Results 1 to 7 of 7
    Nov 19 2005
    Pair of (. )( .)
    Question 16487 and 17704 trouble codes -> limp mode+vibrations: opinions welcome
    So yesterday i got 16487 and 17704 trouble codes , i found some info too, first one is MAF sensor with/or possible boost leak and the other one is temp sensor or thermostat, goes into limp mode after hard acceleration and stays at 5psi, in a minute or so goes back to normal, and starts vibrating while at 16psi and up, anyone had those codes and those symptoms? please feel free to help a braza out:) thanx. andrey.
    -Andrey
    Stanced and Tuned Brilliant Black RWD C5 A6 2.7T 6MT
    Nov 05 2010
    Rosemount, MN
    Do you have the updated green coolant temp sensor? If not, and yours is black, replace it. The vibration you feel is probably a misfire. Are you able to scan with VAG-COM?
    Sep 27 2010
    64 bug w/swapped crossflow, 71 KGhia, Nissan Armada
    Reading, PA
    My car is doing the same exact thing, but I get zero check engine light.
    Nov 05 2010
    Rosemount, MN
    Quote Originally Posted by Michael B View Post
    Does your CEL illuminate when you turn the key one before starting the car? If not, it's probably burnt out. Have you scanned for codes?
    Sep 27 2010
    Reading, PA
    I was worried that the light was removed before I bought the car but it does light up when I turn the key. Scanned it and was reading left bank egt bad. $800 dollars later at a so called audi guru the car acts the same. Weird thing is it only runs like this during the winter months.
    Nov 05 2010
    Rosemount, MN
    Scan the car for codes and post them here. If you don't know someone local with VAG COM then you can get by using a generic scanner from an auto parts store, but the codes will be generic and less specific.
    Sep 27 2010
    Reading, PA
    I can run vag com just need to get time do it. I will post up the findings
