Results 1 to 2 of 2
    Jul 27 2011
    IN
    Suspension Rebuilding>> Parts needed
    Hello,
    I am rebuilding the whole suspension (98 Audi A4 1.8t, non- sport) and following are the parts I am replacing.
    Struts, boots, mounts, coil springs
    Control arm set including tie rod ends and sway bar links
    Is there any other relevant part that I need to replace? ( l don’t know whether I need to replace spring seat and all..)
    Registered User Two Rings SALES@RSW's Avatar
    Oct 03 2011
    New Jersey
    I would recommend doing the upper and lower control arms while you are at it.That way every component in the front end will be brand new. If you are looking for an after market suspension setup like coil-overs or drop spring/shock setup, I can help you out with either of them. We carry almost all companies like kw/st, h&r,anze etc.....
    An aftermarket setup will increase handling tremendously as well as being able to adjust ride height to give the car a better appearance.
    Cheers
    Ryan
