Results 1 to 13 of 13
    Oct 29 2004
    02 S4 Avant 6spd Blk/Blk, 04 Mini Cooper
    Valley Forge
    Trying to Diagnosis Starting Issue
    I've been having an intermittent issue since getting my S4 (6spd, 120k.) It only seems to occur on a cold start.
    When I depress the clutch and turn the key I get nothing from the engine, all of the interior lights come on and the display says "Press Clutch to Start" yet I'm pressing the clutch and turning the key and nothing happens. Sometime I will turn the key once and it will turn over, other times I'm turning it 3-4-5 times and this morning it was probably 8 or so times.
    After searching I've come to the thought that it is one of these 4 issues, I'm just looking for a way to narrow it down to one.
    - Starter
    - Ignition Switch (leery of this b/c this is mentioned when they key stays in the start position)
    - Clutch engagement switch
    - Crank Shaft Sensor
    If anyone has any thoughts or past experience it would be greatly appreciated.
    I'm going to find it and I'm going to destroy it. Possibly with dynamite.
    Veteran Member Four Rings zillarob's Avatar
    Nov 16 2010
    2kS4, 84gli, 84caddy dsl
    WetSide, WA
    Hopefully either ign switch, or clutch switch.
    If you hold the clutch in and switch the key a few times before it starts, prob ign.
    If you hold the key to "start" and cycle the clutch to get it to start I would lean toward clutch switch.
    Oct 29 2004
    Valley Forge
    anyone else w/ a similar experience?
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    ignition switch is shorting out. its about 20 minutes of work to replace.
    crank position sensor will usually cause misfires and dtc errors
    could also be your FP relay. but im betting ign switch
    Nov 16 2010
    WetSide, WA
    Unplug the clutch switch and put a jumper in the connector. If it starts it was the clutch switch.
    If it doesnt, there is a harness right by the pass engine mount with a giant black wire and a small black wire. Probe the small one, should see ~12v when you turn the key to "start".
    If no 12v, then ign switch. If you see 12v and it still doesnt turn over, its the starter.
    A wiring prob could cause this, but it is more than likely one of the three above. (and pray its not the wiring, hate tracking that shit down)
    Mar 21 2010
    Baltimore, MD
    Quote Originally Posted by zillarob View Post
    make sure you get the right clutch switch, i believe there's 2, one in from of the pedal for cruise control shut off and one behind the pedal for starting
    -Steve
    Baltimore, MD
    Feb 07 2008
    The boonies, near Seattle
    My money is on clutch switch.
    -dre
    Nov 16 2010
    WetSide, WA
    Quote Originally Posted by emmwhat View Post
    Yup, 2. And as usual, not the easy one. lol
    Sep 08 2009
    S4 Avant, Golf TDI
    Walden NY
    Hey Guys - I'm having the same symptoms as the original poster. 2001 S4, 6-speed, 182k miles. All stock except borla cat-back.
    Intermittent starting issues with no codes. When I turn the key to ACC, I have cluster lights and battery gauge on lower right of cluster reads plenty of juice (15V or so). When I turn the key to the Start (cranking) position, I'll get a very brief cranking from the motor then it completely stops (motor not turning, but cluster lights stay on). If I keep the key held to the start position it will crank again normally and start right up. Sometimes I have to repeat this a few times. Until now I haven't had to do it more than 3 times max, but I realize I'm on borrowed time here. Gotta get it fixed.
    I have no other issues while driving. No stalling, No RPM jumps, No hesitation. Driveability is normal.
    From reading here, I don't believe its the Crank Sensor, as that is more likely to throw codes and have stalling/driveability issues.
    As stated in this thread, I'm guessing its the 1. Ignition Switch or 2. Clutch engagement switch. Anybody have the part numbers? Thanks.
    Jun 29 2010
    Middletown, NY
    I had the random no start issue as well...it was the clutch safety switch. Went at around 115K miles. Expensive as hell for what it is and like many other things on the car, you have to be a contortionist to fix it. Turn key, no crank, nothing, but everything else looks and feels fine.
    Veteran Member Four Rings JDM EJ1 95's Avatar
    Feb 28 2007
    01 Nogaro S4 Stage 3
    chicagoland
    check the big ground on the pass side engine mount. remove and clean it up well.. i had similar issues.
    Nogaro 01 s4
    24v 2.9L VR6. 6466. Pump gas 10.7 @ 132
    620whp 93octane
    806/767 whp/wtq on C16
    10.4 @ 136 C16 (bad slipping clutch)
    138mph best trap with slipping clutch.
    Veteran Member Four Rings Rated S's Avatar
    Apr 02 2007
    '01 S4 '94 D21
    Studio City, CA
    99% clutch switch. My car has same problem; too lazy to fix.
    SoCalS4.com/Repair - For All Your Delicious B5 S4 Tuning/DIY Needs
    Don't like me? Feel free to email me and tell me all about it - [email protected]
    Jun 29 2010
    Middletown, NY
