Hi,
first of all - this is my first forum thread ever! Been using the audizine forum alot but never posted anything..
Have upgraded front brakes to the 312x25 from the V6 model. (Black Diamond grooved and drilled rotors, Redstuff C pads and OEM v6 carriers)
Car is 2003 A4 B6 Avant 1.8TQ, rear brakes is still stock with stock pads.
Now I am looking to upgrade my rear brakes as well. The idea from the beginning was to use the V6 brakes (255mm) also here.
But I have some thaughts..
After the 312 front upgrade the braking felt slightly stronger on summer tires. The braking bias is pushed a bit towards
the front and gives the front wheels more weight under hard braking.
On winter tires, and especially when its wet, the total stopping power feels weaker than before the upgrade.
The front wheels "locks up" too fast and therefore I think the new brake distribution gives a longer braking distanse because the rears does a smaller part of the job.
(The braking does not give the front enough extra "weight")
In the winter I drive a lot on snow and my braking power will be even weaker compared to stock.
255 mm is not a big upgrade compared to stock 245, and definitely a weaker upgrade than going fron 288 to 312 in front.
So I did some approximate calculations:
Re = Effective radius (rotor radius minus the "average" of the brake pad area, wich I assume is 30mm on both because I dont have pads available)
Stock: Re front / Re rear = ((288/2)-30) / ((245/2)-30) = 1,23
V6: Re front / Re rear = ((312/2)-30) / ((255/2)-30) = 1,29
I looked at this relation because torque at center is linear in relation to radius.
Caliper pressure is kept out because the models use same caliper.
To keep the stock brake bias I would need a rear brake rotor with 265mm in diameter,
but the next OEM a4 rear upgrade is 288mm from A4 B7. Have anybody done this rear upgrade? (I guess the B7 have different caliper)
Is my calculations way out and what is normal to do with the rear brakes after bigger brake upgrade in front?
