Components l V1 Mirror Display l
    Veteran Member Four Rings S4Per's Avatar
    Feb 17 2004
    2013 Audi S6
    Just spoke to my dealer about this last week. He says they discussed with Audi several years back; Audi wants to make sure that no if's and's or but's, you'll never be going faster than the speedo tells you. There is no way to have this adjusted (mine's off by about 5mph).
    2013 Addict::S6 (Build) // UNITED MOTORSPORT by AMD STG III | Milltek DP's and Valvesonic exhaust | 200 CPSI custom cats | AWE intake | Arc's, Helix, Morel's for sound
    2018 Q7 3.0T Prestige | Glacier White Metallic | Titanium Black Optic | Adaptive chassis | Drivers Assistance | Tow | Cold Weather
    Never forgotten:
    2008 Addict::RS4 (Build)
    2002 S4 Stage 3 Tip
    Dec 05 2006
    So. Cal.
    Quote Originally Posted by B6JoeS4 View Post
    It's U.S.
    Thanks, I would have never known to place a period after the "U" and the "S" to denote that I was trying to abbreviate United States.
    Oct 11 2007
    Suburbia
    Quote Originally Posted by mbgt72 View Post
    I was thinking the exact same thing.
    12' R8 Daytona/CF V10 6MT
    ~VF750 supercharged~Avior Ti non-res~GT coilovers~Girodiscs~Wingbacks~CF S-wheel~
    ~Maxton Aero bits~
    07' RS4 Daytona/Panda
    ~Jackal tune~Zinram 70mm DPs~JHM res catback~Bilstein PSS9s~Girodiscs~JHM shifter~
    01' A4 Silver 1.8T Avant 5MT
    ~Motoza Ko4 tune~550cc injectors~Apikol SMIC~3" testpipe~ST coilovers~18" Avuses~
    Sep 13 2010
    Long Island, NY
    Quote Originally Posted by WinterRunner View Post
    17's fit over the rotors/calipers?!?!
    Veteran Member Four Rings PetrolDave's Avatar
    Jan 14 2007
    SOLD: 2006 B7 RS4 Avant
    Hampshire, U.K.
    Speedos overreading isn't a problem - it's a legal requirement!
    An E.E.C. decree of 25 June 1976, regulates the speed displayed by the speedometer in relation to the actual speed travelled.
    This decree stipulates:
    - The speed indicated by a speedometer must never be lower than the actual vehicle speed.
    - Between the speed displayed «SD» and the speed travelled «ST», there must always be the following relationship:
    ST < SD < 1.10 ST + 4 Kph
    For Example: For an actual speed of 100 Kph the speed displayed by the speedometer may be between 100 and 114 Kph.
    Mar 02 2011
    F-14 Tomcat
    Philly/DC
    haha wow, tough crowd. i was just giving a simple example of how 1-2" could give a noticeable change! don't get your panties all in a bunch over it!
    Veteran Member Four Rings NY07RS4's Avatar
    Aug 14 2009
    RS4
    Every vehicle I have ever owned has had a speedometer reading higher than the actual speed. When GPS units became common I started doing comparisons for fun. Motorcycle, car, SUV, quad - all read higher than actual speed according to GPS. The boat I had was the worst of the bunch, it was way off.
    RS4 : K&N : HPS & Stop Tech : DTH Cover : 30% Tint : Tubi Rumore (SOLD!) : Audi Sport Rubber Mats : H-Sport Sways F/R : Stern UCA's : JHM L/W FR & RR : JHM I/M Spacers : JHM LWCP : JHM FULL 2.75" : JHM 3R & LWFW : JHM Tune : JHM Cross Rod : JHM SS : 034 MAF & USM's : 034 Trans Mount : USP Slave & SS Line : Ohlins SL C/O : Stop Tech SS : Apikol Red Diff Mount : HOEN H11 Fogs : LED : MTM 10MM : F Plate Delete : CC Mod
    Veteran Member Four Rings A4A4A4's Avatar
    Jun 02 2008
    Victoria, Canada
    1-2" change in wheel size does not equal 1-2" increase in rolling diameter, it's the choice in tire size that makes that difference.
    You can have a 20" wheel that has a smaller rolling diameter smaller than a 15" wheel, it all depends on sidewall size.
    -Cam
    New: MK6 Volkswagen GTI
    Old: E92 BMW 335i
    Older: B7 Audi A4 2.0T Quattro
    Veteran Member Four Rings audikid66's Avatar
    Jun 13 2007
    Belmar,NJ
    I proved this due to the fact I'm pretty sure I topped out my car my Speedo said 160 and I'm pretty sure our cars are stock capped at 155. Correct me if i'm wrong
    Current car: Stage 3+ 2002 Audi allroad 6 speed
    Past cars:
    imola b6 avant 5spd/URS4 avant Big turbo aan/B7 RS4/k04 b5 Avant /BAT B5 Rally car/B6 Ultrasport/TT / multiple B5 A4 /5 speed ford f-150
    Veteran Member Four Rings jareds941's Avatar
    Jan 12 2010
    Portland OR
    Quote Originally Posted by audikid66 View Post
    Oh that proves it fo sho!
    Mine: 2019 Ford F150 / 2004 E46 M3 Track Car
    Hers: 2016 Daytona Gray SQ5
    Previous:
    2019 Daytona Gray S4
    2014 Glacier White S4
    2014 Glacier White SQ5
    2008 Daytona Gray RS4
    Sep 13 2010
    Long Island, NY
    That's what another rs4 member told me
    Active Member Four Rings BenSti's Avatar
    Nov 03 2010
    Cupertino, CA
    I checked my car against GPS, at 192mph on speedo, GPS said 188mph, pretty damn good in my book...
    If you access engineering mode on the RNS-E, it has a page to view actual GPS speed, it also has another page which seems to be calibrating the tire diameter by comparing the wheel speed sensors with GPS speed. I know many other cars actively calibrate the speedometer, so it is possible ours does it too.
    Jun 14 2005
    Anaheim, CA
    What year is your car?
    Brandon @ VMR Wheels
    Sep 13 2010
    Long Island, NY
    Mine is a 07. How do u access the engineering screen?
    Jun 14 2005
    Anaheim, CA
    The tires you're running now has a 2.04% diameter difference from your stock tires, meaning that your speedometer will appear 2.089% MPH too fast. For example, if you're driving at 60 MPH, your speedometer will read 61.2 MPH.
    Nov 03 2010
    Cupertino, CA
    I forget the exact key stroke needed, I think you press the Nav button, hold down the upper left button by the knob for 5 seconds, release and hold down the upper right until the screen changes. It takes a couple tries to get perfected.
    Sep 13 2010
    Long Island, NY
    Quote Originally Posted by VMRWheels View Post
    Hmm not sure about that one. I was doing 65 and my buddy next to me did 60
