Page 1 of 5 123 ... LastLast
Results 1 to 40 of 184
    Jan 25 2006
    A4 2.0T
    MD
    Took it to the strip
    Took it the strip.. I needz a driver mod, ha .
    ET was MEH, but I was happy with the trap.
    A few notes about the experience:
    1. I never launch the car on the street, so launching the car at the track was a blast. Launch set around 4k, it just gets out hard (but lights up all the tires).
    2. My ET really suffered on the 1-2 shift. The first few runs, I was not hitting the right shift point and coming into second right at or below 4k, which is not ideal.
    Then once I got the shift point better.. I started free spinning the tires in 2nd... , It spun so hard in second that I almost crossed over the center divide on the run I posted the slip for.(I refused to lift ha)..
    The next run. I spun all the way to red line (on the 1 -2 shift).. the type of spin that doesn't move the car.... I called it a night after that. I think maybe I should have dropped tire pressure and that the track needed better prep.
    Hardware wise, the car is exactly as I drive it on the street.. full weight, 93 + washer fluid and meth.
    Veteran Member Three Rings s4andtls's Avatar
    Jul 14 2009
    Ma.
    Nothing broke-good job.
    605.2 Brad tuning now
    Jan 25 2006
    A4 2.0T
    MD
    Quote Originally Posted by s4andtls View Post
    Yes, it feels like its going to cannibalize itself on the launch, but thankfully it held together.
    Veteran Member Four Rings NOTORIOUS VR's Avatar
    Jan 29 2009
    awesome man! feels good to run the car eh? very nice trap speed too, your car is def. moving!
    Jan 25 2006
    A4 2.0T
    MD
    Quote Originally Posted by NOTORIOUS VR View Post
    Yeah it felt great.... I went out with a stage 2 b8 S4 (chip, pulley, exhaust, intake) and a stock b6 S4.... It was a fun night.
    Veteran Member Four Rings UkuRiSh's Avatar
    Jan 09 2010
    New York
    1+
    2013 AUDI S5 4.0T SWAP 9.7@145mph < Press @svarog_performance < last test updates
    Veteran Member Four Rings amd is the best's Avatar
    Oct 05 2007
    '91 200 20v, 01 A4 2.8 PES
    Manteca, CA
    Not bad at all! Quick rundown on mods?
    2012 Golf TDI
    2001 A4 2.8 Avant
    1991 200 20v
    YouTube
    8V Audi S3/RS3 Facebook Group
    Veteran Member Four Rings Korben007's Avatar
    Nov 08 2007
    00 Celica Supercharged, 02 S6, 04 S4 Avant
    Lake Tahoe, CA/NV
    No video? You should be required to have a go pro at the track.
    Current Rides:
    2000 Toyota Celica GT-S Supercharged - 2008 Audi A3 VRT(SOLD) - 2003 Audi RS6 Avant - 2013 Audi Q7 Prestige
    2000 Audi S4 Stage 3(SOLD) - 2008 Audi TT 3.2 (SOLD) - 2002 S6 Avant Manual w/ S8 PES Supercharged - 2015 Porsche Cayman GTS
    1990 Audi Coupe Quattro(SOLD) - 1993 Toyota MR2 Big Turbo(SOLD) - 2001 Audi S6 Sedan (SOLD)
    @audijedi
    Jan 25 2006
    A4 2.0T
    MD
    Quote Originally Posted by amd is the best View Post
    FrankenTurbos + FrankenTurbo manifolds
    RAI 3" DPs
    Tuned by me.
    3" single exhaust
    90mm intake
    52# inj
    Walbro pump
    Jan 09 2010
    New York
    Quote Originally Posted by Don Supreme View Post
    RAI 3" DPs
    Tuned by the Don Supreme
    3" single exhaust
    90mm intake
    52# inj
    Walbro pump
    what kind soft are you using ?
    May 13 2011
    2015 BMW F30
    Good numbers.
    | Autospeed | JHM | Pure MS
    Established Member Two Rings stage3s4's Avatar
    Jul 23 2007
    01 Audi S4 Apr S3+ NOS, 00 RS4
    NJ-GERMANY
    by your 60ft it seems like you had decent traction.
    Veteran Member Four Rings Evilevo's Avatar
    May 26 2008
    2018 TTRS, 2014 Q5 TDI, 2020 Supra, 2022 F150, 2004 V70R
    MD
    Right or left lane?
    Oct 05 2007
    Manteca, CA
    RAI 3" DPs
    Tuned by me.
    3" single exhaust
    90mm intake
    52# inj
    Walbro pump
    Did you got to H2O? If you did, I'm pretty sure we had a little run. I was in my 200.
    I am also interested in what you are using for software. Eurodyne?
    2012 Golf TDI
    2001 A4 2.8 Avant
    1991 200 20v
    YouTube
    Veteran Member Four Rings bigern45's Avatar
    Sep 28 2009
    B5S4 stage 3, B9S5 Sportback
    ky
    good trap, i think due to your 60 you should have hit 11's. but nonetheless, thank you for posting your times/et. ive had many nights in the 12's wanting to be better. i think you will need a street radial at this temp, youre in md, im in ky. im sure the strip here hit 45°. so im sure its just as cold there, which is great for top end and engine work but not for tire hook up. hence slipping in 2nd. im doing the strip next friday, expecting same temps, and WILL be using radials, cause i dont want to have such a "bog or shredd" night at the track.
    RS6 hybrids and corn
    May 20 2004
    More cars
    Never Land Ranch
    Quote Originally Posted by Evilevo View Post
    Right or left lane?
    Look at number on car and then look at number on slip ;)
    SEXICAN
    2013 Q5 3.0T-DD
    2002 Honda Civic
    AMD/EPL Tial 605 B5 S4 SOLD
    Oct 05 2007
    Manteca, CA
    Quote Originally Posted by stage3s4 View Post
    +1
    2012 Golf TDI
    2001 A4 2.8 Avant
    1991 200 20v
    YouTube
    Senior Member Three Rings A4-B6's Avatar
    Nov 09 2009
    2011 S5 Prestige Briliant Blk/Pearl
    N.CALI
    Nice run. Car should go deep 11's with no problem.
    SOLD
    Nogaro 2001.5 S4
    JHM built
    12.1 @116 MPH
    2011 S5 Prestige
    https://imgur.com/a/YKQww#0
    Fast Intentions exhaust, Euro tail lights, RS5 front grill w/fogs, JHM 382mm BBK, Lightweight disc x4, JHM tune, VOLK G2's, JHM Stage3 clutch, JHM Supercharger kit, JHM HFC's.
    Oct 31 2005
    Ashburn
    Nice! Glad to see someone out there getting some numbers!
    - Instagram: @Sinister_rs5-
    Veteran Member Three Rings judeisnotobscur's Avatar
    Apr 22 2009
    America
    trapping like a boss. nice work man!
    u running anti-lag and nls?
    Timing is Everything
    Veteran Member Four Rings Sole_'s Avatar
    Oct 29 2009
    Nice run man! That trap is killer!
    Imola<3
    Jan 25 2006
    A4 2.0T
    MD
    Quote Originally Posted by bigern45 View Post
    That was the best 60', but not my best ET.... why, because as i said.. I spun through second gear into the center divide on this run and the run after that I free spun to red line (in second gear).
    I had to drive through the water box (no way around it), so I launched in the water box every time (which I think helped with the launch), so I seemed to be able to pull most 1.8s, spinning the tires some....
    I lost the ET on the 1-2 shift.
    Quote Originally Posted by Korben007 View Post
    I do have a shitty video of one of the runs.
    Quote Originally Posted by judeisnotobscur View Post
    I used ALS, but I did not use the NLTS. I planned to use the NLTS on the last run, but it was pointlessly free spinning on the shift.
    I don't remember? Same wheels ? How did the encounter turn out?
    no I am not using EuroDyne....grassroots nefmoto ftw.
    May 26 2008
    MD
    Quote Originally Posted by A4-B6 View Post
    Deep 11s? no.
    In the 11s? Maybe.
    Look at his 60'. It is pretty good at a 1.7. If he ran those times and traps with a 2.0 or 2.1 60' then yes I would agree.
    Jan 25 2006
    A4 2.0T
    MD
    Deep 11s? no.
    In the 11s? Maybe.
    Are you reading my posts? I ran a better ET with almost a 1.9 60' (not posted)........ spinning in second is a waste of time.
    Jan 29 2009
    Well I'm going to the track in a few hours... so I'll be posting some results as well.. but I probably won't be launching or beating on the car.. just going for fun this time.
    May 26 2008
    MD
    What was that ET?
    Veteran Member Three Rings DanS4's Avatar
    Oct 03 2008
    01.5 Audi S4, 00 golf Tdi
    Reading, PA
    looks good. It was 40 degrees last night.
    The track is fun
    SOLD Silver 01.5 S4 ; VAST tuned k04s, piggies, ASP exhaust, FMIC, Tracksports, DTS, ...
    http://www.socals4.com/
    Jan 25 2006
    A4 2.0T
    MD
    Launching is half the fun though.
    Senior Member Three Rings slowz32's Avatar
    Nov 23 2010
    Bodymore, Murderland
    @119mph and a 1.7 60' the car def has 11s in it with a clean pass.....
    Established Member Two Rings Audi4952's Avatar
    Oct 24 2010
    2002 Stage 3 Nogaro B5 S4
    Vancouver, WA
    Nice.
    2002 Stage 3+ Nogaro B5 S4 Avant
    -GIAC Tuned
    -AWE Downpipes with forge exhaust
    -Podi Boost Gauge
    -Alcon/Staisis Brake kit
    -H&R Coilovers
    http://tinypic.com/r/330v8dh/7
    Veteran Member Four Rings Aggv's Avatar
    Sep 26 2006
    Ohio
    x2 That's about all you can really hope for
    Love the wheels, and color.
    S4
    Veteran Member Four Rings A4 TSCHUSS's Avatar
    Apr 24 2005
    E55 AMG, CTS-V
    Jacksonville, Florida
    Not gonna lie, I was expecting a higher trap after seeing dynos, especially in cold weather. 60ft was pretty good, the A4 or E55 are ready for some highway runs when you are Come on down to Florida haha.
    To the guy saying should go low 11s when trapping 119mph, lay off the pipe.
    And it is always a good day at the track when you drive it home.
    ~David~
    Gone but not forgotten 437whp on 93 octane and washer fluid injection A4 12.2 best ET, 12.3@119 best overall
    480whp/500wtq E55 AMG 11.6@120
    CTS-V 9.6@148
    Jan 25 2006
    A4 2.0T
    MD
    You had your chance when you were in VA!
    Only put down a little more then your A4 and trapped sufficiently faster than it, seems about right.
    Apr 24 2005
    E55 AMG, CTS-V
    You were still many hours from me and I worked 70 hours a week when I was there! Trust me if you were close I would have been there.
    And what do you mean trapped sufficiently faster? A4 did 93.89 in the 1/8th to your 90.89 and it trapped 118.6 to your 119.0 which is nearly identical, only thing is I did that with bad syncros in my transmission (slow shifts). Here watch the video and see how slow I was shifting, you can tell by how long it takes to hear turbo/exhaust again.
    1.96 60ft and you can hear I let off in 1st gear from spinning to much just like you had trouble with then got back in it before shifting to 2nd.
    Click
    And here is fast shifts you here the turbo quickly spooling with a good tranny and faster shifts unlike the 1/4 mile run. I know the car will do better than 119, I just haven't made it back with a good clutch and transmission to put it on paper.
    click
    And E55 ran 11.6@120 a few nights ago with 1.82 60ft
    I'm not scared of no stinking Frankenturbo S4 haha
    I wish my roommate would hurry up and get his RS6 turbos and meth installed in his S4 then we can have all kinds of fun videos. Win or lose, it is all fun to me doing different comparisons.
    ~David~
    CTS-V 9.6@148
    Jan 25 2006
    A4 2.0T
    MD
    Quote Originally Posted by A4 TSCHUSS View Post
    Are you reading what I have typed??? Let me ask you a question. What do you think is going to happen to my 1/8th et and trap if I am spinning in 2nd gear? I am lucky it caught eventually on the this run.. The run after this spun to redline and never caught at all... high performance summer tires, low temps, and TQ don't play nice some times.
    No point in being scared. We are worlds a part and these runs will never happen.
    Jan 25 2006
    A4 2.0T
    MD
    Quote Originally Posted by Aggv View Post
    Thank you.
    Apr 24 2005
    E55 AMG, CTS-V
    You don't have to tell me about torque, trust me you will never have the problem I do in the E55 with only rear wheel drive and over 500ft/lbs at the wheels at 2800rpm. I have all kinds of problems trying to keep that thing from going all over the place on street tires. With that said, I got traction with a 1.82 60ft and trapped 94.0 in the 1/8th and 120.0 in the 1/4 and then I spun all over the place and did a 2.11 60ft and still trapped 93.1 in the 1/8th and 119.4 in the 1/4. I am sorry but you can think you will have big changes but I have been down the track well over 100 times, I would guess closer to 200 times and know how things work. I always spin completely through 1st gear until shifting to 2nd in my A4, just depends if you actually have some good forward motion going while spinning.
    You got a 1.76 60ft, your forward motion was very good spinning or not, so you won't be seeing any major changes with everything else being equal (no changes to make more power in the car).
    And I was being sarcastic and joking about the not being scared part, just saying it would be fun no matter the outcome.
    You could always go back again and prove me wrong though
    ~David~
    CTS-V 9.6@148
    Active Member Four Rings NYCVR6's Avatar
    Queens, NYC
    C'mon, spinning second gear all the way to red line? Were you running on snow?
    I went 125 consistently on crappy tires with K04's, never spun second gear. Hell with just about 600whp, a bog on the cars face with a 2.26 60', my car 100 mph in the 1/8th and 130mph in the quarter. No spinning second gear with that power either.. You can try to make up excuses, but it's not going to work. You have a decent 60' on the sheet, dont pretend like you are spinning second gear to red line, it's just silly because we are looking at the sheet break down. I'd sooner believe the tune is off, that's a way better excuse.
    Justin- 01.5' Pearl S4 24V VR6 Turbo Pow Pow
    034 Motorsport
    FFE Racing
    MoTec
    Tuned By Shane T
    Boost Factory!
    Drive your car, not your dyno sheet
    Jan 25 2006
    A4 2.0T
    MD
    So in your opinion a 93 mph trap 1/8th trap is a big change??? I never said this car could run low 11s, because I don't think it can in its current state. I would be happy with a low 12.
    I swear you are not reading... AGAIN the launch was OK, the car lost control in 2nd gear.. You do the math... how does one get a 1.7 60' foot, make as much power as this car clearly does, on a ko4 size turbo setup and only run 8.3 in the 1/8th? Look at the 330' foot... there is almost a half second lost in spinning.
    Jan 25 2006
    A4 2.0T
    MD
    Quote Originally Posted by NYCVR6 View Post
    You are silly.
    If I say the car was spinning in second gear, then the car was spinning in second gear. The end of story.
    How am I going to argue something with you that I experienced? Please go sit down in a corner. Additionally, your experience is irrelevant to this situation as you left out some key factors.
    Do you know the condition of my tires or the condition of the track? What do you know? I guess I imagined almost crossing over the center divide as my car spun... lolz.
