Results 1 to 7 of 7
    Jul 19 2009
    03 2.7T A6 6MT
    Marlton, NJ
    VAST and EGT Delete
    So in my misfires thread, it also says the left EGT sensor is bad. As everyone here knows, it's a small investment to purchase these replacements and they now want you to buy both. In researching these, I found VAST offers a delete of the EGTs with their ECU upgrade. I'm not racing my car, at least not yet, but if it's not really needed (I do understand it seems to be a safety measure), why not code it out? So I'm looking on thoughts on this. If I just want the EGT delete with the tuned ECU, it's $650. $750 for a host of deletes. VAST ECU.
    Note to VAST: $150 to delete just the EGT???? Man, that must have been one hell of an engineering effort!!
    I've done a search, but didn't come up with much. Seems the VAST ECU generally gets a thumbs up, so wondering if folks have added the deletes as well.
    Feb 07 2008
    The boonies, near Seattle
    I would check out nefmoto, I wouldn't be surprised if you could diy an egt delete yourself with a vag-com cable.
    I won't give any more many to vast, their reputation as of late has been going downhill.
    -dre
    Jan 31 2010
    S-Line A6
    East Haven, CT
    Pretty much ALL the info you'll need is in here. http://s4wiki.com/wiki/Tuning
    Whether you choose to read it and give it a shot is up to you. Spend an hour reading, another hour coding, save $150. Why the hell not.
    Veteran Member Three Rings estomax's Avatar
    Jan 16 2009
    07 A6 Avant 3.2L, 13 Leaf, 08 Titan
    wow that's an awesome link vin, bookmarked!
    if i got an APR flash could i disable the rear o2 myself with the above code tables? or are APR ecu's locked (i assume otherwise someone would just rip the tune and host it somewhere..)
    Jul 19 2009
    03 2.7T A6 6MT
    Marlton, NJ
    Thanks, guys. I appreciate the info. Now, the next question is what's the risk of doing it? Are the EGTs really just a safety measure?
    Jun 27 2010
    2002 Audi allroad 2.7T - GIAC Stage1
    Palm Desert, CA
    EGT prevents the turbos from getting too hot and cooking themselves. Boost is restricted and limp mode goes into effect, once the EGT CEL comes on. I'd pass on the delete and replace them....most likely the last ones the car will ever need.
    Jul 19 2009
    03 2.7T A6 6MT
    Marlton, NJ
    Quote Originally Posted by Zachariah View Post
    That's a good point that I probably won't have to replace them again.
