Results 1 to 11 of 11
    Jul 27 2008
    Orlando
    OEM Green coolant sensor?
    So I bought this VAST Fueling kit, have everything installed, where does this OEM green coolant sensor go?
    https://vastperformance.com/index.ph...-kit-2-7t.html
    Thanks for help guys
    Jun 24 2008
    It goes into the coolant pipe on the passenger side close to the fake firewall under the accordion hose.
    Senior Member Three Rings PluschakovP's Avatar
    Jul 05 2010
    NW Washington
    Right here, circled in red. Sorry for the bad picture...
    Senior Member Three Rings hellrot98m3's Avatar
    Dec 21 2009
    i dont know why but i could have sworn it was on the driver side? i know the picture is there to prove me wrong smh
    Senior Member Three Rings Marioh's Avatar
    Jun 26 2010
    Passenger side for sure. Easy to replace.
    Senior Member Three Rings ezfour's Avatar
    Apr 17 2010
    Nevada
    Nope, driver's side is for the afterrun pump switch
    Jul 27 2008
    Orlando
    Thanks guys! I knew AZ would come thru :)
    Jun 23 2010
    Athens, PA
    So just to make sure, if we're looking at the engine in the car, the coolant temp. sensor is down below behind the accordian hose and not right behind the top of the y-pipe where the accordian hose connects right? Cuz it looks like there's two sensors there.
    Jul 05 2010
    NW Washington
    Quote Originally Posted by hellrot98m3 View Post
    there actually is one on the drivers side too, but people always replace the one on the passenger side. don't ask me why, i don't know the difference.
    Jul 05 2010
    NW Washington
    here's the one on the drivers side too. apparently drivers side is for the aux pump, and passenger side is coolant sensor.
    Jun 24 2008
    Quote Originally Posted by PluschakovP View Post
    Like you said above, the one on the passenger side is the coolant temp sensor (CTS) that actually can affect performance. My car was throwing rich codes and sputtering because mine crapped out. The sensor on the driver side that looks nearly identical to the CTS is the aux pump thermostat which controls when your aux pump runs.
