I currently have the same problem, only I can still shift, a little notchy and locked out of 2nd but definite clutch drag. Grinds into R, 1st, and 3rd after several minutes with the clutch in. But once I stop the input shaft with the synchros it doesnt start turning again until the clutch is let out.
First try to bleed it. I use a pressure bleeder on the brake res. and whatever higher quality fluid they have at NAPA, if you have access to it though Pentosin is always better, I just live in the middle of no where. Any DOT 4 will work as long as you arent tracking the car.
To bleed the slave, search for DIY, its easier from the top but the coolant tank needs to be moved. Its just like you would bleed brakes, the bleeder valve is a 9mm right behind the slave hardline. The valve is plastic so be careful/ gentle. I used a standard size wrench since it fit a little tighter. You gotta go all in with your arm though. You can also get to it from the bottom and is easier if you take the CV heat shield off. Bleeding with the back of the car raised can also get any hard get bubbles out of there.
Second I would replace the slave and rebleed.
Third, replace the master and rebleed.
If that doesnt work I plan on lengthening the slave rod slightly as the clutch is barely dragging. I have a VAST stg 3 clutch so I am wondering if the added thickness is what is causing it.
I am a little vague on how the SAC mechanism plays into all of this but that could be another source of disengagement problems. However I had read that a longer slave rod will cause a higher engagement point on the pedal and mine is already pretty high. These master cylinders do not look to be adjustable.
Fourth, take out the trans and inspect or just replace the pilot bearing, clutch fork, throw out bearing. Maybe even the pressure plate.
Fifth, crash the car into a tree and get on with your life.
The end.
