    Senior Member Three Rings haggard69er's Avatar
    May 20 2007
    Alligators
    pittsburgh
    missing message from abs controller
    ok so i bought a vast rs6 fueling kit from a member to complete my setup. my car is a 2000 A-box. he sent me an M-box ecu with the tune. i have already converted my Bosch maf to a hitachi unit. i have a fully registered version of vagcom. i have already recoded the instrument cluster but am having a very difficult time performing the engine recode. every time i go to engine, login, type in 11463 and press do it nothing happens i am not prompted to enter 06611 for no ESP. this has been driving me bananas! any help would be appreciated. i just want to get my running correctly so i can enjoy it. thanks
    Veteran Member Four Rings cj-S4's Avatar
    Not enough space here
    Somewheretown, PA
    You dont have to login.
    Just click on "Code" and enter 06611 if that is the number you want to use?
    Do you not have ESP?
    My new ecu from Giac was coded like that (without ESP),, it just made the ESP be off and the ABS and ESP light to be on all the time. I recoded it for with ESP, and the lights went away and the system works, and can be turned off via button as it should now.
    May 20 2007
    Alligators
    pittsburgh
    no my car is a 2000. does not come with esp. 2001 and above have esp i think. these are the instructions i used http://s4wiki.com/wiki/Engine_recode
    May 20 2007
    Alligators
    pittsburgh
    thanks finally works. open vag com go to engine, recode, change first box value to desired. thanks!
    Somewheretown, PA
    Glad to hear
