    Jul 18 2010
    Newmarket
    any after market quad exhaust could be fited in the RS5 valance?
    anyone has rs5 valance fited? looking forward to mod my A5 exhaust to dual with rs5 valance, wonder if anyone has done it already
    Veteran Member Four Rings UmIsThisThingOn's Avatar
    Jun 03 2009
    1954 Volkswagen Beetle
    Raleigh, NC
    Do you have an SLine rear bumper? If not, you may need to upgrade the bumper or look for another option.
    There's an A4 owner who put an RS5 Valence on his car. You can search over there for more info.
    Edit: Here's his Work In Progress Thread:
    http://www.audizine.com/forum/showth...s-B8-avant-WIP
    Tschüß!
    Šave
    ____________________________________________
    '10 Brilliant Black A4 Sline • Hüper Optik • 034 HiFlo Turbo Hose • EC HFC • Milltek • Alu Kreuz/ÜSS • Hankook V12's • ST-40 BBK
    Jul 18 2010
    Newmarket
    ive seen Dasquades' post~ the exhaust he got is not quite what im looking for.........i was thinking about APR,AWE,Stasis those kind of loud exhausts
    Jul 18 2010
    Newmarket
    and yes, i got sline bumper. will the RS5 valance fits the sline perfectly?
    Veteran Member Four Rings Dasquade's Avatar
    Sep 07 2010
    Belgium
    Quote Originally Posted by zane0728 View Post
    Like UmIsThisThingOn posted, check my WIP topic or my other DIY RS5 valence topic. It more or less clearly shows what you are up for to get the valence fitted. Basicly the valence fits, but you will have a groove on the left and right + you need to give it a bit extra contour in the bumper, at least that was what i did.
    Keep in mind, most exhaust post (especially OEM) will not fit! For example when i mounted my s-line bumper with rs5 valence, my stock exhaust pipes were hitting the underside of the valence hole. So your new exhaust pot will need to have enough clearance to be mounted around 3-4cm higher then normally to be centered. So before you plan to go for the RS5 valence, you better to some research on the exhaust pots you will be planning to install!
    http://www.audizine.com/forum/showth...=1#post6586339
    *Note i had to jack up the exhaust pot to get the bumper on for testing.
    http://www.audizine.com/forum/showth...=1#post6600163
    The post about how i fixed the gaps etc...
    EDIT: Keep in mind this was an A4 B8 avant and not an A5/S5. You might have spotted that black A5 with RS5 valence (and bumper i assume). Maybe you have more room to play around. You might want to compair the bumpers (RS5 versus A5) as there was a +-2cm difference in height on the non s-line versus s-line bumper if i recall.
    S6 C7 avant '13 estoril | ceramics | DS1 OTS stage 2 | Lightvan | Milltek non-res X pipe | TS1 | 034 trans-diff mount | CETE ASC-EVC | FL tails & dynamic signals | Thermo ZO catless DP | SRM a2a | BC Forged 20" HCA162S | custom spoiler sideskirts | Maxton front lip & diffuser | Armor heatshield mani-turbo-dp | B&O led tweets (repli) | Forge boost hoses | FIS mmi gauges | R8GT steeringwheel | alcantara interior | SRM inlets | R8 exclusive seats | JXD driveshaft | Tial WG
