Results 1 to 10 of 10
    Established Member Two Rings P_Diako's Avatar
    Oct 08 2011
    04 Audi S4
    Name that weird vibration
    I took the car out for a drive after work cause it's been sitting for a week. I noticed that there's a weird vibration while on the highway. Not through the steering wheel but the whole car seems to vibrate (drivetrain). It's more noticeable while accelerating. But when the car gets to full temp and has been driving for 10min it comes and goes. Any suggestions on what I should look for? (6mt)....brand new tires...clutch replaced 600 miles ago...
    Veteran Member Four Rings Fade2Black's Avatar
    Nov 27 2008
    Black B6 S4
    Springfield NJ
    Flat spots on the tires,maybe from sitting.
    The democracy will cease to exist when you take away from those who are willing to work and give to those who would not.
    – Thomas Jefferson
    Oct 08 2011
    04 Audi S4
    I was thinking the same thing. The tires are brand new though. Still have the paint lines on them. But don't know how long it's been sitting for. Plus I don't like these tires cause they are noisy...any other suggestions? driveshaft joints?
    Sep 13 2008
    Western Chicago Burbs
    Nothing really I can think of that would be caused from the car sitting. It could be misfires, but gas doesn't go stale in a week. Take a look under the car at the axle boots
    Veteran Member Four Rings SquiddyB6S4's Avatar
    Apr 24 2010
    B6S4, CD5, Gen4 T4R, NA8 aka ugly track slut
    Teh!cks-us
    New or old, many tires flat spot slightly when left for a few days, and some will even do it daily. Common for heavier cars, and happens way worse with stickier tires. Usually if it only happens when the car is cold it's the tires. A car like this there's probably no tire that doesn't flat spot slightly, just tires that are mushy enough not to be a bother and tires with firmer construction that make it more noticeable.
    There are a few other things it could be, but my money says tires. Normal, no worries.
    -Jason
    2004 B6S4 6MT - Apikol Snub Mount, Piggie Pipes, Magnaflow Cat-Back, JHM Tune with Launch Assist, Squid Rear LSD #01 20lb wheels + Michelin PSS
    2013 Veloster Turbo 6MT - For sale
    1996 Miata - DE car; every moving part new or rebuilt, almost stock
    1995 Accord Wagon - Beautiful, stock, DD Duty, trip-mobile, track day support wagon
    LifeWithSquid
    Dec 07 2008
    Harrisburg, PA
    Quote Originally Posted by P_Diako View Post
    If it comes and goes after driving car it's not the tires.
    Oct 08 2011
    04 Audi S4
    drove the car tonight and no vibration... on a side note it was a bit warm today and i did notice that the vibration happens when it gets colder out. by the way the tires do make a lot of noise while on the highway. im taking it to the dealer in the morning so they can take a look at it. also the car does need an alighment but i dont know if that would cause the vibrations.
    Oct 08 2011
    04 Audi S4
    Well got the car back from the dealer same day as I dropped it off. One of the rear wheels needed to be balanced. Thanks for all your info!!
    Aug 10 2010
    rhode island
    Put new tires on her? What did you get??
    Oct 08 2011
    04 Audi S4
    Well I got them to change out the yokohomas that were on there cause they where a bit noisy. Replaced with conti sport contact 2's.
    Quote Originally Posted by rirobs4 View Post
