Results 1 to 12 of 12
    Oct 22 2011
    almont/MI
    Question Coolant and burning smell. Just bought it.
    Hey everyone, if ya could help me out that would be appreciated. I just picked up my first s4 on Monday and after 2 daays of driving it I started to smell coolant at stops. And if I get on it I smell burning. Can't tell what to. The car is a 2000 with 97000 miles. The power steering pump is also going on it. I just bought the tb and wp kit with cam and crank seals. Plan on doing that in 4 days. I also have very weak or no heat at times. Anybody have any ideas or experience similar burdens with theirs?
    MechMike
    Active Member Two Rings Speedyj's Avatar
    May 06 2007
    OZ
    you have a leaking cam cover or rocker cover gasket... easily fixed
    Senior Member Two Rings PSUS4's Avatar
    Oct 06 2011
    B5 S4
    Charleston,SC and Pittsburgh
    I just bought my 01 a little over a month ago with 99k miles and I had the same burning smell. I had to change the valve cover gaskets. The kit you got should cover it. Sounds like you know a bit already so you should be good.
    Oct 22 2011
    almont/MI
    I bought the ecs ultimate plus timing belt kit. I don't think it came with it? Where can I get them?
    Oct 22 2011
    almont/MI
    Veteran Member Four Rings bigern45's Avatar
    Sep 28 2009
    B5S4 stage 3, B9S5 Sportback
    ky
    yep, its a B5 S4..
    valve cover gaskets, 2ndary water pump, cam adjusters, coolant passage o-rings, 268.00 power steering pump hoses..
    you name it, it can/will leak..
    RS6 hybrids and corn
    Oct 22 2011
    almont/MI
    I'm definatly happy I bought it. Just want to do all the prevent matinance on it before something major happens. Plus I'm going stage 2+ until my turbos go. But I don't think that will be anytime soon after. The turbos just got replaced at 60k.
    Veteran Member Four Rings s vier's Avatar
    Dec 10 2006
    2015 RS5
    Milwaukee
    Based on your simptoms (low or no heat and burning coolant smell on acceleration) I'd say it's the after run coolant pump under the intake manifold. Mine went and when it did it pooled in the valley and ran back onto the back of the engine and exhaust when I would accellerate from a stop. There may be other issues as well but I think this is a safe first guess.
    2015 Suzuka RS5 Black Optics
    Wings
    Carbs
    Titaniums
    @GERMANBrew
    Oct 22 2011
    almont/MI
    Thats what i thought it would be off the bat. but i cant find a drop of coolant under the intake manifold.
    Oct 02 2006
    Wadsworth,OH
    Only thing our kit doesn't have that others have mentioned is the valve cover gaskets. They are available in a kit HERE
    Of you can find them individually HERE
    Let me know if you have any other questions.
    Jason
    Veteran Member Four Rings DiscoPotato's Avatar
    Sep 16 2009
    Delray Beach, FL
    I might have a PS pump for you.
    1996 A4 - Rolled into the woods
    2001.5 S4 - Stolen
    2001 STG3+ S4 - Sold
    2011 M3 - Blown up
    2017 S3 [11.990 @ 112.38mph] - Current
    Oct 22 2011
    almont/MI
    Quote Originally Posted by DiscoPotato View Post
    New or used. I was going t buy a new one.
