Results 1 to 2 of 2
    Veteran Member Three Rings hazard860's Avatar
    Aug 22 2011
    1984 gti, 2001.5 s4 (stg3)
    Lebanon, CT
    key fob question
    so im sick of using my valet key, the local dealer says they ca get me a new fob and cut it for $90, i can program it my self with 1 key in door and other in ignition, but they said if i do that only the power locks would work and do have it be able to be a ignition key it my be programmed by a scanner?? true or bs?
    Oct 30 2009
    Miami, FL
    Depends on what year your car is, if it's '00 or higher there's a good chance it has an immobilizer in which case it will have to be programmed to work with your ignition.
