Results 1 to 40 of 74
    Deactivated Four Rings Kay15's Avatar
    Jun 12 2009
    Audi A6
    Norway
    APR Stage 2 Tune and Shifting/LC issues hmm?
    So I have had everything fixed and the road adaptaion was done about 250kms of adaptation was put on just to smooth out the shifting points. I also did that for about 45min on my drive back home. But as soon as I flipped into a diff map I tried the LC off the red light the revs would jump to about 3900 just under 4k. I found it odd but when I was in stock mode it was at 3K. So I tried a few diff mixes to see if it was constant to the ecu maps when the revs would change.
    Now i have noticed on STOCK mode launch control lifts off at 3k no problem right when I left off the brake the car goes. On any tune the cars RPM for launch moves up to just under 4k to about 3900k and lags when the launch kick in a much softer launch. When I mean any tune I left the car at the dealer with 60kms left in the reserve of 91 they had to top it up with 20 dollars of 94 to do the road test when I got it had only about 80kms left in the reserve I went topped up on more 94 flipped over to the 94 program and gave it about a 15min drive around and I feel the power it is there but the shifts are short of red line. I did the LC with ASR off and ASR and ESP off it lifts to 3900 and when I let off the brake it has almost a 2 second delay! When in Stock mode when you flip back to stock do it with either ASR off and ASR and ESP off it it goes only to 3k rpm and as soon as you left off it kicks but it short shifts when you use LC but if you are rolling in first gear and punch it it shifts at redline but between 2-3 it short shifts at about 6600 rpm but 3rd shifts at red and so does 4th. When the Tune is on the shifts are always about 6700 always just short of red line.
    Now I am wondering if anyone else notices that the LC revs go up when the tune is on and if in stock mode the revs stay at 3K and if that is the case what is the reason for this? Why is there such a variation in the launches. Note it is not the Stage 2 itself it is with the tune all together because I had the same problem before but never tested it to this extent and thought it maybe because of the tranny faulting as I would never use LC in stock mode ever anyways.
    APR? .. Anyone else notice this?
    Just so everyone knows it is the 2011 Audi S4 with Sport Diff with Stage 2 intake pipe and muffler delete with upgraded Pulley from APR.
    Brand new Mechatronics was put in and I still cannot figure out why the launches are so much more effective off 3k and there is almost a 2 second delay when they rev at just under 4k. I will also try keeping the revs around 3k preventing them to stop form going all the way up I notice I can kind of dictate that with throttle position as well instead of hitting the kick down or not hitting the kick down. Clearly there is a problem or a difference here but I cant figure out what or why.
    Active Member Four Rings clochner's Avatar
    May 11 2010
    Chicago, IL
    Yep, myself and several others have noticed this. Bottom line: the APR Stage II tune alters LC in two ways - (1) revs go up to around 4k as opposed to 3k w/ stock, and (2) the launch itself is significantly diminished from what stock can do. I prolly won't even use LC anymore, as there is NO WAY it is more effective than just slamming on the throttle. I tried bringing this to Arin's attention in a separate thread but got shot down pretty quickly.
    B8 S4 - tuned.
    Stage 2 Banner Advertiser Four Rings Arin@APR's Avatar
    Aug 23 2008
    Auburn, AL
    The stock Engine Control Unit has a standing revlimiter.
    The stock DSG Transmission Control Unit has a standing revlimiter.
    The stock 6MT does not have a Transmission Control Unit so it does not set a standing revlimiter.
    The APR Tune sets the ECU standing revlimiter to redline so you can rev to whatever RPM you want.
    Do DSG customer want the standing revlimiter set to stock?
    This will prevent future DSG TCU software from setting launch control higher.
    GoAPR.com | Facebook | YouTube | Twitter | Instagram
    Phone: (800) 680-7921 Local Phone: +1 (334) 502-5181 Fax: +1 (334) 502-5180
    Address: APR LLC, 4800 US HWY 280 West, Opelika, AL 36801
    May 11 2010
    Chicago, IL
    I wouldn't mind if the car continued to launch @ 4k as long as I get the same kind of "kick" that I got w/ stock (hell, even APR Stage I for that matter). The real problem is that the effectiveness of LC has been significantly diminished since installing the Stage II ECU. The car simply doesn't launch like it used to when engaging LC.
    Is it possible that the Stage II tune is hitting the DSG's maximum torque/power potential, and thus the TCU is automatically diminishing the launch b/c of this?
    B8 S4 - tuned.
    Aug 23 2008
    Auburn, AL
    Launch control doesn't actually product any real load on the engine before launching, so if there is a 2 second delay before it actually does anything, I don't see how the TCU could be hitting a limiter, shutting down power.
    As always, we'd have to log it and see what's up.
    Senior Member Two Rings misc720's Avatar
    May 04 2009
    socal
    Quote Originally Posted by clochner View Post
    I'm curious, if you engage launch control, but then use your foot to modulate the throttle and bring revs down to 3k before releasing the brake, do you get that old "kick"? If so, then maybe the solution would be as simple as Arin says, just reflash the ECU standing limiter to 3k. If not, then maybe there's something else going on here.
    As Arin said, log it!
    May 11 2010
    Chicago, IL
    Quote Originally Posted by misc720 View Post
    I can definitely try this when I get a chance, although it may be hard to time it correctly to launch @ 3k. And I'm not sure if it's possible to bring the RPMs down to 3k once it has already revved to nearly 4k.
    B8 S4 - tuned.
    Aug 23 2008
    Auburn, AL
    Just put your foot on the gas slowly and bring the revs up to 3K.
    Oct 14 2011
    Chicago
    Quote Originally Posted by Arin@APR View Post
    I've tried doing this, and it makes no difference...launch control is still pretty useless.
    Aug 23 2008
    Auburn, AL
    Strange. I don't think any of the DSG's we've had here even had launch control. :/
    May 27 2010
    2010 Touareg, 2007 Jetta GLI
    Vancouver, Canada
    I ran at the track with both the stock motor and with stage 2+ 100 oct file. 60 ft time was only fastest when the revs started to fall because staging took too long. Launch was much more violent that way than it ever was with the 4000rpm launch.
    Arguably the best 60ft times with LC were with launch control.
    Would be nice to get the extra few RPM's up top but the changes with the LC are definitely detrimental.
    I think having the standing limiter at 3k (if that will in fact change things) until the time that HPA releases a tune that changes the parameters of the TCU.
    2007 VW GLI - AWD Conversion, a diet and 600+HP coming soon - Racing @ 2014 Pikes Peak Hill-Climb
    2011 Audi S4
    May 11 2010
    Chicago, IL
    Interesting experiment: use my new dynolicious app to record 0-60 times for stock LC and Stage II LC (assuming, of course, that stock mode's LC is not affected by the Stage II ECU). I may just give it a try this weekend.
    Arin - if you have a chance, try LC on both a stock car (or even w/ APR Stage I) and a Stage II car. You'll notice the difference we're talking about.
    B8 S4 - tuned.
    Jun 12 2009
    Audi A6
    Norway
    I tried it by slowly bringing the revs to about 3k it takes about 60% throttle give or take and it does nothing same useless delay no kick that it why any other car with AWD is taking off the line on me and cars taht squeel are right there next to me out of the dig. I even tried to time it to the lights counting 3 seconds it takes on yellow to go and letting off on it a little earlier to see if it is more effective but requires timing.. Nothing it is hard to time and it is almost you are standing still for 2 whole seconds that is a big difference!
    I just spent 2hours finicing with it I dont have any way to log it no vag cable or anything but it really blows I thought it was the tranny all along to some extent probably still is for the red lining but the useless Launch Control gives us nothing I think we may get better response by just flooring it but I dont have a way to meassure times and in that case I would rather a standing 3k hold as stock.
    DONT tell me I got to send the ecu back again :( ... FML!!!
    Aug 18 2008
    Florida
    I'll chime in on this as well.
    It seems to be something that happens over time.
    I had my car flashed on a Monday (drove about 1500 miles that week)
    Took it to the track that friday, make 15 passes with launch control always launching at 3k.
    1 week later, I tried launch control, and now it did the same thing, revs up to nearly 4K, and when you let it off, it sort of slowly rolls out, rpm's fall and then it catches.
    Oddly, I made zero LC passes between the track and the last time, almost like something just decided to switch over or adapt.
    FWIW, launch control doesn't seem to help anyone anyway, Ron's cutting a 1.6 now with his patented 1-2 mash.
    I tried it a few times and got the hang of it with much wheel spin on the street, which is promising.
    When I make it back to the track, i'll just stick with Ron's launch until someone comes out with a updated DSG flash.
    '24 RS3 Daytona Grey Pearl
    Aug 23 2008
    Auburn, AL
    Hmm... If it happens over time, can someone clear ecu codes (even if none exist) and try lc right away? Try the same with the dsg controller.
    Veteran Member Three Rings FourRingRider's Avatar
    Nov 04 2008
    911 Turbo
    Jacksonville, FL
    Arin, I just had my ECU there earlier today for the loaded stage 1 tune and it is currently in transit back to me via next day air... I am seriously hoping the tune doesn't change the LC behavior. This was a specific question that I previously asked Ryan about early on and was told that the tune does NOT affect the LC functionality in any way. I want it to always launch just like it did @ stock 3000 rpm. Please confirm asap before I install... Thanks!!!
    2019 Audi A4 Quattro Glacier White Metallic & Black
    2017 Ford Raptor SuperCab Avalanche Grey & Black
    2016 Bentley Continental GT V8 S Glacier White & Hotspur w/Beluga Contrast
    "Any car that merely takes you from A to B does not go far enough." - August Horch
    Veteran Member Four Rings ilspazzaneve's Avatar
    Jul 18 2011
    Stop teasing us!!
    Nov 04 2008
    911 Turbo
    Jacksonville, FL
    Quote Originally Posted by joneze93tsi View Post
    Which tune are you running... Stage 1 or Stage 2?
    Senior Member Two Rings QSonx's Avatar
    Jan 31 2011
    2013 Scion FR-S, 2016 Audi Q3 Prestige
    Olathe, KS
    Mine always launched at 3k. The day I installed my Stage II it changed to 3900; kind of sucks :-/
    2011 Audi S4 Premium+ Bang and Olufsen | Sport Diff | Nav | Apr Carbonio Stage I/II Intake | APR RSC Exhaust | APR ECU S2+ | APR Pulley | Vogtland Coil-Overs | Alu Kreuz | SPC Adjustable Control Arms | 19x9.5 VMR V710 | Michellin PSS | AWE Vent Boost Gauge
    Nov 04 2008
    911 Turbo
    Jacksonville, FL
    Quote Originally Posted by QSonx View Post
    Were you previously Stage 1? I am curious if this problem is unique to the Stage 2 tune or does it occur on a Stage 1 tune as well???
    Jun 12 2009
    Audi A6
    Norway
    I guess we just leave it as in and get the TCU tune in the works APR we DSG'ers will wait :) I wouldnt mind a 3500 launch :) with better shifting points.
    Cheers haha. 81Bear check your PM!
    Aug 23 2008
    Auburn, AL
    I'm made engineering aware of this. We'll look to see if the standing revlimiter is changed like I mentioned in #3 (I could be wrong). I'll keep everyone updated.
    Thank you!
    May 11 2010
    Chicago, IL
    Quote Originally Posted by FourRingRider View Post
    I used LC plenty of times on Stage I and never had a problem. It launched exactly the way it did in stock. It was only immediately after installing the Stage II that my LC changed. So, I don't think you have anything to worry about.
    Arin: thnx for looking into this!
    B8 S4 - tuned.
    Jun 12 2009
    Audi A6
    Norway
    I think we all agree that APR does great work and if the TCU software gets a little priorty because of this mis-hap we would not mind at all. We your customers do not mind helping push the limits and further testing of your products. Anything to get us the edge over those Bimmers haha =)
    Registered User Four Rings Fonzie@DipYourCar's Avatar
    Oct 16 2010
    Coconut Creek
    i'm stage 1, LC revs to 4k, and slams out the gate fine. +1 for this being a stage 2 only problem
    Nov 04 2008
    911 Turbo
    Jacksonville, FL
    Quote Originally Posted by Fonzie View Post
    Thanks for the info.... My ECU just arrived and I am debating whether I should install it or send it back to APR to have the ECU standing rev limiter reduced to the stock level 3k rpm.
    I don't sit and rev up my engine while parked or in neutral so I really don't even see a need in having the ECU standing rev limiter removed. Maybe I am missing something here?
    I must say I am concerned about what will happen since the standing rev limiter is removed from the ECU w/APR tune, but is still 4k on the TCU. So if and when the DSG TCU Software is brought to market then the TCU standing limiter would be increased therefore wouldn't the LC launch at red line? I think for reliability sake the car should always LC at 3k, unless someone specifically requests differently. I don't fully grasp the technical details involved here so feel free to school me at any time.
    Nov 04 2008
    911 Turbo
    Jacksonville, FL
    UPDATE: I just spoke with Arin @ APR and he is looking into the current values set on the SRL (standing rev limiter) with the Stage 1 program, etc. He said he believes that the SRL was not modified on Stage 1 (so that dealers couldn't simply rev the engine in neutral to detect if the car is chipped) but he wants to check with engineering to be 100% certain. At this point he is waiting for a response from someone in engineering to look at the SRL values set on the Stage 1 tune. He will be posting the answer here shortly...
    Jan 31 2011
    Olathe, KS
    Nope. I went from nothing to Stage II
    Established Member Two Rings r32breeze's Avatar
    Sep 17 2010
    2011 Audi S4
    Seattle,WA
    Subscribed.
    Aug 23 2008
    Auburn, AL
    I got word from engineering, the standing revlimiter is not altered on either ECU (Stage 1 or Stage 2+) (6MT or DSG).
    Are people reporting this behavior on stage 1 or is it only stage 2+?
    Veteran Member Three Rings DATZ's Avatar
    Oct 17 2010
    Northern NJ
    I've said this in other threads before, but my launch control changed from 3k to 4k BEFORE I had any APR software. I went straight from no software to Stage II, but my DSG had been launching at 4k for weeks before APR ever touched my car. I think this is an Audi TCU issue, not an APR issue. The 4k launches definitely arent as violent as the 3k launch.
    2015 S4 - Sepang Blue - 6mt - Black/Silver Nappa - Sports Diff - Black Optics - B&O - Tech Package - Carbon Atlas
    Bilstein PSS10 - Milltek non res - Eurocode sways/links/AluKreuz/STS - StopTech Trophy 380mm BBK - APR intake
    Aug 18 2008
    Florida
    Quote Originally Posted by DATZ View Post
    Nice,
    Probably something that was just going to happen anyway..who knows.
    We need a DSG flash STAT!
    Aug 23 2008
    Auburn, AL
    Reports like this make me think something else is at play... Anyone else experience this? Not many people have LC if I remember correctly... We'll all need to investigate further.
    May 11 2010
    Chicago, IL
    Interesting. I used LC probably 20-25 times with stock and Stage I (about half w/ both), and the car consistently launched at 3k every time. IMMEDIATELY upon installing the Stage II ECU, however, the revs jumped to 4k and the launches have been WAY less "violent" (i.e., effective) ever since.
    Adding another wrinkle into the mix is Fonzie's car. He confirmed again today that his car (Stage I) launches at 4k but is no less punchy than it was at 3k. Strange . . .
    B8 S4 - tuned.
    Nov 04 2008
    911 Turbo
    Jacksonville, FL
    Just got the ECU installed, selected the 93 tune. Drove around for 20-30 to allow the tune to somewhat adapt. Then tried out LC, it immediately noticed it revved to 3800. Something in the tune causes this to happen, as I have used LC 5-6 times in the last week prior to sending my ECU to APR and they all perfectly launched from 3k.
    Maybe it's all in my head but the launch doesn't feel as hard as the original 3k launch. Still effective, but something seems different. The original LC would give me a second or two of the funny gut feeling like when taking a steep drop on a roller coaster, I don't really feel that anymore.
    Here is a video of the launch...
    http://youtu.be/4kzYJpIdDL4
    Oct 14 2011
    Chicago
    The launch issue is definitely tune related. As an experiment today I switched back to "stock" mode, and the car launched at 3000 rpm...and it launched just as hard as I remember it from before the stage II tune. I then switched it back to the 91 tune, and it revd to about 3800 and launched like a scared little school girl.
    Active Member Two Rings hbm5006's Avatar
    Aug 02 2011
    NH
    Damn, I'm really reconsidering tuning in the near future. Can anyone with another type of tune(maybe stasis?) comment as well. It would be interesting to see if this is being seen across ALL chipped cars, not just APR chipped cars.
    We gotta isolate this, and fix it, so I can buy my APR tune
    May 11 2010
    Chicago, IL
    It's not in your head - the impact of the launch undoubtedly diminishes w/ the higher revs. BTW - you're short-shifting in manual mode. Just keep it in "auto" mode and then floor it after you launch. Should take care of the short shifts. LC does not require you to be in manual (just ESP/ASR off, and in dynamic).
    B8 S4 - tuned.
    May 11 2010
    Chicago, IL
    Quote Originally Posted by hbm5006 View Post
    ALL chipped B8 S4s = APR-chipped B8 S4s.
    B8 S4 - tuned.
    Jun 12 2009
    Audi A6
    Norway
    It is tune related because if it was not then in stock mode it would remain at 3800 rpm.
    Arin what would you like for us ot look at or check for to help? I can try meet up with someone to search the car for codes but not sure when though but what would we be checking for.
    So clearly the Stage 1 and 2 maps have not removed the SRL ? That is confirmed so that means something else is at play because its causing the remap to cause this hmm.. Have we looked into if the TCU can re limit it or what the TCU is reading when the stage map is on do we see any shifting properties or limiters changed?
