I got the car aligned earlier this year. I'm at 24.25 up front and 24.5 in the back. So obviously pretty low, and I was expecting some premature wear on the tires. When I got it aligned and got the specs back, the guy was pleasantly impressed. He said the rears are at -1.5* and the fronts are at -2.4* camber. He said Audi spec is max at -2.. so I was just slightly over the spec. He said he was able to add just a touch toe and that would even out my wear and shouldn't be that noticeable.
About 15k later, here's where I sit:
Does this seem a little out of place? I get that I'm low. I get some early wear. But an alignment shop telling me I have nothing to worry about just doesn't quite add up either. This is the passenger front tire. The driver side front tire is not as bad, but certainly not awesome either.
I am getting new tires tomorrow, and am going to throw it on the rack again to see where it sits. However, anything I should check specifically that might have caused this. Am I living a pipe dream and this is just going to be standard for tire wear? Or should I consider tie rods failing? Control arms are a year old, and while the suspension is a little clunky over bumps, nothing feels out of place.
