Results 1 to 11 of 11
    Veteran Member Three Rings saucys4's Avatar
    May 30 2007
    San Diego/SF Bay Area
    left lights on... car dies when jumper cable removed. alternator shot?
    I have owned an optima red top battery for four years. Recently, my battery light has been coming on intermittently but I have driven several thousand miles and have not yet had any problems. I only drive about once a week and take short trips around my town but I have also gone on a few 3 hour trips and havent noticed any electrical problems. I had come to the conclusion that it was just a voltage sensor. Last night I left one of my interior lights on which drained my battery. I hooked up my jumper cables and my dead s4 started but as soon as I removed the negative ground terminal jumper, it died. I tried again while letting the cars idle for a few minutes and even held the rpms up to ~3k but it died within seconds of removing the jumper cable. could a dead battery be causing this or is it a bad alternator?
    J Fonz Stage II+
    Apr 18 2007
    ny
    Those batteries suck when they die.
    6 Speed--EPL--034--SPEC--ER--AquaMist--Forge--RS4--RS6--K04 --RNS-E--DTS--PSS9's
    SOLD
    Greg
    C5UNION
    Veteran Member Four Rings zillarob's Avatar
    Nov 16 2010
    2kS4, 84gli, 84caddy dsl
    WetSide, WA
    Try a new battery (gonna need one anyway) and keep an eye on the votage, might get lucky.
    Those symptoms can be indicative of a bad alt but an internally shorted battery can do the same.
    Veteran Member Four Rings flyingfish2626's Avatar
    Nov 23 2008
    2008 GMC Sierra 1500
    Colorado
    Totally dead battery will do that for sure.
    2016 S3 Black Optics/LED/technology package/EQT stage 1 ECU/TCU
    2008 A4 Avant APR stage II / 6-speed.....Sold
    2001.5 S4 Avant/Pearl/Oynx/Tial 605/6-speed......Sold
    2015 VW GTI PP/LP/APR/6-speed....Sold
    Jan 08 2008
    New Milford, CT
    Sounds like the battery and alternator are dead, even if the battery is stone dead, a car will run on alternator only until you shut the car off or use accessories.
    Nov 16 2010
    WetSide, WA
    Quote Originally Posted by KFC_Or_Bust View Post
    Not always
    May 30 2007
    That's what I thought... I don't want to buy a new battery and have it die soon after if the alternator is damaged. But it doesn't make sense that a single interior light that was left on could have damaged the alternator.
    Anyway I borrowed a slow battery charger and will see if it holds any charge overnight.
    J Fonz Stage II+
    Jul 28 2008
    01.5 S4, 09 Touareg, 88 Cabriolet 16vT
    Pittsburgh PA
    Quote Originally Posted by saucys4 View Post
    the battery is junk... it is dead. live somewhere cold and that would have died on you the first night it was around freezing. very common with german cars to have high demand on batteries... the battery light was a good indication it was going to go... what is your voltage around when cranking? does it just drop to 0?
    Established Member Two Rings AJ88CAB's Avatar
    Oct 04 2006
    Atlanta, GA
    Start with the basics... If you haven't done this yet, remove the battery connectors and cleans the posts and clamps. They may look good, but if they are even a little corroded this might be why the battery is not charging and the car stalls when the charger is disconnected. Reconnect after cleaning and try starting again with the charger to see if it keeps running, if it stalls it is most likely the alternator.
    As for the battery it may not be toast just yet, see this tech article on maintaining Optima batteries.
    http://www.batteryminders.com/batter...pe-battery.pdf
    Good luck...
    aj88cab
    Marietta, GA
    2002 Audi S4, Silver, 6 Speed
    1988 Porsche 911 Cab
    1972 Porsche 914 (long term...really long term...restoration project)
    Oct 02 2006
    Wadsworth,OH
    I would at least put the battery on a charger first ( leave it over night). Reinstall and see if it holds a charge. Most car batteries last about 5 years, after that your on borrowed time.
    Start with that and see what happens.
    Good luck!
    Jason
    May 16 2008
    South Texas
    If your alt light is coming on then it's likely the alternator. However a weak or dead alternator can kill a battery over time so I'd bet that you'll need both.
