    Senior Member Three Rings cpu77's Avatar
    Feb 27 2004
    Mansfield Ohio
    Anyone Wrinkle Paint Throttle Body?
    I just got my intake mani powder coated and thought it would be cool to do the TB as well. The 400 degrees seems like a bit much on the TBs parts. Maybe the 200 degree wrinkle paint would be better? Just wondering if anyone has done it and how much of the TB should be taken a part for 200 degree cure.
    Current
    2004 Silver A4 1.8T FWD 5spd Franken Turbo/3"Exhaust/Racewerks FMIC/440cc/Motoza/TestPipe/SAI Delete
    2004 Red A4 1.8T FWD 5spd (Wifes) Mods- Stage 1 Plus APR w/Neuspeed Exhaust/Test Pipe
    2002 Black Porsche 996TT X50 UM Stage2 Z/C k16/24 528AWHP
    1999 Wrangler 4.0 5spd/2.5" Lift 33" Tires No doors No top!(I like driving this better than my 911)!
    Aug 26 2005
    You definitly don't want to disassemble the TB. The way they are assembled, does not allow for practical disassembly and reassembly. For example, to remove the throttle plate screws, the screw staking must be ground or filed away before removing the screws, then the staking must be re done to lock the screws in place after reinstalling them. Even if this is done successfully, the position of the throttle plate on the throttle shaft, is difficult if not impossible to get re-positioned correctly after removing the plate from the throttle shaft. If not repositioned right, the throttle will bind in the throttle body bore. Then, there are other parts of the assembly that are fastened together using methods that don't provide for disassembling, to do so, the parts most often are damaged or destroyed trying to take things apart. A wrinkle paint process that does not require more heat than the TB sees in a hot engine bay would be the only practical way to to this.
    Vorsprung durch Technik
    Jun 08 2008
    Calgary AB Canada
    I used VHT wrinkle spray paint. Masked off areas I didn't want painted and gave it a few good coats.
    Turned out nicely
    2011 Audi A4 Avant // quattro // Garnet Red
    Stock. For now...
    1989 Porsche Carrera 4 // 5 Speed // Guards Red
    Feb 27 2004
    Mansfield Ohio
    Quote Originally Posted by onceover View Post
    Turned out nicely
    It did turn out nice so you cooked it at 200 degrees?
    Current
    Jun 08 2008
    Calgary AB Canada
    I didnt heat it at all, the paint does it on it's own
    Stock. For now...
