Results 1 to 4 of 4
    Veteran Member Three Rings mike's machine's Avatar
    Apr 01 2008
    Ducati M750 900SS Honda CBR600rr Ruckus
    Massachusetts
    Where to get AR suspension level sensors???
    as title says...where I can get new leveling sensors with good price?
    I couldn't find a place even carrying them...
    C5, Giac, 2Bennet , UUC, snub, 034, piggies, RS6 SE catback, rear S4 BBK, RNS-E, JHM, darintakes, K&N, forge, samco, rs6 reps, OZ Ultraleggera, phat box, 4.2 blades, clear corners, LED tails, tinted - SOLD
    Rolling on AR 402, H-sports, Milltek Turboback, O.CT tune, LWFW w/RS4, Stoptech ST-40 332mm fitted in stock 17", hyperboost BPV, Quad-xenon
    Sep 27 2010
    64 bug w/swapped crossflow, 71 KGhia, Nissan Armada
    Reading, PA
    If you tell me where they are at I would sell you mine unless they have something to do with leveling the headlights. Mine worked fine before I removed the air ride
    Veteran Member Four Rings PaperToast's Avatar
    Apr 29 2009
    Quadzilla
    Longmont, CO
    other than the stealership, you could check ecs tuning and europa parts
    Rockin' the Rockies
    '01 allroad, 250k woot woot, still boosting on original turbos and tippy, slightly modified. . .
    Scotty@Advanced, "Push it off a cliff, when it hits the ground you should have a few thousand horsepower available for a brief second."
    Apr 01 2008
    Massachusetts
    they both had it, europa parts was cheaper by $10.
    thanks!
