So, after soaking up the knowledge from the mighty AZ, i figured id post my first DIY to give back a touch of love:
This is the same thing as the bracket fix, but for $3.
First, get you sum of these here from The Depot. Make sure you find the thinner guage (there will be a few different kinds).
Take out that busted ass glove box, knock out the hinge pins and remove the door (disconnect the dampner piston lever, you should be able to just pry out the connector pin). The pins are in there pretty good, they have knurled ends that seat in the hinge so it ill take some big boy whacks with a flat screwdriver and hammer to dislodge.
Now comes the part that brought me the most joy, dremel that back of that effing piston off to defeat the dampner. This little piece of crap is the cause of all your woes. Be careful not to mess up the glove box light switch while vengefully mutilating this little bastard. You may feel that a good "take that bitch" makes the experience much more enjoyable.
There are other ways to fix the piston, but this way was way more fun.
So, now that your piston has been terminated, take your trusty hammer and gently shape one arm of the bracket to match the hinge curve as such:
And yes, much beer makes the process mo better.
Also match the slight curve on the door as well. Trial and error.
So now predrill the screwholes, paint (rough up the surface with sandpaper), and install ( you may need to dremel out the hinge reciever area a touch to get clearance):
Id suggest lathering on the JB Weld in the hole left by the broken bracket just to be sure. Also fill those two rectangular holes on the underside with JB or superglue or whatever you have. This will give those screws somthing to bite into. I did this after i put the bracket on and noticed an exposed screw:
If you use super glue like i did, watch out for the white vapor haze.
Now reinstall and love life.
(sorry my pics and post format sucks! first DIYish thing)
