Results 1 to 15 of 15
    Veteran Member Four Rings TConklin821's Avatar
    Mar 17 2011
    Binghamton, New York
    Could I get some help on a dumb question?
    Hey all. So I am installing my LED interior lights (courtesy of www.krautoparts.com). I put the lights in the vanity mirror lights, and they look awesome. Only problem is, I can't get the housing back in properly. Is there a trick to getting that annoying metal clip on the side to hold properly? It keeps falling down.
    2001 A4 1.8TQM. Custom catless turbo back, GTRS turbo, 440 green giants, FMIC, custom tune, ECS RA4 clutch + LWFW, short throw, ST coils, 235-40-18 tires
    ^RIP^
    Veteran Member Four Rings seanj130's Avatar
    Sep 05 2008
    Pittsford, NY
    Turn them around, they will stilll be plenty bright
    Best regards,
    Sean.
    Paying someone to install parts and bragging about it being fast, is like watching someone
    bang your wife and being proud to raise their kids.
    Sep 05 2008
    Pittsford, NY
    like make the led face the other direction
    Best regards,
    Sean.
    Mar 17 2011
    Yeah I know, but that wasn't my question lol.
    ^RIP^
    Jan 26 2007
    Bingo, NY
    send me a picture of the part you stuck with - when I had the S4 I put those lights in and had no issues.
    Veteran Member Four Rings Avant Nate's Avatar
    Dec 23 2009
    2001 Audi Allroad 6MT,1999 Yukon Denali, 1987 4Runner
    Boulder, CO
    The metal clip is just on one side right? The other side should have some sort of tab that locks hooks it behind the liner. You may have broken the tab off when removing the light. I've dropped hundreds of headliners and sometimes shit breaks.
    99.5 1.8T QMS: GT2860RS .63 T3, PSI T3 Mani, Turbosmart 38mm EWG, Unitronic 415, Forge 007,Treadstone TR18 FMIC, Walbro e85 450, FSI coil conversion, 3" DIY Magnaflow/Dynomax VT exhaust
    Depo ecodes, DDM slim 6000k, VDO boost gauge, PLX AFR, Greddy profec B EBC,
    H&R sport springs, 034 rear sway, 034 rear diff carrier, A8 fronts,18x8 OZ Superleggera
    Next up E85, efr 7163 or gtx3071r?
    01 allroad 2.7t 6mt, GIAC stage 1
    Mar 17 2011
    i dont know what to do with this clip
    ^RIP^
    Dec 23 2009
    Boulder, CO
    That clip is completely bent back. The edge of the clip should be more parallel to the edge of the light as opposed to perpendicular like it its now. Be careful trying to straighten it as it is likely to break. Looking at the picture it should look like an upside down U as opposed to a D. Does that make sense? When you take the light down, you insert a little pick to compress the spring and it pops right out.
    Dec 05 2007
    Krazy Glue. That's what I did.
    Mar 17 2011
    So I should bend that clip down? I'll see what I can make happen.
    ^RIP^
    Jan 26 2007
    Bingo, NY
    You gotta bend that clip down - then glue it or wedge something in there. It basically lost its "compression" since you bent it backwards. If you have the one on the passenger side take that one out and look at it, it'll show you what it's supposed to look like. I had that same issue with mine in the S4 and it was a PITA....once you bend them that far the wrong way they almost never stay right again.
    Mar 17 2011
    Krazy Glue it is.
    ^RIP^
    Dec 05 2007
    Use the liquid one that comes in the white-out look a like bottle (with brush). It's just way more clean.
    Mar 17 2011
    Where did you apply it? Headliner where it touches the back of the light?
    ^RIP^
    Dec 05 2007
    Yep. Right on the edge where the light would sit, so that the lip of the light held to the headliner. Only solution I could think of, and it works quite well.
