Results 1 to 6 of 6
Thread: Brake lights
    Oct 30 2011
    Pa
    Brake lights
    I have a problem with my brake lights coming on randomly when the cars not even running, when I come out from work they will be on n it's causing my battery to die, anyone have this happen to them or know how to fix it?
    Veteran Member Three Rings plokm's Avatar
    Feb 19 2007
    Louisiana
    i have the same problem too...dont know what's going on
    Veteran Member Four Rings Coderedpl's Avatar
    Jul 27 2007
    Orange County, NY
    Quote Originally Posted by Lildego09 View Post
    Quote Originally Posted by plokm View Post
    To both of you. Buy a new brake light switch and change it out. I had this happen to me a few times with my B7 S4. After replacing the brake light switch, the issue hasn't come back. Forgot the cost but it wasn't bad, i bought mine from the dealer.
    Current: F80 M3 | 2018 Q7
    Past:2018 VW Golf R | 2014 S4 | 2016 Nardo Gray SQ5 | 2012 VW Golf R | 2006 Audi S4 | 2006 A4 2.0T |
    Feb 19 2007
    Louisiana
    where is it located? need the part number
    Senior Member Two Rings 2007B7cabrio's Avatar
    Apr 05 2010
    2008 MB R-320 4-Matic, Toyota Prius
    Weston, FL, USA
    I would check the brake pedal switch first... if it is hanging it would cause your problem
    Crap too slow , sorry,
    Brake switch;
    http://www.ecstuning.com/Audi-B8_A4-...ng/Electrical/
    Jul 27 2007
    Orange County, NY
    Behind and slightly above the brake pedal. When you push the brake, you push the pin. I guess the pin gets stuck or something.
    Here is a DIY:
    http://www.audizine.com/forum/showth...e-Light-Switch
