Results 1 to 40 of 63
    Active Member Three Rings spinall4's Avatar
    Jan 10 2010
    Buffalo, NY
    frankenturbo vs elim -STATS
    Please state any experience and actual #'s you have had with either of the turbos. Also the difference in price, and what would be better for a dd/occasional track car. Also does anybody offer an ots tune for the franks yet?
    Veteran Member Four Rings Turbwhistle's Avatar
    Jan 02 2011
    I am interested in this question also.
    Chris|1999.5 B5 A4 Avant 1.8TQM Brilliant black|Flickr
    PSS9 | StopTech | Fikse | Challenge Motorwerks | EPL
    Dec 05 2007
    No personal experience, but the Frankenturbo F4 will never be able to flow what the GTRS/GT71R can. And no OTS tune for the Frankenturbo, but Unitronics is working on it (so they say).
    posted 8/31/2011
    Quote Originally Posted by David@Unitronic View Post
    We do not have a specific software for these turbo yet on longitudinal engine. Work is in progress and it should be available shortly.
    Veteran Member Four Rings Turbo Nerd's Avatar
    May 12 2009
    B5 A4, B5 S4, C5 Allroad, C5 A6
    Detroit Metro Area
    Stock motor GT2871 Elim 18 psi... I walked a K04'd Uni Jetta pretty good, put bus lengths on a APR stage 1 S4, and walked a GIAC stage 2 S4, walked a MK6 GTI (APR stage 2+, carbino, HPFP, TBE, light weight wheels ect.). I can tell you numerous cars I beat but I never felt the full potential of this turbo since it was on a K04 tune (ran like piss in high rpm). I want to see what it will do with a built motor and high boost which is one of the reasons I don't want to ditch the setup just this second.
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    Quote Originally Posted by Turbo Nerd View Post
    I wish my tune would run even close to that!
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Veteran Member Three Rings CamrideA4's Avatar
    Jan 05 2011
    Raleigh, NC
    I've got about $2400 into my FT setup (that's including the FMIC that I haven't installed yet) and my car was bone stock to start. I can't comment on the price of an elim since I've never had one. There is no off the shelf tune yet, but as mentioned Uni is working on one (I wouldn't hold your breath though, it seems to be taking them a while).
    As far as performance I don't have any dyno's yet but I will get one once my FMIC is installed and Malone finishes tweaking my tune. Right now I don't have any problem beating my brother-in-law's 2011 GTI (stock) by a few car lengths to 60mph. I haven't raced anyone else though, but the car feels great. The FT will hit max spool (whatever you want that to be) by 3,000rpm. For a DD I think it's great (as that's what mine is). I'm very happy with the amount on money spent and the performance I've gotten, especially know it'll get much better once my IATs are under control with the FMIC.
    2001.5 A4 1.8TQ Tiptronic - FrankenTurbo F4 - 440cc Green Giants - TT225 MAF - Borla exhaust - ST Coilovers - Malone Tuning - Garrett FMIC
    Jan 10 2010
    Buffalo, NY
    Apr s4 not really impressive, but a stg2 giac s4 now we are talking a solid 110mph trapping car and you walked one? Thats impressive! I am now on my third b5 1.8t and also had a 01 s4 6spd and i ran a 13.8 @100 bone stock was def a fun car, but could not work on it myself and maintenance/labor/parts were just way to much money. I mean really $6000 for a turbo replacement job, $1500 for aftermarket downpipes wtf lol.
    Jan 10 2010
    Buffalo, NY
    Turbonerd any pics or vids of it in action?
    Registered User Four Rings
    Feb 08 2011
    B5 A4 2 liter HTA3586r
    Phoenix, Arizona area
    Has anyone tried running a FT on a APR stage 3(GT28r) tune?
    Veteran Member Four Rings dcampana's Avatar
    Nov 01 2006
    04 Allroad, 01a41.8Q
    Nor Cal
    My mods are below. At 25psi I ran a 12.74 at 109mph. That was a stock block and then I windowed the block in 3 spots. So now I am running another stock block (I know I know) butvat 19 psi. Its slower for sure but still pretty quick.
    I bought used parts and have about 2200 in it.
    my ride: 2001 A4qtm... 2871r, 440cc, 3 bar, turbo xs dv, custom 3" exhaust, test pipe, Cm fx400 billet LWFW...
    2004 AR... stage 1 DAZ tune
    Timing belts, clutches, and all done in the North Bay. Pm me.
    Jan 02 2011
    Quote Originally Posted by M-Hood View Post
    We should try this, you can use my car as a test car.
    Oct 22 2005
    Reppin the Mitten.
    I'm impressed.
    The tune must be called wishful thinking? . I haven't seen you in a while.
    Jan 25 2006
    A4 2.0T
    MD
    Without even knowing any actuals about this situation, I can tell you that S4 was broken. He was probably in limp mode running 5 psi.
    Jan 10 2010
    Buffalo, NY
    Quote Originally Posted by Don Supreme View Post
    Meh apr tune is crap i have seen run slower times than i did stock lol.
    Oct 22 2005
    Reppin the Mitten.
    Quote Originally Posted by spinall4 View Post
    Thats most likely attributed to the nut behind the wheel.
    Veteran Member Four Rings flynnr's Avatar
    Sep 22 2008
    2015 Q7 TDI Prestige/S-Line
    Minnesnowta (Roch)
    with all of the technology these days, its crazy that we cant get videos of all of these claims...
    but a gt871r running 25psi should be aroudn 400chp
    giac stage 2 s4 is what 330chp?
    1999 Audi A4 Avant 1.8tqm
    JE pistons/ Scat Rods/ Built AEB head (8500rpm)/ GT2871r/ 034 IIc Standalone/
    034 Tubular Mani/ full 3" Exhaust/ Racetec FMIC/ Stg 4 Clutchmasters/ V&S shift kit/
    H&R Coilovers /H Sport sways F&R/ AR racing 330mm BBK & S4 rear brakes/S4 HID's
    Jan 10 2010
    Buffalo, NY
    Quote Originally Posted by flynnr View Post
    Pretty much but the s4 also has around 400 ft/lbs and a 6spd with better gearing
    Jan 25 2006
    A4 2.0T
    MD
    Well I had a gt71 elim A4, and I also had an APR chip on my S4 back when it was stock turbo.. I raced a gt71 elim a4s, running more than 18 psi and other faster A4 setups.. and they lost.
    As I have said before on the forum. I have ran many A4s in my S4. While running the ko3 s4, I lost to a 35r A4 (stroked 2.0) (running low boost to boot), and a big Borg warner turbo s364 or something like that....
    Now keep that in mind, there is NO WAY he put bus lengths on a properly running chipped b5 s4, with a half decent driver.... especially @ only 18 psi. I am not doubting his story, so the logical conclusion is that the car he raced was broken.
    Jan 10 2010
    Buffalo, NY
    Now keep that in mind, there is NO WAY he put bus length on a properly running chipped b5 s4, with a half decent driver.... especially @ only 18 psi. I am not doubting his story, so the logical conclusion is that the car he raced was broken.
    /truth
    Established Member Two Rings 2BehindJordan's Avatar
    Jul 03 2010
    01' A6 2.7QT
    Jersey City, NJ
    Quote Originally Posted by vinny.dtw View Post
    LOL
    Veteran Member Four Rings ZimbutheMonkey's Avatar
    Mar 27 2010
    solar system
    I can't speak for the Frankenturbo directly, but my K04 hybrid (which was very close to a F4L) was run most of it's life on an Upsolute GT28 tune. So if you're hinting that you can probably get away with it (and I'm preeetty sure you are ) , I'll agree with you 100% on that.
    Personally, I think people are making way too big a deal over not being able to find a 'proper tune'. Really people, Audis aren't that 'special'. As long as you're running a MAF and the turbo you're running doesn't flow way more air at a given PSI than the file thinks it should be seeing (like 21 PSI on a K03 vs 21 PSI on a 71r), then it should work. It may require some logging and fiddling to make it perfect, but you can dial it in eventually.
    Anyway, just saying that not having an OTS tune for a F4L is not a really good reason to pass on buying one. Also, remember that most of the OTS tunes are just that, OTS. It's not tuned exactly to your hardware anyway. So in any case you'll probably end up having to do a little legwork of your own to get it optimal no matter what canned file you get.
    May 01 2011
    2000 A4 atw car with a stock aeb motor, 71r elim, revo stg3 custom file, 550cc, 3 bar, 3 inch exhaust, FMIC, 2.5 inch ic piping, MBC, 3 inch intake after stock maf, forge dv, no emissions or pcv crap.
    run it on 20 psi mostly, have run it on 24psi with no timing pull or knock on 93 octane but i'm keeping the timing numbers very low. car pulls real hard on the highway. dont have any numbers on it yet but its fasssssttt on 24psi and a 5500 rpm launch will spin all 4. going with a 01.5 awm harness and ecu for the wideband o2 and better software options.
    a little laggy on the street and with a 6 puck copper clutch it can be a bitch to drive around town but i dont care. frankenturbos or any kkk turbo is gonna be easier to DD from faster boost response. i dont hit full boost until 5k rpm or so iirc havent driven it in awhile been parked with no exhaust on it
    Jan 05 2011
    Raleigh, NC
    Quote Originally Posted by ZimbutheMonkey View Post
    Yep. Most of the time spent tuning my car with Malone has been dealing with part throttle issues and other things like that. WOT it runs great. There has been some tweaking there and testing with different boost levels, but overall it just runs great at WOT. I'm running between 225-235g/s through the MAF right now and it feels good. I'll be even happier once I get this damn FMIC installed tomorrow.
    Stage 3 Forum Advertiser Four Rings Info@EuroCode's Avatar
    Dec 24 2008
    Torrance
    We have run the REVO GTRS 550 file on the CH box with a 3bar FPR and the Frankenturbo performed flawlessly. I cannot imagine it making more than 250WHP though.
    EuroCode Tuning, Inc.
    1872 Del Amo Blvd Unit A
    Torrance, CA 90501
    310-294-8108
    Jun 10 2010
    Quote Originally Posted by Info@EuroCode View Post
    If I was to put a FT setup on my car, that would be enough power for me.
    Any tunes for nDBW cars?
    Dec 24 2008
    Torrance
    No tunes for any non drive by wire cars on the B5 chassis. REVO does not formally suppport Frankenturbo if you go with a REVO file it will be a semi home brew setup.
    Torrance, CA 90501
    310-294-8108
    Mar 27 2010
    solar system
    Quote Originally Posted by CamrideA4 View Post
    Funny how that works eh? It's been the same with my Eurodyne setup. Not that there were any problems with the base file per-se. But the first order of business was to try and optimize the off boost/part throttle response since 99% of my driving occurs there. Hell, with traffic the way it is where I live, sometimes I can go an entire day without ever getting a chance to put my foot down.
    Strangely enough, my most daunting task so far has been tuning at idle. I put a VR6 TB on and the damn car refuses to idle at a set point. It keeps surging from 1000-1500 RPM. Problem is, I'm starting to think that Chris Tapp didn't access any maps necessary to change the idle in the ME3.8/5.2 release of Maestro.
    May 12 2009
    Detroit Metro Area
    Might of been in stock mode I'm not sure but I wouldn't lie to impress anybody. Also maybe it wasn't bus lengths but probably 5-6 cars and pulling (car was running healthy that day). When I ran the stage 2 the driver said his drive shaft was messed up or something so he couldn't shift to fast (something along those lines I don't remember it was last year). Yeah I'm not trying to say my car was faster than theirs but I did in fact beat them. The stage 2 car always ran like ass put it turbos 2 or 3 times and it's smoking again lol.
    I'm not one to cause any drama and say my car is better than someone else's or anything along those lines. The car was getting faster and faster before my #1 rod decided he wanted to go to the moon (idk wtf he was thinking). Whatever we will see what's it like with a built motor, race gas, real tune, and high boost.
    May 12 2009
    Detroit Metro Area
    I'm impressed.
    What do you mean I'm on this site every night lol.
    Oct 22 2005
    Reppin the Mitten.
    in person jerk.
    May 12 2009
    Detroit Metro Area
    I'm not sure if I know you. If your thinking this is Louis it isn't.
    Oct 22 2005
    Reppin the Mitten.
    Yea, I thought it was...oops?
    Veteran Member Four Rings Shhmaudi's Avatar
    Nov 16 2009
    Ducati 1299 panigale, Raptor, Tesla Y, MK2 TTRS
    Sandy eggo
    Old: 1.8T Stg 3, Noggy stg 3, Silvaro tag 3 B5 |JHM Trans W/Carbon Syncros 4:1 diff|Tial 770|I.E Rods|Built 2.8 Heads W/ supertech RS4 intake, Y pipe, manifold etc...
    Current: 2013 TTRS Nimbus grey| HRE FF01| 034 RSB w/endlinks| 034 CF intake| 034 dogbone mount & CNC shifter bushings| Miltek DP custom 3in exhaust| Autotech HPFP| AEM 3-1 gauge|Schroth racing belts| S3 shifter| Revised injectors| Ceramic coated/ PPF
    May 12 2009
    Detroit Metro Area
    I bought it from him last year.
    Sep 22 2008
    Minnesnowta (Roch)
    [QUOTE=Shhmaudi;6967978]This is my most recent win
    http://www.audizine.com/forum/showth...at-a-B6-V8-S4!
    http://www.youtube.com/user/MrSpeige.../5/m9GYGmNdtxo
    And a lil montage I put together after I got my new exhaust and Go Pro
    http://www.youtube.com/user/MrSpeige.../3/Jkl8bx-Y4kM[/QUOTE
    you running a little rich? soudns good though.
    Nov 16 2009
    Sandy eggo
    Yea I am running a lil rich. How could you tell? I know its a lil off topic but how do you correct that with a 440cc unitronics tune on a 98? Its killing me when I go to down shift and rev match it hesitates and bogs a bit..
    Sep 22 2008
    Minnesnowta (Roch)
    It just sounded like itto me.
    and you can see it in your video that you have some smoke coming out of your exhaust
    i recommend getting an adjustable fuel pressure regulator. i had that same tune and I ran a bit rich too and tweaking my FPR helped a lot.
    Nov 16 2009
    Sandy eggo
    Did you mount the FPR on the fuel rail? I forget what year was your last a4? Did you have a A/F gauge?
    thanks for the help
    I gues you can pm me if you wanna stay on topic here
    Oct 22 2005
    Reppin the Mitten.
    Wait a second...this is Lou's brother isn't it?! lol
    Sep 22 2008
    Minnesnowta (Roch)
    Quote Originally Posted by Shhmaudi View Post
    thanks for the help
    last a4 was a 97. and no i didnt have an a/f gauge to be honest. i kept it pretty near what it was supposed to be, but just tweaked it a little bit and it felt much better
