Results 1 to 6 of 6
    Nov 04 2009
    Vienna VA
    Question clutch fan question..
    quick question about the clutch fan,
    not sure what i was thinking but when i was removing the fan there is a metal peice which goes across and i thought there was a bolt behind it so i took that off then figured that it was only held by the 4 hex
    behind the metal rectangular logo there is a pin which sort of pushes in, i wonder if this metal is supposed serve the purpose of pushing that pin constantly in or can you go without it?
    i managed to place the metal thing back on and used a sealant to secure it in place where its pushing the pin in which is on the back
    is there really a use for that metal thing or can you go without it? http://www.ebay.com/itm/98-99-00-01-...item415759ae25
    thanks
    Veteran Member Four Rings salz2135's Avatar
    Sep 15 2005
    Austin, TX
    My guess is that the engineers would not be concerned with aesthetics on a viscous fan clutch. Therefore, it likely services a functional purpose. You may have a problem with fluid leaks and if it were my car, I would replace the clutch now that you've damaged it.
    Deactivated Two Rings
    Aug 19 2011
    1998 Audi A4, Quattro, 2.8/30v, Tip; 2001.5 VW Passat GLS, 2.8/30v, 5spd, w/Unitronic
    Groton, CT
    Quote Originally Posted by salz2135 View Post
    x2 on that, I would simply replace it to place it safe. That way you know you'll be replacing it with a brand new one, and not have to play around with it if you re-installed the old fan clutch. It's cheap enough where I wouldn't bother getting one used. A used fan might have as much wear on it as your current one, and wouldn't come with a warranty on it.
    (Click on the pic to follow the link.)
    Veteran Member Four Rings Avant Nate's Avatar
    Dec 23 2009
    2001 Audi Allroad 6MT,1999 Yukon Denali, 1987 4Runner
    Boulder, CO
    Time for EFK.
    99.5 1.8T QMS: GT2860RS .63 T3, PSI T3 Mani, Turbosmart 38mm EWG, Unitronic 415, Forge 007,Treadstone TR18 FMIC, Walbro e85 450, FSI coil conversion, 3" DIY Magnaflow/Dynomax VT exhaust
    Depo ecodes, DDM slim 6000k, VDO boost gauge, PLX AFR, Greddy profec B EBC,
    H&R sport springs, 034 rear sway, 034 rear diff carrier, A8 fronts,18x8 OZ Superleggera
    Next up E85, efr 7163 or gtx3071r?
    01 allroad 2.7t 6mt, GIAC stage 1
    Nov 04 2009
    Vienna VA
    hey thanks for response,
    just so that we are talking about the same thing here, this is basically my clutch fan (http://uploadpic.org/storage/2011/NY...GEkFAJKQoA.jpg) the red circles the metal clip which i removed which is held together by the white glue thing circled in the yellow...
    i managed to put the original one back on and used a cilicone sealant to put it back on its place and stick it ...
    let me know what you think..
    Thanks
    Aug 19 2011
    Groton, CT
    That would be the fan clutch! I just had to replace the one on my '01.5 Passat, you couldn't believe the difference having a new one installed made!
