Results 1 to 9 of 9
    Sep 10 2011
    None
    Service Reset Won't Work
    I've reset the Service display and it shows nothing but **/**. I am aware that it's supposed to do that for a little while until you drive it a bit, but I've driven it at least 300 miles since the reset and it stays the same. Initially, I reset it with the VAG Com, but a couple days ago I tried the normal way (hold wrench, turn on, hold 0,0). It still displays **/**. Anybody know what the deal is?
    Veteran Member Four Rings CoreyRS's Avatar
    Aug 07 2009
    Ca
    try disconnecting the battery to reset the ECU
    Established Member Two Rings whoosh's Avatar
    Feb 07 2009
    Belfast, Maine
    Mine reset almost 400 miles later!
    The older I get the faster I was.
    Veteran Member Four Rings bez101's Avatar
    Oct 06 2009
    sheffield
    its usaly around the 500 mark
    wait a while it will show
    Sep 10 2011
    None
    Quote Originally Posted by bez101 View Post
    Crap! I reset it again last night just to see if that would kick-start it. OMG 450 miles to go. Terrible!
    Aug 07 2009
    Ca
    Seriously? Mine resets instantaneously, I just did it about 2 months ago
    Sep 10 2011
    None
    Well, so which is it?
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    I don't know exactly but it resets on a time/distance schedule. Mine usually takes a few days to start registering again after a reset.
    Veteran Member Four Rings Pothole's Avatar
    Jun 02 2008
    Snohomish, Washington
    I remember reading that it will take a wile in the manual, but ive actually looked to see when it resets, it will be back in another 5,000
    Please Drive Right
