To fix an oil burning problem, details here: http://www.audizine.com/forum/showth...-whole-vehicle . I am going to either rebuild the bottom end and head OR my mechanic recommends getting a slightly used (<60k miles) long block that has good compression/leak down and swapping that in. His fear is something else going on inside the block or head that will cost way more to fix than just replacing a few parts. My AMB engine has 150k miles on it but all 4 cylinders are above 170psi and less than 10% leak down. I NEVER plan on going beyond my FT F4L at 20psi peak boost. Any recommendations which way to go?
Parts if I rebuild my block:
IE forged con rods (19mm wrist pins)
calico coated bearings
stock (keep old ones) pistons
stock (new) rings
rebuild my head:
Supertech SS nitride coated exhaust valves
stock (new) valve guides
stock (new) stem seals
stock (keep old) springs/retainers
stock (keep old) intake valves
