Results 1 to 12 of 12
    Sep 17 2005
    Fremont, California
    *** 034Motorsport 2.7T Billet Fuel Rail "Drop-In" Kit for S4/RS4 ***
    Here at 034Motorsport we've been producing 034EFI Billet 2.7T Fuel Rails for some time now. However, installation has largely been left to individual custom setups and such. In an effort to get more folks interested in upgrading to our billet fuel rails, we've compiled a complete "Bolt On" or "Drop In" kit that includes every hose clamp, o-ring, sealing washer, replacement fuel lines, replacement vacuum lines and check valve, and even a billet aluminum fuel pressure regulator adapter that allows the reuse of your stock FPR! This means a completely bolt on solution for both the S4, RS4, and A6 2.7T!
    The kit is available as a conversion for the stock 2.7T manifolds, or it can be used as an alternative to the rare and expensive OEM RS4 fuel rail when converting to an RS4 intake manifold! We use these on a variety of vehicles, including our 1000+ horsepower GTi-RS 3.0L 30v V6, as well as my own personal vehicle.
    We are offering Audizine members $75 off the kit and FREE SHIPPING as an introductory price for the first 5 kits sold!
    What's Included:
    - 034Motorsport 2.7T Fuel Rail Pair w/ Brackets
    - 034Motorsport Internal FPR Housing (or fittings for external adjustable FPR's)
    - Injector Mounting Hardware
    - Fuel Lines with clamps and -6AN Fittings
    - Replacement Diverter/Vacuum Lines (not pictured)
    - Replacement check valve for EVAP (not pictured)
    - All Necessary Hardware, Seals & Fittings
    Normal Price : $425 (S4 manifold), $385 (RS4 manifold) + shipping
    034Motorsport's billet aluminum fuel rails for the 2.7T are CAD engineered and CNC machined to precise tolerances in order to ensure perfect injector and thread sealing. Brackets are available for short and tall injectors. Allows the use of OEM injector clips to keep injectors attached and sealed even with the rail unbolted from the intake manifold.
    These rails will primary be aesthetic and while allowing more flexibility in the use of fuel gauges, fuel pressure regulators, etc. It also helps clean up the busy top of the intake manifold and allows you to replace and reposition the evap and fuel lines, leaving the engine bay looking cleaner and nicer. While the B5 community has seen the stock 2.7T fuel rail do over 600whp, that is not an excuse to assume there are no benefits to running a rail that can outflow any fuel pump you ever use!
    However, please do not buy this product assuming you can just bolt it on and get instant additional horsepower. The stock fuel rail is probably not a bottleneck for most people. This is however pretty much the highest flowing fuel rail available on the market for the Audi 30v V6, and a great way to improve your engine bay, install an RS4 intake manifold, or guarantee you have the highest flowing fuel system possible with the flexibility of easily integrating -AN braided lines in the future!
    -AN stainless steel braided lines can also be supplied for an additional cost, but this "Drop In" kit is designed to utilize your factory hardlines from the pump. Please contact me for special requests.
    To Order: Contact me via PM, Email, or Phone and supply me with your full name, shipping address, and email address.
    Please Also Specify:
    - S4 or RS4 intake manifold
    - Raw Aluminum or Black Anodized (other custom colors available at additional cost)
    - What Injectors You Run (EV14, DEKA 60lb, etc)
    We can also supply everything else required to convert to the RS4 intake manifold, such as adapters to utilize a silicone throttle body boot and aftermarket bipipes!
    Note: This has only been tested for fitment on manual transmission cars...
    Jun 14 2007
    2000 S4
    Connecticut
    That's awesome.. Something I will be getting in the future for sure.
    Great job!
    Veteran Member Four Rings Mantis's Avatar
    Aug 04 2007
    I have been sitting on a set of 034 rails with -8 option fro almost a year, I went a different direction on my A6 build, but may use them on my FT'ed S4, do you have an option to sell just the lines and FPR as a kit
    I don't think I care anymore
    Sep 17 2005
    Fremont, California
    Quote Originally Posted by Mantis View Post
    Most definitely Mantis. Tried to PM you, your mailbox is full, but anyone is welcome to contact me with special requests. We can supply the lines without the rails, or supply the kit with complete AN fittings in place, or lots of other options.
    I'd be willing to put together some 034Motorsport FP34 Inline Surge Tank (or dual 044 surge) + 2.7T Fuel Rail Drop In Kit packages as well!
    Great job!
    Thanks dude! Definitely hit me up!
    Sep 17 2005
    Fremont, California
    Here are some more pictures!
    Veteran Member Four Rings Sleeeper X's Avatar
    Nov 20 2007
    01.5 S4
    The city with tall BUILDINGS!
    Quote Originally Posted by Max@034 View Post
    powered coated intake mani, 650 dollars
    loba y pipe, 800 dollars
    silicon accordian with cnc'd maf housing, 200 dollars
    learning how money makes money, priceless.
    l gotta-- l gotta get
    a form from a scientist.
    Veteran Member Four Rings Raacerx's Avatar
    Mar 22 2009
    ex B8.5 SQ5, ex 8V S3, ex 8P A3 VR6, ex B5 STK S4
    Norcal
    Quote Originally Posted by Sleeeper X View Post
    However, that is a 034Motorsport Carbon Fiber RS4 Replica Y-Pipe; not a Loba.
    See here: http://www.audizine.com/forum/showth...-Group-Buy-***
    The Best Things in Life Are Free... Or Heavily Discounted!
    Jan 11 2007
    Salt Lake City, Utah
    Details on the dual surge? Or is it just two of the single inline surge tanks?
    ** GT2860R-7 S4 Build Log--
    LOOKING FOR:
    --Late 2.7t Block "BF"
    Sep 17 2005
    Fremont, California
    Quote Originally Posted by jibberjive View Post
    We've had the dual 044 pump surge tank for quite some time now. I'll take a picture of mine on Monday; it is powder coated and anodized. Wish I could do something with the 044's finish. Maybe they can be polished.
    Jan 11 2007
    Oh yeah, I forgot I've seen that. I was hoping maybe I didn't have to make one, but that's not what I'm looking for. Thanks for the info.
    LOOKING FOR:
    Sep 17 2005
    Fremont, California
    BUMP! Still got 2 kits left at this price if anyone wants to get in on it!
    Raw or Ano Black!
    Custom colors if you want to pay extra!
    Established Member Two Rings palpal b5 s4's Avatar
    Aug 03 2011
    b5 s4 single
    In the shop
    Hey Max
    Can i just order the banjo line plus the bolts and seals ?
