Car is a 2002 1.8t Quattro, 103k mi
Has intermittently shown an obvious lack of power when you step on the pedal. I have noticed it a few times, you push down to accelerate and it is extremely sluggish and I really wonder if we are going to move down the road. Now car has begun to surge. I started it up this morning, let it idle until it kicked down...car was running normally. Put car into drive and as I pulled onto road, car felt like it was surging slightly. Drove about 1/2 mi and battery lt flashed on and then back off and car started to run quite roughly. Made a quick u-turn to get it back home and the brake pedal was very unresponsive. Engine light came on and car was almost bucking it was running so rough. Had to stand on the brake pedal to get car to stop. Shut it down, started it back up and it ran rough from the get go. Revved it up in park and the idle smoothed out but engine lt stayed on. We replaced the coil packs less than a year ago, fuel filter was changed within 6 mos. Have no way to check the codes and no $ to take to the shop. Any help is appreciated.
