Page 699 of 702 FirstFirst ... 199599649689697698699700701 ... LastLast
Results 27,921 to 27,960 of 28078
  1. #27921
    Jul 07 2024
    Elk Valley, BC, Canada
    What did you do to your B6 today?
    Bought a breaker bar and 19mm deep socket to replace the oem tire change tool because PO replaced lug bolts with very long studs and bigger nuts. About to go on a 1000km road trip so don't want to get stuck without the ability to change the tire/take the wheel off.
  2. #27922
    Veteran Member Four Rings Akronnnnnnnn's Avatar
    Jun 21 2010
    04 Audi A4 1.8TQ, 90 Camaro RS
    Akron, OH
    some pics of the recent work I've been doing
    full interior LED upgrade(taken from my sedan so I had to pick up new ones for the cargo area):
    replaced rear license plate light housing with mine from my sedan. The one on the avant(2003) was made of metal and completely corroded, while mine from the sedan(2004) was made of plastic and in great shape.
    Painted some front of the engine components while they were off.
    Resprayed the grille surround with plastidip.
    Installed the podi boost gauge and steering column mount
    Getting closer to having this thing on the road!
    -Brian
  3. #27923
    Established Member Two Rings Danisson's Avatar
    Dec 30 2023
    Cluj, Romania
    Smile Old (-ish) cars nightmare...
    It all started yesterday afternoon when the driver's door started to misbehave in a very strange way... so in order to open it first time after unlocking, I had to pull the handle multiple times for the latch to disengage. The electric control was always working so that really bothered me; not to mention that after the first time the door was indeed opening & closing just fine. So my first guess was that the striker plate went out of alignment and I've spent a lot of time adjusting it until the door was sitting flush with the rest of the panels when closed. But after that it was rubbing even worse...
    This morning it came to my head that the door itself needs to be adjusted 'cause it started sagging after all these years. The usual way of taking the fender out (along with half of the car :) was definitely NOT my option so with the help of two washers and a jack did the job quite well. Think it was done ? Nah... the door lock module was still not giving up. After giving all the hinges (from all 4 doors) a good amount of lubricant, cleaning the latch and fiddling around with it it seized up in the lock position while the door was opened. God !
    So... on we go again ! Out with the door card, rain cover foam, (crusty melted brittle af.) door lock cover, door handle, barrel and finally THE DOOR LOCK MODULE itself. (which was all original, 2001 made) Assuming that the electric part of it was fine and the mechanism got stuck into the micro switch; which carved and wore down the rubber insulation of the latch, I took it apart and cleaned it good with a healthy dose of brake cleaner. Lubricated it with some lithium grease, soldered in a brand new micro switch and repaired the rubber onto the latch by melting it. Considering how old and rough the module was moving and looking, the final result really is impressive to say at least; like BRAND NEW !
    So back on the car it went ! Tomorrow I'll apply new adhesive silicone onto the foam, sealing everything up and replacing all the clips on the door card with new ones. Sure I'd keep you updated... (man, what a mess of tools around the house)
    '02 A4 B6 1.8T 5-MT | ECM Tune | Res Delete & 4" Chrome Tips | MTS Technik | USP Front Bumper & Trunk Lid | S4 Door Blades & Sills | 18" ET43 USP Alloys & Continental "SportContact 6" 235/40/ZR18 | Black DEPO E-codes & Smoked Side Markers | Blacked Out Grilles | Glovebox Fridge | Color DIS | Brushed Aluminium Trim | RNS-E PU (mkII) & 6 CD Changer Retrofit and more...
    "Dani"
  4. #27924
    Jul 07 2024
    Finally swapping all the control arms and tie rods, took it for a test drive and it's much better now.
  5. #27925
    Dec 30 2023
    Cluj, Romania
    Talking "The End"
    Hey folks !
    Posting this means that everything is fine with my driver's door (as far as I can tell :) so here we go:
    Cleaned the old adhesive from the entire door and applied some rubber gasket-maker silicone to hold the foam protection (which I managed to patch with some strong 3M Duct Tape) into position and seal it up. After testing all the functions like lock/unlock, windows, mirrors and so on I've decided to replace the AM mirror adjusting switch with an OE one, along with all the door card clips (NEW as well ;) Now it's all aligned and working properly. What a 2 day hassle !
    "Dani"
  6. #27926
    Jul 07 2024
    Mounted an amp in the trunk and rewired all the speakers.
    Bled the brakes, old fluid is very dirty.
  7. #27927
    Veteran Member Three Rings Dr.B6Banter's Avatar
    Sep 26 2017
    B6 A4 1.8T, B8.5 SQ5
    NB, Canada
    Took advantage of my friend's new quickjack lift to bleed the brakes (takes a little longer when the Brembos have 2 bleeders per calliper) and took it to our local racetrack Atlantic Motorsports Park in East Coast Canada. This is my 2nd year of taking the B6 there and slowly the lap times are getting better as I set the car better for grip and get more comfortable driving it on the limit. As it was a fairly warm day I had the boost turned down to a conservative 18psi so it was probably only making 250whp to the rear wheels.
    Link to a clip of one of my better lap times but far from great:
    https://drive.google.com/file/d/1gSv...ew?usp=sharing
    B6 A4 1.8T Nottro 02X 6spd Conversion | GTRS | IE Forged Rods | Suspension/ Subframe Poly Bushings | 18z BBK Front & Back
    B8.5 SQ5 3.0t | JHM 207mm Crank Pulley | IE Dual Pulley Tune & ZF8 TCU Tune | CTS Test Pipes, Downpipes & HX | AWE Touring Exhaust
  8. #27928
    Jul 07 2024
    Changed the cv axle, finally drove it again! Brakes are much tighter after bleeding and steering is great after changing the front end parts.
  9. #27929
    Sep 10 2021
    Pennsylvania
    Quote Originally Posted by Dr.B6Banter View Post
    Hell yeah! Get out there and rip up some pavement!
    Edit: Just watched the clip. Nice job! I loved seeing you push that thing all the way out to the concrete runoff on the second-gear right-hander after the hairpin (top-left of the track... not sure which turn # it is). Also, the little G-Force instrumentation you had there dangling from the rearview mirror was showing us 45 degrees at times, so I think you were probably near 1G lateral--plus, it probably smelled nice if it was an air freshener. Keep it up!
  10. #27930
    Senior Member Two Rings canonball's Avatar
    Apr 20 2011
    Tacoma, WA
    Quote Originally Posted by Gunnarrrrr View Post
    motoza is really the only one doing good custom 1.8 audi tunes these days
    +1
    I don't have much basis for comparison but I've been super happy both with the K04 tune and the stellar customer support at Motoza. 10/10 from me!
  11. #27931
    Jan 10 2022
    Richmond, VA
    If by "today" you mean "over the last week and a half", I tackled the rear coolant flange replacement. Had to wait for parts/tools twice and work in several short periods, but I finally got it done and the cooling system flushed. Seems to be holding up; my heat isn't working but it hasn't worked in the entire time I've had the car so that's not news. In the process of getting everything apart, the lower heater hose and 2 PCV hoses broke, so those got replaced too.
    While I was waiting for parts I also replaced the coil pack connectors, brake light switch, front license plate bracket, and overhead switch panel. So my sunroof works again, which is a bonus.
    2005 A4 Avant Quattro 1.8T USP
    2013 VW Jetta Sportwagen TDI
    1988 Volvo 780 Bertone (project #2)
    1979 Chevy Malibu (project #1)
  12. #27932
    Jul 06 2021
    '03 B6 Quattro 1.8T
    Saint John NB
    Quote Originally Posted by CJM_RVA View Post
    Sounds like you might be doing the heater core in the near future as well.
    Luckily it's a pretty easy job, one of the only cars I know of that the job doesn't involve tearing out the dash for.
  13. #27933
    Veteran Member Three Rings codemode's Avatar
    Sep 01 2019
    EU
    Quote Originally Posted by TobiqueSlang View Post
    I need to do a heater core as well before the winter. Does it matter which brand?
    A4 B6 1.8T Manual FWD 2002
    Painted lowers, USP front
    18'' RS4 ET 35 Replicas
  14. #27934
    Jul 06 2021
    '03 B6 Quattro 1.8T
    Saint John NB
    Quote Originally Posted by codemode View Post
    Not particularly, I think the only real rule of thumb is to make sure whatever you get is all aluminum, avoid anything with plastic tanks. Generally though, cheaper=harder to install for most parts.
  15. #27935
    Veteran Member Four Rings Gunnarrrrr's Avatar
    Mar 25 2015
    cars, wheels, cars with wheels
    Placer County
    nissens all the way for radiator/heater/ac condenser/etc
    not to be confused with the instant ramen company
    B9 SQ5 Mythos X Magma - 034 stg2
    2005 B6 GT2871
    2005 B6 S4 4.2L 6MT
  16. #27936
    Sep 26 2017
    NB, Canada
    Quote Originally Posted by Mike Tries View Post
    Haha thank you, regardless of the times it is a blast to drive there! Will be putting the front axles back in this weekend to help with the drive out of the lower-speed corners. RWD and open diff results in a lot of one-wheel peels and not a whole lot of acceleration lol
    Been following the progress on your wagon, hope you get to take it out soon!
  17. #27937
    Sep 10 2021
    Pennsylvania
    I hope I can get it half-assed together at least for an HPDE this year to shake it down. If not that, then my gosh, I hope there's something on some schedule SOMEWHERE before the race school next Spring. I'd hate for my shakedown run to be at the school.
    I always thought the A4 1.8t was too heavy and low-power to benefit from AWD on dry race tracks, but if you're experiencing traction issues with RWD, then I can't imagine what I was thinking daydreaming about FWD (what I thought of as the easier solution since they made them in FWD). Perhaps I'll rethink my desire for a less draggy drivetrain now that the car weighs less. I want to love the AWD (on the track--I already have fun with it in the snow)!
    So tell me about this front axle pulling stuff... I always thought that to go RWD in our cars, you had to do weird stuff to the transmission--to block the center diff somehow so it didn't just desperately try to spin the front axles and send no torque to the rear. Were you really able to just... remove the front axles and that's it?
  18. #27938
    Dec 30 2023
    Cluj, Romania
    Re-finished my ESP button, coins tray and cup holder faces with some high temperature matte black paint which actually gave it an interesting raspy texture. Also gave up any kind of symbol or text previously written on them as the clean look matches the custom hazard lights switch that I've done some time ago better. Sure I'll edit and upload a picture tomorrow as right now it's very dark outside ;)
    "Dani"
  19. #27939
    Mar 25 2015
    Placer County
    you need to weld the center diff, grab a spare junkyard one and go to town. Also need to either use some front cv flanges or grab those ecs axle delete pieces to keep pressure on the wheel bearings.
    and stock up on spare rear axles, you’ll need them.
    2005 B6 GT2871
    2005 B6 S4 4.2L 6MT
  20. #27940
    Apr 13 2017
    2003 A4 6MTQ 3.0, 2005 A4 FWD 1.8T
    Dallas, Tx
    Repaired the the cd-changer input on my Concert II head unit this week. The Bluetooth input I have uses the cd changer-in port and it hadn't worked for the last year. I pulled the Concert II out and disassembled it and found corrosion on the circuit board from what looks like leaking capacitors. I've been meaning to learn how to fix electronics so I watched some YT videos and learned how to diagnose bad capacitors with an ESR meter. I bought a meter and an assortment of capacitors on Amazon and stumbled my way through the process. I tested probably 100 capacitors on the board, and I probably only found 3 that were bad. I also destroyed a couple de-soldering them, but once I got those replaced and the radio back together, miraculously the changer input worked again.
  21. #27941
    Dec 30 2023
    Cluj, Romania
    Talking BOSE (8E0 035 411 B) added to the mix...
    Hi everybody !
    It's quarter past 9 PM here and I've just had my cup of coffee to somehow "extend" the night after all this adventure ;) Why do I say that ? Well, it was certainly NOT as simple as buying 4 speakers and replacing the ones on the car. Ordering old parts without actually seeing 'em is definitely very risky as you'd see... one came with the magnet separated (glue failed from the transport) and another one had its membrane pierced. Luckily enough I was able to fix both of 'em and have all set of four disassembled, cleaned and treated with silicone spray. Think that was all ? No chance ! So I did remember having some leftover pieces of sound deadening material from doing the bonnet a few months ago and I've decided to use 'em (as a treat) on the front door panels. So on I went cutting and rolling it onto them and man was I impressed ! No more empty plastic bucket sound. While I was at it I chose to replace all the clips with new ones and (re-) do all the wiring harnesses on all four panels. Nice and tight, but still not over ! Cleaned everything up and on with them with hurry 'cause night was setting in.
    And this was just about yesterday :)
    After cleaning some old clips (just in case) I went to bed thinking about all the things I've skipped while putting everything together... just to wake up today and take apart all the panels. This way I was able to fix all the little rust spots, paint 'em, re-do the wiring harnesses on the doors themselves with textile insulating tape (just as the factory did back in the day), re-glued the rain covers, zip tied the wires to be snug and of course replaced some clips which decided to broke after many times prying them off.
    What can I say... happy with the sound, proud of the (pre-) maintenance work and deeply exhausted :)
    "Dani"
  22. #27942
    Mar 25 2015
    Placer County
    interesting.
    I found awhile back that the bose door speakers (non bose are glued) have 4 screws that can be removed and the speaker can be removed from the housing, and these 6.5” Dayton woofers from parts express for $7/ea fit perfectly, with about 3mm of clearance on the rear grille
    2005 B6 GT2871
    2005 B6 S4 4.2L 6MT
  23. #27943
    Mar 12 2013
    Houston, Texas
    interesting.
    .. these 6.5” Dayton woofers from parts express for $7/ea fit perfectly, with about 3mm of clearance on the rear grille
    Sorry to bother you but any way to look up your past orders and post the part# for those? I'm looking for a nice 3-way set but in the meantime those look like perfect drop-ins. I'll order them today if they are still available.
  24. #27944
    Mar 25 2015
    Placer County
    Quote Originally Posted by ye1low View Post
    backordered for 2 weeks:
    https://www.parts-express.com/6-1-2-...-4-Ohm-299-609
    they’re actually the drivers from the dayton b652
    2005 B6 GT2871
    2005 B6 S4 4.2L 6MT
  25. #27945
    Apr 13 2017
    Dallas, Tx
    Does anyone know the ohms of the original Bose speakers? My experience with Bose is that they use weird ohm stuff, and using a speaker with higher impedance could overdrive the amp.
  26. #27946
    Mar 25 2015
    Placer County
    Quote Originally Posted by krazeedrivr View Post
    Everything’s ~4ohm except the sub which is 1ohm(insane)
    I checked most of them and they also read 3-4ohm.
    if you upgrade the tweeters, 10000% do 8ohm because the stock ones are extremely inefficient, and the amp is tuned accordingly. higher efficiency tweeters even at 8ohms are still very loud.
    2005 B6 GT2871
    2005 B6 S4 4.2L 6MT
  27. #27947
    Dec 30 2023
    Cluj, Romania
    The 2nd gen BOSE (the ones from A3 8P, which I got) are approx. 2 Ohms measured. (2.2 to be more exact :)
    "Dani"
  28. #27948
    Veteran Member Four Rings egovreau's Avatar
    Sep 08 2015
    2017 Audi Q5, 1989 Jaguar XJS, 2005 Ford F-250, 2002 VW Passat Wagon
    Orting, WA
    Ordered a resonated Milltek cat back exhaust to replace the Borla currently installed.
    That will likely become available sometime in the next month or so.
    Sent from my SM-S918U using Tapatalk
  29. #27949
    Mar 12 2013
    Houston, Texas
    Thank you sir!
  30. #27950
    Sep 10 2021
    Pennsylvania
    It works! I drove it! (Shhhhh...) I'm surprised, to be honest. I guess I found all the grounds that I needed to find. I suppose a whole bunch of wires don't do anything anymore because I didn't plug them in and the car worked just fine. It did complain a lot though--I'm going to get quite sick of "BEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEP" every other second for the first 30 seconds of run time while it freaks out about all the crap I broke/threw away.
    Anyway, I tested it out Saturday sometime, but then last night I moved it out of the center of the garage and did another "victory lap" around the circle where I live, and then cleaned the garage superhardcore. So much so, in fact.... that another car fits in there next to it! Fancy! So my wife has her space back (and I am grateful to her for being tolerant of this insane endeavor of mine).
  31. #27951
    Dec 30 2023
    Cluj, Romania
    Cool "Dreams (Will Come Alive)"
    What's up guys !
    Happily (and exhausted at the same time :) I am glad to present one of the best gifts I've ever got: UltraSport Alloys ! (18"x 8J, ET43) wrapped with Continental's "SportContact 6" tires (235/40/ZR18, 95Y, DOT 0723). Spent 10 hrs. today to clean, polish, wax and dress them with silicone. They are very, very rare here and that's why I have 17" of the same model. Man o man... WHAT A DAY ! Tomorrow they're getting up on the car ;)
    *sorry for the bad quality, had just the cellphone with me ;)
    "Dani"
  32. #27952
    Sep 10 2021
    Pennsylvania
    I pulled it out of the garage last night and cleaned it! With a leaf blower! Well, I emptied all the stuff out of it and vacuumed it first... but then I went at the interior with the leaf blower. Both actions were very satisfying as I vacuumed out probably 5 pounds of debris, schmutz, welding slag, crud, and grinding dust. Then, knowing that the blower probably got most of the stuff that I couldn't get with the vacuum felt pretty good, too. Many of my tools found their way back to the tool chests as well!
  33. #27953
    Jul 07 2024
    Awesome! Super satisfying to clean up a space after it's been messy/dirty for a while. "Most" of the tools hehe, the rest will probably wander back over the course of the next few months
  34. #27954
    Dec 30 2023
    Cluj, Romania
    Talking RNS-E PU (ver. 193) finally !
    Been dreaming about it for a long time by now, but 500$ for a unit would have made some deep cuts ;) So recently, this add from a guy selling a "Big color screen Audi A4 sat nav" caught my eye. He was asking 140$ and at that point I thought: -"Well, this is either broken or stolen and doesn't have a PIN..." Called him and after a quick chit-chat he told me that if I would buy it he'll negotiate to 110$. Asked him to pack it well and send some pictures and that was it. After hooking it up and entering the PIN it'd say "1 Attempt Left". The first digit was a quirky written 1... made me believe it was a 2. Tried with 1 and man was I happy to see the unit in perfect working order... even the CDC works and I found a 32GB SDHC inside with some music :) IT EVEN HAS A SCREEN PROTECTING FILM ON !
    So, without any further ado, I pulled out the Quadlock adapter and completely re-did it so it matches the OEM Harness to the unit. Man o man, WHAT A STEAL ! Now the A/C panel from a 2011 Seat Exeo, the re-done buttons and the 'new' Sat-Nav unit finally are a pride to watch ant touch ;)
    "Dani"
  35. #27955
    Sep 26 2017
    NB, Canada
    I didn't mention in the original post but the center diff was welded a few years back to go RWD, and I just took apart the front axles for the outer cups to hold the bearing together and give the ABS speed signal. If you go that route, I'd keep a stock center diff if you want to go back to AWD because currently the welded center diff with all 4 axles in leads to some binding on tight turns similar to a welded rear diff. If its only a track car then you would be fine however autocross may still pose a challenge with all the low speed tight turns.
    The suspension on my B6 is pretty soft and more of a street-orientated coilover setup so that exacerbated traction issues as the weight transfer moved all the load to the outside tire causing the inside rear tire to light up as soon as I touched the gas pedal. Even with that suspension though the last track day this past weekend saw my lap times go from 1:25.5 down to a flat 1:23 with room for improvement so even with less than 300hp AWD greatly improves drive out of corners.
  36. #27956
    Dec 30 2023
    Cluj, Romania
    Replaced the (what I thought they sold me) GPS antenna with a new one so my RNS-E happily catches 7-8 satellites at all times now :) Also replaced the FM/AM tuner adapter (now I've got the proper Fakra x2 to ISO) and managed to write 3x DVD+DL discs with all the Europe maps. (Eastern, Central & Western)
    "Dani"
  37. #27957
    Jul 07 2024
    What did you do to your B[emoji29[emoji292]] today?
    Did an oil change for the first time, easy, but way messier than I expected... Unfortunately shops around here don't have great availability.
    Also changed the rear passenger brake caliper yesterday (the seals were leaking, so I had disabled it with a line clamp) but forgot to replace the crush washers so there was still a tiny leak, anyways I replaced those and bled the brakes (again, third time this month lol). Did a bunch of progressively more and more aggressive testing while checking fluid level regularly, and other than an initial small drop (about 2-5mL) in brake fluid level it doesn't seem to be leaking anymore. I know I should replace the hose, but it is rusted to the hardline and I don't want to break that while I don't have a replacement hardline. The old caliper looks pretty much brand new (and according to the PO it was replaced less than 15k ago, so no idea why that failed.)
  38. #27958
    Dec 30 2023
    Cluj, Romania
    Took out the shifter knob & boot to treat them with some leather spray and polish the top acrylic part with the gears written on it. Replaced the clips and also lubed the shifter assembly with white grease. All nice and smooth ;)
    "Dani"
  39. #27959
    Jul 07 2024
    Quote Originally Posted by Danisson View Post
    Where did you get the clips? My shifter boot plastic holder trim is just kind of floating, would be nice to clip it down again. I might lube mine too
  40. #27960
    Veteran Member Three Rings Puddin Tane's Avatar
    Jun 22 2020
    Athens, GA
    Quote Originally Posted by willemml View Post
    Did an oil change for the first time...
    In case you're as dumb as me: I did quite a few oil changes before realizing that freeing the coolant reservoir from its mounts and tipping it forward out of the way makes the filter part of the job 10x easier (1.8t). As for the mess, yeah. If there's a way to keep the subframe from getting an oil shower as the filter's loosened, I'd love to hear about it.
