Results 1 to 16 of 16
    Active Member Three Rings
    Aug 10 2009
    Space
    Apr 21 2011
    Central NY
    Nice write up. You can clip the small white plastic that's attached to the 2 small LCD's instead of removing them.
    I replaced my center LCD last weekend and it's nice to be able to read the screen again! So worth it.
    Established Member Two Rings GiantBean's Avatar
    Mar 28 2011
    where are you guys sourcing your LCD replacements? I need to do this, and I am lucky enough to have a hot air rework station to use, just need a good place to get the replacement
    Jun 01 2008
    Apopka, FL
    NICE. in for the sub for future use.
    May 13 2011
    2015 BMW F30
    Good info. Thanks.
    | Autospeed | JHM | Pure MS
    Nov 20 2011
    Jacksonville, FL
    Quote Originally Posted by EuroDriven View Post
    Yes! I bought the car with the screen messed up. I am working on cleaning all the radio and climate control buttons right now as well. After that the interior will be 100%.
    Great write up! I also need to clean up the radio and climate control buttons-- especially the climate control. Assuming you are planning on doing a real removal/re-install for the clean up... do you mind posting a qrite up? I would love to see it, especially the removal. Thanks.
    Senior Member Three Rings Scottie2LO's Avatar
    Dec 20 2009
    02 S4 04 S4
    Montreal
    needles are out on my car....any idea on how to fix that?
    Veteran Member Four Rings nynoah's Avatar
    Jan 16 2006
    01.5 A4 avant Past cars: 95 S6, 85 Golf II VR6, 2 sciroccos, 92 Corrado VR6, 86 Euro BMW 535 Alpina
    LA CA
    Threads like this make me love Audizine
    Senior Member Two Rings tambat's Avatar
    Sep 04 2007
    Chicago, IL
    i've read through a few of these threads and i feel the answer is staring me in the face but i'm going to ask anyway: what supplier are you guys using for these screens? i have read that the oem ones are very hard to source and the non-oem ones are very bright and don't match well. i don't mind the latter so long as it doesn't look terrible. debating whether to take on this project myself or have mpower take care of it. seems pretty straightforward. can you guys please provide a direct link to the lcd screen you purchased and how you feel about it after installing?
    B5 S4 K04'd + (sold)
    can't seem to leave
    Established Member Two Rings inzunzar's Avatar
    Oct 09 2010
    El Paso, TX 79906
    I will try to do this, also the LED for the oil temp is not working, I will figure out why.
    Sep 04 2007
    Chicago, IL
    anyone?
    can't seem to leave
    Senior Member Two Rings RagtagXMASTER's Avatar
    Jul 15 2012
    2002 dodge RAM 1500
    Boston MA
    I just did this with the chinese replacement screen but i have a weird error infront of me. the date and time lcd display displays some strange information, anyone know how to fix that. and my center display no longer has lines running through it but displays no information at all and does not beep when there is an important messege to be displayed like coolant is very cold or the brake replacement warning beep. here is a photo oif what i mean
    upload immagini
    Active Member Two Rings BRTN639's Avatar
    Apr 27 2013
    2002 S4, 2000 Xterra, 2007 Suzuki SX4, 1978 BMW 530i, 1958 Mercedes 180
    Ontario, Canada
    Quote Originally Posted by RagtagXMASTER View Post
    upload immagini
    I believe the issue you are seeing is due to the LCD screen not sitting right on the pcb. I had this issue, but after removing and re-seating the lcd, it displayed correctly. It was some time ago, but I remember powering it up while dismantled to troubleshoot, the digits should light up correctly once they touch the pcb properly.
    Veteran Member Four Rings JKnight41's Avatar
    Oct 11 2012
    Southern Illinois
    upload immagini
    I had this problem, too. All I had to do was just press down on the front of the LCD and it fixed it.
    -00 Hibiscus S4 Sedan (FOR SALE)
    -09 Audi S5 / SOLD
    -01 Audi S4 Avant / SOLD
    -04 Audi S4 / SOLD
    -00 Audi S4 Stage 2 / SOLD
    Veteran Member Four Rings zillarob's Avatar
    Nov 16 2010
    2kS4, 84gli, 84caddy dsl
    WetSide, WA
    Im not at all askerrd of soldering on electronic parts, but this stuff is well worth the few extra dollars to have somebody with experience handle.
    Just got mine back from daz and it turned out good as new.
    Regardless of sending out or diy, get the oem screen!!
    Not much more and the brighter ones would slowly drive me insane every time I looked at it and it didnt match the others
    There are only 2 things needed to make an Audi work properly - Duct tape and WD40. If it moves and it shouldn't - Duct tape. If it doesn’t move and it should - WD40.
    Mar 24 2015
    Portland, Oregon
    Very nice post. I've taken on quite a bit with this car, but this is one project I didn't trust myself with.
    I went to Module Masters. They were really fast and the new screen looks superb. Well worth the $150 plus another $36 for FedEx two day shipping. It was back in under a week.
