Results 1 to 40 of 61
    Jun 06 2010
    germany
    Thumbs up A simple gt28r ( gt2560-466541-4) build.
    Hi guys
    This is a very basic gt25 build
    -rs4 clutch
    -motor and tranny mounts
    -custom 3 turbo back exhaust
    -custom manifolds
    -044 intank pump
    -60lbs injectors
    -water-meth
    -oil cooler
    -and every thing you need for this type of turbos ( new sensors timing belt etc)
    - motor complete stock
    Target
    The principal idea ... fast DD car
    18-20lbs of boost ( rs4 clutch) for now.
    why gt turbos? I bought them for cheap from a friend, my idea was to use ft turbos...but I could not pass the price.
    400-30whp-420-40lbs torque
    Some pics ( later with the finished product I will post betters)
    Hope you enjoy.
    Regards
    Veteran Member Three Rings judeisnotobscur's Avatar
    Apr 22 2009
    America
    nice.
    Timing is Everything
    Jun 06 2010
    germany
    Quote Originally Posted by judeisnotobscur View Post
    nice.
    Thanks guys.... say hallo to joaquin.
    Let you know ( j-fonz)as sonn its finished.
    Veteran Member Four Rings AudiForeman's Avatar
    Apr 24 2011
    B5A4T.06R1.B5S4
    co719/303
    looking great so far. my only question is why an rs4 clutch when the motor is already out? seems to me that you should just save and wait X amount of time and instal a twin disk or something along those lines. do u really want to pull the tranny down when you dont need to later down the road when you shouldnt need to? thats typer of power is addictive and unless u have super good self control u will likely be romping on it more than you intended on. i feel the clutch wont last too long, but im no expert. someone please correct me if im wrong. reguardless the install looks great, i love the manifolds makes me wish i would have gotten some with my 605 setup but i fail at life already. best of luck my friend
    May 13 2011
    2015 BMW F30
    Thumbs up for turbos and manifolds.
    | Autospeed | JHM | Pure MS
    Veteran Member Four Rings 2380S4's Avatar
    Jul 16 2008
    2001 S4 Avant, 07 DTM S4, 15 328XI & 90 Turbo Grand Prix
    Living The Dream!!!
    If the power goal is met and not exceeded the clutch should hold, although I'm a firm beleiver of doing it right the first time. With that said I would go up a level or two on the clutch.
    interested to see where this goes.
    I've got my build going somewhat similar to this.
    Veteran Member Four Rings DiscoPotato's Avatar
    Sep 16 2009
    Delray Beach, FL
    I'd say do a fx400 for clutch
    Veteran Member Four Rings bigern45's Avatar
    Sep 28 2009
    B5S4 stage 3, B9S5 Sportback
    ky
    RS4 clutch will hold just great for a DD at that power leve, but if you plan on the strip at all, definitely do not go that route. been there.. done that. .
    RS6 hybrids and corn
    Registered User Three Rings GWerks's Avatar
    Sep 11 2010
    Grand Rapids, MI
    This is starting to look great!
    Veteran Member Four Rings Evilevo's Avatar
    May 26 2008
    2018 TTRS, 2014 Q5 TDI, 2020 Supra, 2022 F150, 2004 V70R
    MD
    I honestly don't see the point of this. It is cool and all that you got the turbos cheap and are making or getting the manifolds made for you. But you are gonna almost as laggy as my car, and not make more power than K04s. It is just absolutely pointless.
    K04s are soooooo fast because of their area under the curve. You will not have any of that with this setup.
    Either way, good luck.
    Jun 06 2010
    germany
    Quote Originally Posted by Evilevo View Post
    Hi
    This turbos got out of another s4 , wich was running 22-1 lbs( ebay modified manifolds , crush bent 2,5 exhaust ebay modified intakes stock filter box etc) was faster than a 997mk1 stock . I think it was arround 7x seg 100-200km I have to cheak the vbox. Its not a slow car by anymeans,of course my car will be slow 18lbs but as soon I got some time with the new motor in its going to be a nice DD.I f I want to go real fast I do have some other car for the job, but I do really like the ride on the s4.
    hope this clears why the gt25 on stock motor.
    Thanks for the imput guys.
    Regards
    May 26 2008
    MD
    Quote Originally Posted by JPM-Engineering View Post
    Hi
    Regards
    I don't think you fully understand. The turbine wheel on that turbo is huge. They do not spool up very fast. Link that with only trying to make 400whp. The car is going to be slower than a K04 car making the same power.
    There have been a couple cars here on AZ that have used those turbos. They are running mid 3.x FATS times.
    The power goals you want, are achievable on K04s with MUCH better low end TQ.
    If it was my car, I would sell those turbo and just buy FTs or BW K04s.
    I do wish you luck if you stick with it, just personally from experience with GTs, I wouldn't do it.
    Jun 06 2010
    germany
    I do fully understand , if you read what i wrote , built motor is going in soon , besides there is only a cuople of s4 and rs4 in my country wich are no contest jaja jokes apart thanks for your imput.
    Regards
    Jun 06 2010
    germany
    Some more pics... this weekend Im going to be cleaning the motor and motor compartiment, he only thing I got left is the oil and water lines... some head shields are now being made.
    Hope you enjoy
    Regards.
    pd: I hope next week the car is ready and waiting for the tune.......(Joaquin ???? ;)
    Jun 06 2010
    germany
    Quote Originally Posted by AudiForeman View Post
    My Apologies for have not respond you.
    All the others "upgrades" and for the new motor....
    Regards
    Jun 06 2010
    germany
    A cuple of more pics.... Hope to finish next week
    Regards
    Veteran Member Three Rings MLJS4's Avatar
    Jan 06 2010
    Michigan
    please clean your engine bay before the motor goes back in!
    2001.5 Stage III
    Veteran Member Three Rings dubzackvr6's Avatar
    Oct 18 2010
    Stage 2 C7 A6, Tahoe for the kiddos
    SLC, UT
    Those manifolds scare me. I hope you beveled the joints after tacking them.. It looks they were just welded super hot to get penetration.
    Jun 06 2010
    germany
    Finally the car its ready , running perfect without any probs here are some more pics
    Right now its running on a very detuned file I made 15lbs falling to 10 pump gas
    Some pics of the "build"
    Cleaning the motor.
    Gearbox
    Installing the turbos
    Oil cooler
    Jun 06 2010
    germany
    Leather steering wheel , and shift knobs .
    R35 2012 smics. 2000 us
    Now the dimensions on the r35 smics
    Stock S4 Intercooler Dimensions.
    * Height 8.5” (215mm)
    * Width 6.3” (160mm)
    * Depth 2.55” (65mm)
    * Exposed Core Volume 136 Cubic Inch
    * 11 Charge Rows
    * Bar and Plate, Plastic End Tanks
    AWE S4 Intercooler Dimensions.
    * Height 8.50” (215mm)
    * Width 8.56” (217mm)
    * Depth 3.50” (89mm)
    * Exposed Core Volume 254.660 Cubic Inch
    * 15 Charge Rows
    * Bar and Plate core, Welded Aluminum End Tanks
    Nissan GTR R35 2012 530 hp
    *Height 8.65 (220mm)
    *Width 10,2 (260mm)
    *Depth 3,2 (80mm)
    * 22 Charge rows
    More pics
    Regards
    Jun 06 2010
    germany
    Teaser vids
    Veteran Member Four Rings Audi_S4's Avatar
    Feb 20 2008
    belgium
    Cool stuff! Now what did it do from 100-200km/h on the Vbox ?
    A3 8P DSG 3.2 S-Line : Billstein PSS / OZ Superleggera / 034 Sway / 034 Spherical bushes
    Jun 06 2010
    germany
    Hi thanks
    Some test so far
    100-150km 3.9 seg 100-200km 11.1 seg
    Feb 26 2010
    Santa Ana, Ca
    Hows the fitment on those intercoolers?
    You might be an S4 owner when......
    You spend more time pulling you engine out than driving your car.
    Jun 06 2010
    germany
    Let you know this week , Im planning to fit them tomorrow
    By the way I put the stage 4 SB clutch. No rs4.
    Regards
    Veteran Member Three Rings Spooled1.8's Avatar
    Jan 26 2006
    York, PA
    I have the stage 4 SB with the race PP, holds up perfect on my 605's.
    -Pete
    2001 Imola Yellow S4 EPL/TiAL S605
    -Evolution Racewerks Intercoolers with Carbon fiber shrouds.-EBC Redstuff Pads-EBC Rotors-RAI Motorsport 3" Downpipes-AWE Twin 1 Exhaust-AWE DV1 DV's-AWE Center Vent Boost Guage-AWE DTS Bar-Advanced Automotion Rebuilt Trans-Southbend Stage 4 Clutch-Fidanza LWFW-ASP Engine Mounts-034 Motorsport Trans Mounts-Apikol Rear Diff Mount-KW Variant 3 Coilovers-
    Jun 12 2011
    Italy
    This is a great job
    Nice
    Veteran Member Four Rings witwer4444's Avatar
    Dec 13 2008
    Palm Beach FL
    Interested to see how those IC's work out. Price?
    Current:
    2005 Black W211 E55 AMG
    Sold:
    2002 Stering Grey E39 M5
    2001 Nogaro Blue S4
    Jun 06 2010
    germany
    Thanks
    Jun 06 2010
    germany
    Sep 18 2008
    lancaster,pa
    Quote Originally Posted by witwer4444 View Post
    X2
    Frankenturbos, Stage 3 tuning by Jfonz Tuning.
    Veteran Member Three Rings zrider91r's Avatar
    Jan 06 2012
    California
    Also interested in the ICs.. Nice alternative to a FMIC..
    Established Member Two Rings Capt Scuzzy's Avatar
    May 21 2011
    2002 S4/1973 Camaro
    Northern California
    Quote Originally Posted by marlenejlafave View Post
    i've got my build going somewhat similar to this.
    image?
    Sep 28 2009
    ky
    I bought them for 200 there are some of them for 300-350 on ebay
    thats STUPID for that price, especially when you look at the size and just make a guesstimate at the potential. how difficult are/were they to install?? a company named CXRacing didnt make them, did they??
    Jan 06 2012
    California
    Quote Originally Posted by bigern45 View Post
    If you read the thread they are r35 GTR intercoolers.
    Sep 28 2009
    ky
    Quote Originally Posted by zrider91r View Post
    yeah, i did, and i saw. so what is your point? aftermarket companies list their product as OEM items all the time on ebay, you should check it out sometime..
    http://www.ebay.com/
    Jun 12 2008
    Four Rings
    TX
    Curious to know how the logs look after everything is dialed in. The stockers have been ~125mph on the R35...maybe more, but the record on a stock R35 was 10.8x @ 124.9x mph.
    Jun 06 2010
    germany
    I Bought them from a guy I know 2012 gtr , they are NO cxracing by any means , regarding to the install I will post some pics today later, Its TIGHT fit the prob its you have to make custom piping to make them fit.
    Regards
    Jun 06 2010
    germany
    Quote Originally Posted by D Lo View Post
    These intercoolers have been prove to 650whp , just take a look at the measurement I did they probably will work very good, the frontal area its big ,22 Charge rows... etc they are top notch quality and for my goal they are perfect , and you can not forget about the price:)
    Regards
    Jun 06 2010
    germany
