Originally Posted by
flyfishing
will the JHM tune require downpipes? I just have cat-back ** didn't want downpipes b/c didn't want it louder.
The tune can be custom fitted to your mods (whichever is best); they have about 6 different programs to try out.
Ancientpath
I'm not sure if this helps, but I had the APR tune installed in my '11 S5 and while I did notice some minor differences I certainly wouldn't consider it "night & day" from the stock tune. Everything I've read is that not much will be gained from a tune. I'm curious though what a "beta" tune could do differently considering the same parameters are changed? I'm in Cali and using 91 octane but even with 100 octane mixed to get 93 octane the difference was still minimal.
I'm all ears....
You are right and this is because the S5 comes stock with a solid tune, however, JHM is known to significantly modify over hundred different factors versus the competitors which just advance the timing a bit, remove speed limiter, and accelerator delay.
