So I picked up an 08 RS4 a few months back CPO'd and with a 2 year extended warranty on it. She's got about 78,000km and has been running pretty good so far... but I suspect that coming from a civic, I'm easily impressed.
The only issue's I've had are the idle is a bit rough, and third gear has a slight grind on random occasions when the car is semi warm. The old owner also got a coin stuck behind the ashtray which is kind of annoying too. Second gear clutch engagement is a bit rougher than the civic but for that I suspect that the root cause of that is somewhere between the driver's seat and steering wheel .
I guess my question is, what should I do with it now? The only mods I've done so far are to de-flap the exhaust by plugging up the vacuum lines going to it and some electrical mods.
I've been debating getting it carbon cleaned and got a quote for around $900 (CAD) at a pretty good mechanic shop here. Is there anything else I should get done while the engine is taken apart?
Also, would it be worth changing all the fluids in it just for peace of mind? The car reads 12k km's left until the next service, but I don't know if that's accurate or whether it was just reset it when I bought it. I was thinking tranny (redline?) and diff fluids along with a fuel and air filter change.
Any other words of wisdom?
