Results 1 to 6 of 6
    Sep 21 2008
    05 B6 Sedan; 04 B6 Avant
    Derry, NH
    So I've been searching for the source for coolant leak .....
    For months, I've been looking for the source of the coolant leak. It's a slow leak and over time, I just lose coolant and the light comes on.
    After an oil change, I decided to take off the engine cover and lo and behold, I found something broken.
    Is that the cooling system bleeder screw? The head on that plastic hex bolt is cut off and I believe that's where the leak is coming from as I can see traces of coolant on the driver side engine block, right around the fuel rails.
    Gonna call the shop if they have a replacement and better yet, a stronger one.
    2oo5 B6 Sedan Q | Dolphin Gray | SE | Platinum interior | 1.8T | Tiptronic
    2oo4 B6 Avant Q | Silver | Platinum interior | 1.8T | Tiptronic
    Nov 11 2010
    Rochester, MN
    Yep, that's what it looks like to me.
    19" B8 S5 Peelers
    Senior Member Three Rings Outerfroggy1's Avatar
    Nov 18 2009
    Newfoundland, Canada
    Pretty common leak.
    Mine was leaking in the same spot and I took it to dealer under warrenty. The tech put a stainless metric bolt in there with a copper crush washer. Smart man.
    Sep 21 2008
    Derry, NH
    Thanks for the replies.
    Going to find that stainless metric bolt. I hate leaks
    Jun 30 2008
    Erie, Pennsylvania
    Here is the official Audi replacement (metal!):
    http://www.ecstuning.com/Search/ES470119/ES470119/
    However, there is a Vin split in 2004 (8E-4-170 000), forward of which this replacement is called for:
    http://www.ecstuning.com/Search/WHT000316/ES472266/
    This corresponds directly with a change to that upper water pipe, so the newer cars (mid 2004+) may not be directly able to switch to that metal bolt/crush washer linked above. They appear to use a plastic bolt with an o-ring seal. The older pipe has since been superseded to the newer one w/plastic bolt. So I'm really not sure on the compatibility here. Both the plastic and the metal bolt are the same M10x1.0 threads (according to ETKA - they actually look different to me in the photos), so as long as that washer has a surface to seal, you're golden.
    Nov 18 2009
    My car is a 2005 and I have the stainless bolt/washer method.
