as the title says..my rear tires are completely shot after less than 4000 miles, front ones are perfectly fine...but heres what the rears look like
when i hit a bump the rear end feels like it pulls to the side then settles... i got the alignment done right after i got the tires so i assumed that wouldnt be the issue. just changed the upper outer bushings and the sway bar end links (they both had a lot of play) on both sides. it feels like it might be a little better but not perfect...car is lowered on st coilovers. should i assume the place i got the alignment done at did a shit job (one of those cheap 50 dollar alignments) or should i keep searching for the culprit?
