Originally Posted by
Greg Nelson
Assume you're purchasing a CPO from Audi dealer. If original owner purchased Audi Care, would think it's transferable to you as new owner.
It's more than oil changes at some of the later services - search AudiUSA.com - somewhere there is info re service interval items covered.
If car didn't have Audi Care when originally purchased, ask dealer if available and how much on a used CPO.
Well, after browsing around and finding out what's included, it does in fact seem worth it to get. The ability to get it transferred from the previous owner is good to hear, and I'll definitely look into that.
eirebob
If you're purchasing from a dealer, make sure that it is sold as a CPO, which will extend the warranty period beyond the original.
Noted. I actually don't think the one we were going to look at was CPO (it actually sold last night).
The high speed vibration issue you mentioned appears to be the most mysterious, and appears to apply to all years. The power steering hose fix you mentioned applies to a LOW speed shudder issue, which I had, and was resolved by the hose fix.
Hmm, interesting. So, I suppose in that case it's best to just avoid any model with vibrations at high speeds altogether, unless I can get the dealer to replace the control arms?
When I brought mine in for the 25k ( free, as I inherited the Audicare from the previous owner), the dealer performed a camshaft repair which applies to some 2009's.
Reference the thread for Camshaft RVU in the B8 A4 Tech section.
Completely missed this important bit of info. Thank you! Just need to make sure that the dealer is willing to do it if the car falls outside of the given time period.
I bought mine at 13k, now at 23k. Oil consumption seems to have improved with time and mileage. I expect to add about a quart before I next change the oil at about 28k.
Sounds reasonable enough. And I take it from the forums that 5k mile intervals are recommended over Audi's suggestion of 10k?
The 2009 is the first year for the B8's in the states, but the second year for the model at home, so at least some of the bugs were worked out before its US release. I'd still want to make sure, though, that you avail of the CPO warranty extension if you buy from a dealer.
Seems to bring it up to 6 years/100k miles. Pretty solid, though it seems the going rates for CPOs are quite a lot higher. Will have to make a decision on that.
I'm really enjoying mine. It's a fine car, and, here on Audizine, mod heaven awaits.
Glad to hear. We had called the dealer yesterday and the car was still available at the time, but between then and us actually going, it was sold. So, I'll be on the lookout for a low mileage Premium Plus. As it stands, if a deal like that appears again, then it will be the forerunner in our choices.
Many thanks for all of the valuable information.
Edit: After a quick search, it looks like the majority of CPOs in the area have over 40k miles (and thus are over the factory warranty). Should I still be seeking CPO?
