Results 1 to 8 of 8
    Nov 13 2011
    Clearwater
    Crank with No Start
    Looking for some knowledgeable assistance regarding my dilemma. I have a 2006 Audi A4 2.0 approximately 80,000 mile that won't start now after replacing (4) ignition coil packs and spark plugs with OEM parts. The reason for replacement was because I was driving the vechicle and all of a sudden it started to stutter and shake and the CEL started to flash rapidly. Did some research and concluded it was a bad coil pack causing a misfire. Also replaced the battery as well and now it cranks but won't start. Conducted a spark test on the coils and spark plugs and didn't achieve any indication of spark. Checked all fuses to be in good condition. If anyone could please help shed some light on this it would be highly appreciated. Thanks in advance. I ran a Vag-Com diagnostics on it and these were the only fault codes present:
    Chassis Type: 8E - Audi A4 B6/B7
    Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
    69 75 76 77
    VIN: WAUAF78E56A157230
    Address 01: Engine Labels: 06F-907-115-AXX.lbl
    Part No SW: 8E0 910 115 M HW: 8E0 907 115 D
    Component: 2.0l R4/4V TFSI 0070
    Revision: --H10-** Serial number:
    Coding: 0104010A02070120
    Shop #: WSC 05140 444 94213
    VCID: 2B5F2055F39E
    No fault code found.
    Readiness: 0110 0101
    Address 02: Auto Trans Labels: 01J-927-156.lbl
    Part No SW: 8E3 910 155 C HW: 01J 927 156 HT
    Component: V30 01J 2.0TFSI USA 0010
    Revision: 00000009 Serial number: 00000001187324
    Coding: 0000001
    Shop #: WSC 04940 001 00001
    VCID: 2855DF59E268
    Address 03: ABS Brakes Labels: 8E0-910-517.lbl
    Part No SW: 8E0 910 517 D HW: 8E0 614 517 AK
    Component: ESP8 front H05 0120
    Revision: 00000000 Serial number: 00000000000000
    Coding: 0004525
    Shop #: WSC 06335 000 00000
    VCID: 2855DF59E268
    1 Fault Found:
    01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 3
    Fault Frequency: 7
    Reset counter: 40
    Time Indication: 0
    Freeze Frame:
    Hex Value: 0x0000
    Hex Value: 0x0202
    Hex Value: 0x0024
    Hex Value: 0x0187
    Hex Value: 0x0000
    Address 08: Auto HVAC Labels: 8E0-820-043.lbl
    Part No: 8E0 820 043 BL
    Component: A4 Klimaautomat 2832
    Coding: 00000
    Shop #: WSC 00000
    VCID: 6CDDE3493610
    1 Fault Found:
    01206 - Signal for Duration of Ignition Off Time
    27-00 - Implausible Signal
    Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
    Part No: 8E0 907 279 L
    Component: int. Lastmodul USA 0504
    Coding: 00003
    Shop #: WSC 06335
    VCID: 3B7F101503FE
    Address 15: Airbags Labels: 8E0-959-655-94.lbl
    Part No SW: 8E0 959 655 H HW: 8E0 959 655 H
    Component: Airbag 9.41 H11 3540
    Revision: 91H1135 Serial number: 0036N0016RN3
    Coding: 0032607
    VCID: 3C7D130906F0
    Part No: 8E0 910 339 B
    Component: BF-Gewichtsens. 002 0070
    Address 16: Steering wheel Labels: 8E0-953-549.lbl
    Part No: 8E0 953 549 Q
    Component: Lenksáulenmodul 0601
    Coding: 02021
    Shop #: WSC 06335
    VCID: 418362FD6112
    Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
    Part No SW: 8E0 920 951 G HW: 8E0 920 951 G
    Component: KOMBI+WFS 4 H12 0110
    Coding: 0022261
    Shop #: WSC 05811 444 999999
    VCID: 2E592941C08C
    No Faults Found
    or DTCs not supported by controller
    or a communication error occurred
    Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
    Part No: 8E0 959 433 BT
    Component: Komfortgerát T7B 3332
    Coding: 11836
    Shop #: WSC 06335
    VCID: 840D2BE9BE80
    Part No: 8E1959801G
    Component: Tőrsteuer.FS BRM 0506
    Part No: 8E1959802E
    Component: Tőrsteuer.BF BRM 0205
    Part No: 8E0959801E
    Component: Tőrsteuer.HL BRM 0606
    Part No: 8E0959802E
    Component: Tőrsteuer.HR BRM 0606
    4 Faults Found:
    01368 - Alarm triggered by Luggage Compartment Switch
    35-00 - -
    01374 - Alarm triggered by Terminal 15
    35-00 - -
    01371 - Alarm triggered by Door Contact Switch; Driver's Side
    35-00 - -
    01572 - Alarm triggered by Door Contact Switch; Passenger Side
    35-00 - -
    Address 56: Radio Labels: 8E0-035-1xx-56.lbl
    Part No: 8E0 035 195 H
    Component: symphony II PM6 0460
    Coding: 01005
    Shop #: WSC 70656
    VCID: 2C5D2349F690
    1 Fault Found:
    00858 - Connection; Radio ZF Output to Antenna Amplifier
    36-10 - Open Circuit - Intermittent
    End ************************************************** ******************-
    Oct 14 2009
    Okinawa Japan
    Most of those codes seem associated with the fact that it wont start.
    Remember your basics, you need fuel, spark, oxygen and compression. You have determined you lack spark.
    You just replaced your coil packs, and plugs. Perhaps they are tapped incorrectly? First step I would take. Is to remove one coil and replace it with an old coil and old plug. If you now get spark than you know something is amiss with your new coils.. If regardless of plugs or coils you still get no ignition, than I would check my wiring and connectors, perhaps damaged during the procedure?
    Lastly if the wiring is good than you may have blown your ignition control module, or it's associated fuse....
    Good luck
    -Shane Drake-
    2006 A4 Avant Dolphin Grey
    2007 GT3071R A4 Moro Blue-RIP
    >DRAKLOREs Build<
    Formerly DRAKES-PERFORMANCE
    Veteran Member Three Rings makav3li's Avatar
    May 06 2010
    Ellsworth AFB, SD
    Quote Originally Posted by DRAKLORE View Post
    Good luck
    said it alot better than what I had planned to say lol so I'll just quote and agree :)
    Selling Nogoro blue Alcantara door panels. Will fit b6/b7 a4/s4/rs4. In great condition, originally wanted $600 shipped but dropped price to $500 shipped. Check my classifieds for pictures. I want these gone, will include extra door clips if requested. PM me if you want pictures of them installed or anything else I want these gone so make me an offer and we'll talk.
    Sep 07 2007
    WA
    Try and Google search bag com and then code. Did one and this is what it comes up with.
    http://wiki.ross-tech.com/wiki/index.php/01826
    Veteran Member Four Rings bman005's Avatar
    Sep 06 2011
    2015 Silverado, 2012 A4 Avant. Former; 90 Corrado, 97 Golf, 05.5 A4, 2010 Tiguan
    Harrisburg, Pa
    Quote Originally Posted by MR.H View Post
    That fault is just there because the battery was disconnected
    New Build, 2010 Tiguan. Details to com
    Sep 07 2007
    WA
    Ok
    Sep 06 2011
    Harrisburg, Pa
    To OP, did you check the fuse for the coils? Its in the ECM box thats next to the brake booster.
    Veteran Member Three Rings jayphil82's Avatar
    Apr 05 2008
    Quebec, Canada
    OP I hope you get your car sorted out.
    It did happen to me a similar story. I was cruizing and the engine suddenly stopped (no shaking, no sound etc). After that I the car would crank but not start.
    The problem was my fuel pump that broke because my cam follower got destroyed and the pump hit the cam hard.... Final result bent valves and destroyed fuel pump. Thanksfully Audi extented our warranty and AoA replaced my cylinder head and fuel pump at no charge.
    Your problem is probably something else because your symptome are different... I hope
    2006 DG Audi B7 A4 2.0T 6spd
    • Performance: APR Stg2+ 93oct using 94oct gas / AFE Dry Filter/ 034 HFC/ APR HPFP/ Treadstone TR6 IC / OBX Cat-Back
    • Handling & Braking: Stasis SS Coilover / RS4 Sway / Carbotech Bobcat Pads
    • Look: Drop / 19" VMR V713 / OEM S4 mirror / DDM 6000k bi-xenon
    • Other: Evolution skid plate/ Ross Tech VAGCOM/ Snub Mount
