Thread: Boost
    Established Member Two Rings Howdy3's Avatar
    Apr 16 2011
    2004 1.8T A4, 2011 BMW 328i
    San Marcos, CA
    Boost
    Have searched a bit and can not find anything specific about my problem. I sometimes will be getting on it, and usually I will get to 17lbs and then stay there for a bit. Lately, I've been getting to 17lbs while still getting on it and it will just drop down to about 5-7lbs and just stay there. It doesn't do it all the time but just sometimes. Anything anyone knows? any help appreciated thanks. =)
    2004 A4 1.8T
    GO
    Stage 1, AFE Intake, Forge DV, Neuspeed pulley kit, Borla Exhaust, APR 3" test pipe, Custom FMIC
    SHOW
    18" MSR wheels, H & R, Omori ventpod boost gauge, ECS pedal set, ECS A4 floor mat set
    Jun 23 2010
    Athens, PA
    Maybe limp mode. Could be a boost leak, but doubtful.
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    boost leak
    2019 SQ5 Prestige
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    See if you can pull any codes. I can think of several possibilities:
    1) Something is causing you to go into limp mode.
    2) Your DV is either defective or you have a leak in the vacuum/boost signal line that controls the DV.
    3) Defective N249 valve that is sticking open.
    My bet would be on #2. Take a close look at the control lines from the intake manifold/N249/DV and look for any cracks/splits/etc.
    Apr 16 2011
    San Marcos, CA
    I appreciate the help, ill investigate a little more.
    2004 A4 1.8T
    GO
    SHOW
