I tried to install my new JHM short shifter and I ran into a really shitty problem. I got everything out until it came to the 6mm allen head bolt that connects the stock shifter assembly to the linkage. Simply put, the bolt is stripped-I can't turn it at all. I've tried using a long extension and putting a ton of pressure on it. I also tried using vice grips on it but it wont budge.
Shortly after I just got the car something happened to the shifter and I couldn't put it into reverse. Not knowing the car well yet, I brought it to the stealership. They basically fixed it and said that a bolt had come loose and they just put loc-tite on it and tighter it. This must have been the bolt they were talking about, so now I know its crazy-glued in.
How the hell can I get this bolt off?
