Results 1 to 19 of 19
    Senior Member Three Rings 04 S4's Avatar
    Nov 01 2011
    2005 Ford E250 Work van
    Bonney Lake, WA
    b6 s4 ATF change...no difinitave answer
    ok...so Im looking to do and ATF change on the 2004 S4 (trip). I have done alot of searching without much difinitave answers. JHM sells the OEM audi fluid for 55$ a qrt...the dealer for 45$. Im looking for a non OEM fluid that meets all the qualifications. From the research done it looks like the tranny in the 04 s4 is the 6HP19A (PLEASE correct me if im wrong! and Ive seen some people referencing that it needs to conform to audi spec G-052-162-A1...but a few questions.
    Is the trip in the 04 s4 a CVT style transmission? because amsoil has an oil that shows an application for the audi spec...but also states not to be used in CVT trannys. Some people have used a redline variant...but quoted nothing stating it was applicable.
    Also, Im going to be doing the drain where I pull the pan and change the filter and the +/- 5 qrts in the pan...so Im worried about fluids mixing that arent like in type...
    Can anyone give some input on what fluids to go with?
    here are some that I have found:
    http://www.thectsc.com/index.php?p=p...=184&parent=58
    http://www.amsoil.com/storefront/atf.aspx
    I want to go with the right stuff..but id like to not break bank ;)
    Thanks for the input!!!!
    2004 S4 (Tip) - Dolphin Grey metalic Traded 4/3/13
    2009 Q7 Prestige S-line - Daytona Grey
    Sep 13 2008
    Western Chicago Burbs
    Paging justincredible......
    Nov 01 2011
    Bonney Lake, WA
    im assuming thats a user? lol
    Veteran Member Three Rings adioman6000's Avatar
    Jan 12 2011
    SLC
    ask dparm he knows all about this stuff
    Nov 01 2011
    Bonney Lake, WA
    Quote Originally Posted by adioman6000 View Post
    Sent a PM lol, thanks
    Veteran Member Four Rings dparm's Avatar
    Apr 24 2009
    Frisco, TX
    Redline says that this product may safely be used in the automatic transaxle of a B6/B7 S4:
    http://www.redlineoil.com/product.aspx?product=30504
    now: 2021 Mercedes AMG C63 S, 2017 Chevrolet Corvette Grand Sport
    past: 2005 Audi S4, 2011 Audi S4
    Nov 01 2011
    Bonney Lake, WA
    awesome,
    and that can be mixed with the OEM stuff in there when doing a drain and fill without any worries?
    side note...I have a feeling I have found the guru hahahha
    Apr 24 2009
    Frisco, TX
    I see no reason why not. If in doubt, call Redline directly. Their tech line is amazing and those guys will tell you exactly what you need to know. I think since there is so much ambiguity around the VW/Audi spec, it wouldn't hurt to call before buying anything.
    Nov 01 2011
    Bonney Lake, WA
    will call them and post back :D
    appreciate all the info!!!!
    Apr 24 2009
    Frisco, TX
    What'd they say?
    Nov 01 2011
    Bonney Lake, WA
    havent called yet. Will do today
    Apr 08 2009
    Bothell, WA
    I put ZF LifeGuard6 in my tip, ZF makes the trans and it's what they recommend.
    Apr 24 2009
    Frisco, TX
    Quote Originally Posted by guzerone View Post
    Someone is making it for ZF. I had always speculated it was Shell based on the bottle design.
    http://www.bobistheoilguy.com/forums...Number=1829776
    So pretty much as long as it meets Shell M1375.4, you're fine, from what I've read.
    Stage 2 Banner Advertiser Four Rings jaybquick@JHM's Avatar
    Aug 23 2005
    Lathrop, CA
    We have heard reports of people being ok to use Redline D6. However we do the services with pricey OEM fluid until we see long term results from using D6. They put special additives in fluid for the clutches and Audi obviously made a change with this 6-speed thus a fluid change from the older 5-speeds. Wrong fluids can cause hard shifts, slipping and other issues. Like I said though I haven't heard issues about D6 but we won't officially back it until we get results from people running it for years.
    This thread encouraged me to research this as well. It does say it is Shell M 1375.4 in the Bentley Manual for the 6-speed Automatic 09L trans. The Redline D4 Auto Trans fluid meets this spec which we stock.
    Here is our OEM B6 fluid service kit.
    http://jhmotorsports.com/shop/catalo...-s4-p-636.html
    We also sell the filters and gaskets separately. -> http://jhmotorsports.com/shop/catalo...56_61_105.html
    And due to this thread I just made this service kit in our store with the Redline D4 -> http://jhmotorsports.com/shop/catalo...-s4-p-928.html
    We stock B7 kits as well.
    JHMotorsports AZ tuner spotlight VIDEO
    Check out our 11 and 10 second passes on YouTube
    B8 S5 4.2l - JHM Stage 1 SC Kit (ET: 11.8 @ 119mph) -- B6 S4 - JHM Stage 2 SC Kit (ET: 11.1 @ 128mph) – JHM Nitrous (ET: 12.29 @ 117mph) - JHM Bolt Ons -ALL MOTOR (ET: 12.70 @ 111mph) -- B5 S4 - JHM RS6-R (ET: 10.8 @ 130mph)
    Apr 24 2009
    Frisco, TX
    Hey Jay, do I get a cut of all sales since I shared that info with the class?
    Aug 23 2005
    Lathrop, CA
    Quote Originally Posted by dparm View Post
    Maybe but I still had to do the work to confirm it, so only partial. HAHA
    Nov 01 2011
    Bonney Lake, WA
    I had caked then and confirmed as well that it can mix.
    And jhm...you rock!!!!!
    Sent from my LG-P999 using Tapatalk
    Nov 01 2011
    Bonney Lake, WA
    *confirmed...
    Oct 02 2006
    Wadsworth,OH
    Our Genuine VW/Audi automatic transmission fluid is currently up to 28% off!
    Click HERE to order or for more information.
    *Green fluid available as well.
    Jason
