Results 1 to 33 of 33
    Account Terminated Four Rings
    Feb 26 2011
    las vegas
    Converting my sedan to widebody, is 3k$ for the work a good quote?
    If this sounds reasonable, I will get it in the shop and post pics of progress.
    And on a sidenote, does anyone know where I can pick up the rs4 side skirts?
    Senior Member Two Rings tekazgtr1984's Avatar
    Oct 31 2011
    '95 BMW 740i
    Winnipeg, MB
    Sorry to threadjack but what's involved in making it a widebody? Custom fenders and quarter panels but anything else?
    '00 S4 6-spd
    '95 740i
    Feb 26 2011
    las vegas
    rear doors pulled, front and rear bumper pulled, cutting the fenders and welding new steel on.
    Veteran Member Four Rings howardfootball's Avatar
    Oct 20 2010
    '57 Ford Thunderbird
    MD
    A sh*t load of body work and a healthy wallet.
    Veteran Member Four Rings Sole_'s Avatar
    Oct 29 2009
    Or if you're good on your knees.
    Imola<3
    Sep 17 2005
    Fremont, California
    EDIT: ok, now I see its not an RS4 widebody... nevermind. Good luck with that; if the shop is doing actual custom fabrication, I'd expect the bill to go up.
    Quote Originally Posted by itguy View Post
    If thats a real quote, thats a stellar price for installation. People have paid considerably more just to integrate the rear quarter panels, let along getting the rear bumper to flare, swapping doors, etc.
    Veteran Member Four Rings belinko's Avatar
    May 09 2005
    Audi 1.8T QM
    Encinitas, CA
    I don't think that for $3K a competent shop would even touch an S4 wide body conversion. This sounds like a hack job.
    I realize that you're doing a "custom widebody" and not an RS4 conversion, but $3k/$60 per hour = 50hrs. If this shop thinks that they can cut, pull, weld new metal and paint for $3K I think they're a little optimistic. A decent respray with no body work is $3K.
    1.8L, JE pistions, IE rods, APR stg3+, GT28 Turbo, Setrab, ER comp. FMIC, APR HFC, Milltek Cat-back, APR 91, 93, 100 - CM FX 300, CM 240 LWFL, JHM 4:1, AMS SS, RS4 Motor Mounts - 355mm Alcon 4 pot, 300mm Alcon S4 - Stasis/Ohlins MS, Hotchkis Front and Rear, Stern adj. CA Front, 034 adj. CA Rear - 18x8.5" Work CR Kai wheels, NT-01 & Dunlop Z1 star spec - RS4 Front bumper and grill, Tow Strap, RS4 E-codes - SPA Technique Dual Digital gauges Oil & Water temp, Oil & Boost pressure, RS4 Door Handles
    Feb 26 2011
    las vegas
    Quote Originally Posted by belinko View Post
    The shops rep is not in question here, as long as you think 3k$ is a good price for this (does NOT include spray) then ill move on it. Thx!
    Oct 31 2011
    '95 BMW 740i
    Winnipeg, MB
    Quote Originally Posted by howardfootball View Post
    Looks like it... Yikes. I noticed Achtuning has the full kit available for $12K. Damn, that's steep!
    '00 S4 6-spd
    '95 740i
    Veteran Member Four Rings Fourplay's Avatar
    May 01 2010
    Atlanta
    Bumpers pulled? Don't you mean RS4 bumpers installed front and rear?
    Senior Member Two Rings tambat's Avatar
    Sep 04 2007
    Chicago, IL
    i'm kind of confused on exactly what you mean by widebody here. a true rs4 widebody runs close to 10k in labor at a reputable shop. your list suggests you won't be going that route. like fourplay said, no new bumpers? i can't believe you can actually go widebody using stock bumpers. rear doors pulled? how is that possible?
    B5 S4 K04'd + (sold)
    can't seem to leave
    Feb 26 2011
    las vegas
    The above should answer your question. Also, I did not say I was doing an rs4 conversion, I only asked where I could buy rs4 side skirts.
    May 13 2011
    2015 BMW F30
    If you think it will look good, go for it.
    | Autospeed | JHM | Pure MS
    May 09 2005
    Audi 1.8T QM
    Encinitas, CA
    If someone in Cali can do this type of "custom wide body" conversion for $3K PM me his info, I'll drop off my car.
    You can purchase the OEM RS4 side skirts through various vendors: OEM plus, Avalon motorsports, GMG, Europrice, 034 motorsports, 2bennet racing, etc. Nobody lists prices, so you'll have to call them. I think the price range is from $1500-2000. Given that just the OEM S4 side skirt conversion from an A4 to S4 costs $1000.
    Good luck with your build. Keep us posted.
    May 01 2010
    Atlanta
    What happened to your headlights?
    Senior Member Three Rings A4-B6's Avatar
    Nov 09 2009
    2011 S5 Prestige Briliant Blk/Pearl
    N.CALI
    And I'll be third in line. That picture works for me.
    KM
    SOLD
    Nogaro 2001.5 S4
    JHM built
    12.1 @116 MPH
    2011 S5 Prestige
    https://imgur.com/a/YKQww#0
    Fast Intentions exhaust, Euro tail lights, RS5 front grill w/fogs, JHM 382mm BBK, Lightweight disc x4, JHM tune, VOLK G2's, JHM Stage3 clutch, JHM Supercharger kit, JHM HFC's.
    Veteran Member Four Rings 1dopea4's Avatar
    Aug 03 2010
    joliet IL
    hell, for 3k i'll take a trip from chicago to cali for that :D
    Senior Member Two Rings YnotS4's Avatar
    Jun 22 2008
    S4
    Chicago
    Quote Originally Posted by 1dopea4 View Post
    agreed I will road trip also. I figured 2k to 2.5k for paint alone.
    Stage 3 VAST TUNED / EV 14 injectors/ ported intake/ ARD bi pipes/ VAST meth/ h20 / AWE ICs / APR DP / AWE Twin 2 / VAST EFK /
    034 SLFW / 17Z w 300mm rear/ 2.0 CP ICM delete/ plus other stuff
    11.92 @ 122.07 with 1.6119 60ft .
    Oct 06 2004
    Minnesota
    Pass. 3K wont do it.
    Instagram r_michals
    '12 Q7 TDI- Glacier White
    Senior Member Three Rings hellrot98m3's Avatar
    Dec 21 2009
    i think you better keep about double that in the bank just incase
    Sep 04 2007
    Chicago, IL
    Quote Originally Posted by YnotS4 View Post
    no paint i think
    can't seem to leave
    Apr 06 2011
    MA
    I'm with everyone else on this... 3k seems low, but if it's true, sign me up.
    Feb 21 2011
    WA
    It's not like I've actually gone NB -> WB but 3K doesn't seem like too short on the labor of taking an S4 NB -> S4 WB. He's not talking about lumping in 10k worth of OEM RS4 parts, at the most he's talking about sideskirts and not factoring that into the price.
    Now, if that was 3k w/ paint I'd be a little concerned that you're getting the maaco treatment, but if it's 3k for some body work that sounds like a good homie hookup. I have a buddy who will do the work for less up here, granted, it's going to be shit, they've never touched an Audi and I'd never let them touch paint but it's still in the ballpark of what OP is looking at. Same buddy had his shop straighten and repair another friend's totaled front-end collision S14. Sure, the thing will never evenly burn tread again but 1500 to get it back on the road was a great deal.
    Veteran Member Three Rings TheDarkness's Avatar
    Jul 13 2008
    15' A3 2.0T , b5 S4 Stage III
    Gawd, who has the coin to do that!?
    2001 Stage III Pearl White B5 S4: Frankenturbo F21s | Iforged Flux | Solo Motorsports Dyno Tune | Bosch EV14 52#
    2015 A3 2.0T 8V Mythos Black: KW V3s
    Marin, Ca
    3k is about $16,000 less than what I paid for my widebody conversion...
    -Tony
    '68 Datsun 520
    '71 2002 Tii
    '22 Mercedes-Benz Sprinter
    '22 RS6 Avant
    '20 L405 RR P525
    Veteran Member Four Rings jasonsowers's Avatar
    Feb 18 2007
    Denver, Colorado
    Quote Originally Posted by CARTEL View Post
    I am soooo excited to see what a 3k wb looks like.
    That's close to what I paid for my rs4 bumper, front reapray, and labor.
    3k is going to be a major fuck job with bondo and rattle cans.
    2002 B5 S4 Laser Red Avant - Tial 605 EPL tuned
    2000 B5 S4 Brilliant Black - Stage 3 K04/RS6 hybrid sedan EPL tuned
    2006 Cayenne Turbo - Stage 2 EPL tuned
    2006 Audi B7 A4 Avant 2.0t 6mt - Stage 2 EPL tuned
    2013 Phantom Black Pearl Effect 3.0t Q5
    2014 Monsoon Grey SQ5 - Stage 2 EPL tuned
    Veteran Member Three Rings davenew's Avatar
    Jan 20 2006
    VA
    Yea, I was told just getting my rear bumper modified to work took a ton of manhours.
    2000 Widebody S4, 41k miles, ASP GT2860R "-5" kit. EPL dyno tune: 575whp 93+meth, 600whp E85, 650whp E85+meth (2.36 sec FATS) (sold)
    Veteran Member Three Rings Number54's Avatar
    Dec 04 2007
    Switzerland
    Live everyone says, hard to believe anything with only 3K labor will be good quality. Just way, way too little money.
    Aug 29 2009
    London
    Is that includes the parts? as $3k thats very low I done my car about 5000 pounds including the paint and parts.
    AUDI A6 C6 3.0 TFSI MRC tuning stage 2 package plus Milltek Sport cat-back system
    Traffic Exchange Site http://www.24-7-traffic.com/
    Feb 26 2011
    las vegas
    This includes no parts, I would be providing all the parts. 3k$ is for cutting and welding new metal on the fenders and flaring the front/rear bumper.
    Quote Originally Posted by Nez View Post
    May 16 2008
    South Texas
    Sounds way cheap. I'd be VERY Leary...
    Veteran Member Four Rings NishadJoshi's Avatar
    Apr 22 2010
    Playa del Rey, Ca
    You're in Cali too OP, can you PM me with the shop down to do this?
    derp.
    Active Member Four Rings nthusiastt's Avatar
    Oct 27 2008
    B5 S4 Avant
    Just reread... That's dirt cheap. I'd get everything in writing, have a good attorney on hand, and be prepared for lots of stress.
    Here's what you should do. Find a single person who you've seen his work and can confirm it. If he won't do it on the side keep looking. I cut about 5k off my final bill by cutting out the shop overhead and paying directly to the guy responsible for my end product.
    They want you afraid of your neighbors, your community, your family, your ability to support yourself, terrorists, climate change, China, Russia, Covid. As long as you are afraid, and won't unite red or blue, they win.
