I want to keep this thread going, a reference for me and you AZer's. Any help would be grately appreciated and in return I will make a video and hopefully a stickied DIY on how to replace the adjuster/housing/tensioner for bank "2"(driverside).
Since I parked the vehicle saturday night with the CEL on(P0021) I still decided to start it to see if it was acting up and to my luck it was not. Still some slight chain rattle at the initial start but nothing out of the ordinary, after that it ran/idled perfectly normal. Not drop in idle and didn't sound like a muscle car. I drove 1.5miles to work and parked it, scanned the computer and got the code(P0021), cleared it and started the engine, slight chain rattle then ran perfectly normal and no light came on. It was also time to top off my oil so I added 0.5qt Rotella T6 and 3/4 can of Seafoam. 1 Seafoam can is good for 10qts but I didn't want to thin out the oil too much so I added a little less. Started the vehicle with NO chain rattle whatsoever and ran/idled perfectly normal. Drove home and the CEL did not come on.
I have been doing alot of research and have come down to the decision of replacing the tensioner and camshaft adjuster but I need to figure out if I can get to the guide and I'm trying to figure out if i need to replace the control housing. From the looks of it, it might also see oil pressure and I don't know how to test it.
I'm thinking about pulling everything apart before ordering parts that way I can figure out how to test the control housing and go from there. Any help or input is appreciated!!
This is a complete overhaul list of timing components. The number in between the parentheses is how many and the cost next to it is the cost of both, not each. Such as the cam adjuster shows 2, one for bank 1 and the other for bank 2. For both it is $975 but if your like me and only getting a code for 1 side then it would be half that. This scared me until I punched in the part number on
www.genuineaudiparts.com, phew!!!
079109087N — Cam Adjuster [2]- $975
N91086201 — Cam Adjuster Bolt [2]- $14
079109210H — Control Housing [Bank 1]- $650
079109204L — Control Housing [Bank 2]- $650
079109092B — Control Housing Gasket [Bank 1]- $3
079109091B — Control Housing Gasket [Bank 2]- $3
079109218D — Chain Tensioner [Bank 1]- $100
079109217J — Chain Tensioner [Bank 2]- $100
079109510E — Tensioner Chain Guide [Bank 1]- $35
079109514B — Chain Guide [Bank 1] $30
079109513C — Chain Guide [Bank 2]- $35
079109469AD — Center Upper Chain Guide- $32
079109469AA — Left Lower Chain Guide- $32
079109510F — Left Lower Chain Guide- $30
079109507G — Lower Chain Tensioner/Guide assy- $58
079109467AE — Lower Chain Tensioner- $44
06E905163 — Cam Position Sensor [Bank 1& 2]- $13 x 2 = $26
079109293C — Hydraulic Controller Seal [2]- $6
079131120A — Coolant/SAP Gasket- $8
079109139A — Center Lower Gasket- $5
079131120B — Kombi Valve Gasket [Pipe 2 timing cover]- $3
078131120K — Kombi Valve Gasket [Valve 2 valve]- $3
079105193 — Diamond Disc Washer [2]- $130
035906149A — Fuel Injector Seal Set [8]- $10
077129717Q — Intake Manifold Gaskets [2]- $70
077198025B — Valve Cover Gasket Kit [Bank 1: 1-4]- $55
077198025C — Valve Cover Gasket Kit [Bank 2: 5-8]- $55
079115111A — Oil Filter Housing Seal [Double O-Ring]- $4
N90959701 — Oil Filter Housing Seal [single O-Ring]- $3
********* — Rear Water Manifold O-Rings [2]- $2
Chains- Optional
079109229 — Timing Chain Center Upper- $98
079109229D — Timing Chain Center Lower- $88
079109229K — Timing Chain Upper Left- $98
079109229L — Timing Chain Upper Right- $98
