Results 1 to 40 of 74
    Veteran Member Three Rings 05A$SE's Avatar
    Feb 12 2008
    05 A4 1.8T Special Edition
    Dirty Jersey / Phoenix
    05A$SE BAT Build Thread
    Hey all,
    So as the title states I'm joining the BAT/built crowd.
    What I'm starting with:
    2005 dolphin gray A4 1.8T 6MT special edition
    100k miles - I've had it since 32k
    -currently-
    GT2871r eliminator
    ATP large inlet tip (stock maf)
    550 cc inj
    Revo BT
    Full custom exhaust w/ wideband
    Fmic
    B5 S4 brakes
    ST coilovers
    Stage 4 OFE SS clutch -south bend w/ 12lb flywheel
    Build:
    AWD block-
    FSI 2.0 crank
    H-beam forged rods
    Mahle 83mm
    Full arp hardware
    Calico bearings
    AEB head - ported and polished
    Ferrea valvetrain +1mm
    QED purple grind cam
    Full race exhaust manifold
    Gt3582 hta fp
    Custom intake manifold
    Custom fmic setup
    ID1000 cc inj
    Maestro tuning suite
    Aeromotive fpr
    034 fuel rail
    Full -6an braided lines
    034 high output in tank
    Bosch 040 inline w/ surge
    *******will add as time goes on ********
    Drivetrain: to be announced
    2005 DG On Black Special Edition 1.8T 6MT
    Built 2.0L Stroker, ETC
    2012 C63 AMG - 600HP and counting
    2006 Corvette - GTR (1 of 7) - Blue One on GOOGLE
    1998 H1 - AM General 4dr Hardtop
    1992 M998 - Slantback Project
    1990 240SX - big turbo drift missile
    1989 K1500 - LQ4 6L90 Swap
    1986 RX7 - Truck conversion, LS1, 72* angle kit
    Feb 12 2008
    Reserved for continuation
    Feb 12 2008
    Reserved for continuation part 2
    Feb 12 2008
    Reserved for continuation part 3
    Feb 12 2008
    Reserved for continuation part 4
    Feb 12 2008
    I'm almost ready to take my block to the machine shop but was wondering what clearances others have run when they had there motors assembled/machined. I'm running forged pistons, I've heard 0.003"-0.004" piston to wall. I'm planning on making big power and want the motor to be solid, however in the class I'm in at school suggests running a larger clearance due to the high expansion rate of forged pistons. I'll take any help or input! I know a bunch of people on here have done the 2.0 build, what did you guys have done and how'd it turn out?
    Veteran Member Four Rings Wet0willy01's Avatar
    Nov 17 2008
    05 A4 USP, 00 S4, 01 A4, 16 A3
    Veteran Member Four Rings AudiHere04's Avatar
    Nov 21 2005
    568HP%20FWD%20A4
    East Coast
    Looks like a good start.
    Buy My Parts!
    Precision 6262 Turbo needs a core - $800
    B6 Thule Evo Roof Rack - $300
    Veteran Member Four Rings vintagespin's Avatar
    Sep 15 2008
    CO
    Quote Originally Posted by 05A$SE View Post
    It depends on the piston and the alloy used. Look in Audi Skate Snow's build thread, they are discussing this very topic right now.
    http://www.audizine.com/forum/showth...=1#post6995434
    2005 Dolphin Grey A4 1.8T Quattro 6-speed Sedan
    Veteran Member Four Rings RLB6's Avatar
    Sep 20 2006
    '05 MV Agusta F4-1000
    MD
    With Mahle pistons (4032 alloy), you can run anywhere between .0015 - .0026. I say split the difference and run .0020 to be safe. This will provide a quite motor, essentially no piston slap, and reduce oil consumption.
    Current: '23 etron-GT | Prestige
    Previous: S5 | Prestige
    Dec 14 2004
    Norway
    I would change the cams to IECVA1, wait getting the turbo; maybe the twin scrolls EFR are available before you finish your build, and start looking for a 01E drivetrain swap.
    2002 A4 1.8TQ 5MT - Build thread
    - Fully built 2.0T w/ EFR 6758, built and custom tuned by forum member Bische
    - Bilstein PSS9 coilovers, H-Sport S4 sway bar kit
    - B6 S4 brakes F/R
    Nov 17 2008
    Quote Originally Posted by Hansi View Post
    I'd tend to agree.
    However your build plans are very simular to what I have done (Less the 2.0)
    -Andrew
    2005 Dolphin Grey Ultra Sport
    630AWHP HTA3582R 1.8L 93+ Meth
    Before camber and tire stretch, there was horsepower and performance.
    Veteran Member Four Rings MmmBoost's Avatar
    Nov 29 2005
    10 A4 Avant S-line, 07 Suzuki GSX-R600, '69 VW Beetle w/ 1.9L aircooled turbo
    Edmonton, AB
    I hope you've done your research on what you're getting into with Maestro. It is not for the impatient or the faint-of-heart
    ~Chris
    I sold my Audis and bought a Touareg... Catch me over at Club Touareg
    My B6 Avant GT2871R build
    Tumblr
    "Robert Bosch don't fuck around"
    Feb 12 2008
    sorry i didnt make it more clear, i already have all the parts listed above! 01E might be where i end up as far as a tranny but im doing some more then that with the rest of the diffs/axles/etc.
    vintagespin and RLB6 - thanks! just what i was looking for, mahle's website kept leading me to dead links with 404 errors , somewhere around .020ish is probably where ill end up, most likely no less then that.
    mmmboost - ive done some poking around into maestro's forum a little bit, my next class at school deals with ecu tuning before and after engine modification, and a few of my instructors are spot on with that stuff so i have plenty of resource to assist me thankfully!
    i got a decent amount of my stuff from AudiA4_20T. no worries, no internals , theyre all new.
    and been drooling over this CLICKY
    waiting on a few last parts to get shipped! should have this stuff going soon!
    Nov 29 2005
    Edmonton, AB
    Bosch Motronic is not like any other animal out there. Understanding the tuning process and actually knowing what map to change is a whole different story.
    ~Chris
    Tumblr
    Senior Member Three Rings cpu77's Avatar
    Feb 27 2004
    Mansfield Ohio
    I hate noisy forged pistons on startup. Makes me think..... dam did I run it too hard the last time I drove it:)
    Current
    2004 Silver A4 1.8T FWD 5spd Franken Turbo/3"Exhaust/Racewerks FMIC/440cc/Motoza/TestPipe/SAI Delete
    2004 Red A4 1.8T FWD 5spd (Wifes) Mods- Stage 1 Plus APR w/Neuspeed Exhaust/Test Pipe
    2002 Black Porsche 996TT X50 UM Stage2 Z/C k16/24 528AWHP
    1999 Wrangler 4.0 5spd/2.5" Lift 33" Tires No doors No top!(I like driving this better than my 911)!
    Dec 14 2004
    Norway
    Nice.. Looks expensive though
    And probably not necessary at your power levels?
    - B6 S4 brakes F/R
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Quote Originally Posted by cpu77 View Post
    I've never had any issues like that on the two 1.8T motors I've had with forged pistons.
    Build it right and it won't have any issues.
    -Doug
    Feb 27 2004
    Mansfield Ohio
    My only experience has been with a factory 4.6. I had this issue on my 03 cobra.. It came from the factory with forge pistons. It was noisy when cold. They all are. I will let fords SVT division know they can't build engines according to dougyfresh:) I even spoke to some well known engine builders who told me I would need to live with it? Maybe you leave something on the table to not have it? I have no idea as I have limited knowledge. I assumed 1.8ts would sound the same way.
    Current
    Dec 03 2005
    2 pedals 1FG
    connecticut
    You can relay what I said to Ford. I'm cool with that. Maybe they'll figure out how to design and build a real car.
    it's the alloys used in every component in the motor.
    -Doug
    Feb 27 2004
    Mansfield Ohio
    Well I think that can be said about all automakers! Look at our over priced piles. All these little cheap plastic parts. Not to mention the infamous German over engineering. As if making something more complicated makes it better. I see you own a jeep ever done a stroker in a 4.0?
    Current
    Feb 12 2008
    mmmboost - One of my teachers instructing that actual class is a former employee of audi R&D! crazy stuff, would love to be able to get a job like that,
    Hansi - yes!, but hopefully i can source some of the parts from my nissan friends, they tend to "bend up" there 240s alot.
    Dougy - Your knowledge is awesome
    Just a little update - still waiting on engine seals, gaskets, sensors, and the cylinder head to be sent out from NJ to AZ, hopefully this week coming up i can drop off the motor.
    Feb 12 2008
    Finally been making some progress! have been waiting on machine shops for over 3 months to bore the 034 billet mains! Ive moved on and am now sourcing all the odds and ends again!
    Does anyone have a good place to get upgraded manifold hardware? intake and exhaust for aeb setup? or sizes possibly?
    BTW - Turbo setup has changed to GTX3576R, what a beauty! Got the block on the stand and assembly has begun!
    Veteran Member Three Rings 1ScientisT's Avatar
    Sep 30 2009
    Cleveland, OH
    This is where you post pics of said turbo and engine on stand!
    Sep 03 2009
    San Antonio, TX
    Quote Originally Posted by 1ScientisT View Post
    no pics, no proof?
    MY BUILD
    Senior Member Three Rings Hammie's Avatar
    Jan 02 2010
    Miami, FL
    ooh Build thread Fail
    USP WHEELS FOR SALE HERE
    Ocean Blue '04 A4 1.8T/ USP/ stock-ish
    Brilliant Black 2014 S8/ sold
    Oct 22 2005
    Reppin the Mitten.
    Have fun with the 01E... I'll keep an eye out for this swap.
    Feb 12 2008
    Forgot to mention! My Daily driver honda got stolen with my south bend stage 4 in the trunk and my flywheel! So i decided to upgrade to clutchmasters 850 twin disc kit.
    So what's everyones Consensus on this?
    I Wasn't to happy to find this so i installed a piston to check the clearances and i'm not to sure what to think.
    Sep 03 2009
    San Antonio, TX
    With all this big build build accessories, to go cheap on the block seems silly. Looks like a weak point if it even manages to stay together and run. Could lead to a longer deeper crack that could eventually cause a catastrophic failure and ruin all those nice rods, pistons, crank, and other stuff you shucked out dough for.
    Just my $.02...source anew block.
    MY BUILD
    Sep 30 2009
    Cleveland, OH
    I agree. That block is a boat anchor....not hard or expensive to find a suitable replacement!
    Feb 12 2008
    I Talked to machine shop and sourced some opinions through some friends. work is being covered by shop and that block is making a nice coffee table :) possibly a low power application later on in a cabrio or rabbit
    Nov 21 2005
    568HP%20FWD%20A4
    East Coast
    still want the meth?
    Buy My Parts!
    Veteran Member Four Rings Black_Pearl_B6's Avatar
    Aug 11 2010
    Agawam Ma
    I don't think it would be a problem, but do you want to risk all that money and time u have into it
    09 Prestige Package
    Feb 12 2008
    Nope dont want to see all this go to waste. its been almost a year since i purchased the block and started getting everything around.
    With that being said. does anyone have an 06a block in good condition with no damage to it? just looking for block with caps and squirters. thanks!
    Sep 20 2006
    MD
    OP, not a biggie there. Just need to get that area deburred to remove any sharp edges and smooth it out to keep the skirts from getting knicked up. Also, the rings will never come down that far so no blow-by issues there.
    Feb 12 2008
    RLB6 - Not worth it to me, id rather spend 400 on another block then worry about this every day when i turn the key. i understand your point of view however i dont want any issues that could have been prevented.
    STILL LOOKING FOR A BLOCK! PM IF YOU GOT ONE
    Feb 12 2008
    Update - Using My original Block that i had in the car, upon taking it apart found that last year when i had my head redone one of the valve guides was never done properly and had been leaking into cyl 2 causing misfires and popping spark plugs! fun!
    as for the "Boat anchor" block, it is, the Nice new billet main caps from 034 were over machined .040 along with that nice cylinder chip. its useless,
    So with that being said!
    Does anyone have any good info on dual fuel pump installs or pictures of surge tank mounting / wiring etc. thanks guys!
    PS tried search on FP stuff
    Thanks,
    J!
    Nov 21 2005
    568HP%20FWD%20A4
    East Coast
    i have a inline pump if you need it.
    Buy My Parts!
    Feb 12 2008
    Yeah i have all the parts already for the install.
    just curious as to what had already been done for reference thats all. for instance do people run another power wire for there second fuel pump with a relay or they just jump onto stock harness with the other pump? stuff like that. not pumps for sale but thanks anyway man.
    Oct 29 2005
    10speed
    San Francisco, CA
    separate relay
    - Clint
